Question / Help OBS Problem?
Palladini921
When I run OBS and Capture My Desktop, I get several (never-ending repeating) desktops that get smaller into infinity. I am trying to record my desktop, it has 2 screens, how do I record each screen. I have an NVIDIA Graphics Card
03:06:33 PM.107: CPU Name: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
03:06:33 PM.107: CPU Speed: 3433.769MHz
03:06:33 PM.107: Physical Cores: 4, Logical Cores: 8
03:06:33 PM.107: Physical Memory: 16007MB Total, 10282MB Free
03:06:33 PM.107: Kernel Version: Linux 4.15.0-46-generic
03:06:33 PM.107: Distribution: Flatpak KDE Runtime 5.12
03:06:33 PM.108: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.19.6
03:06:33 PM.108: Portable mode: false
03:06:33 PM.157: OBS 23.0.0-modified (linux)
03:06:33 PM.157: ---------------------------------
03:06:33 PM.181: ---------------------------------
03:06:33 PM.181: audio settings reset:
03:06:33 PM.181: samples per sec: 44100
03:06:33 PM.181: speakers: 2
03:06:33 PM.186: ---------------------------------
03:06:33 PM.186: Initializing OpenGL...
03:06:33 PM.294: Loading up OpenGL on adapter NVIDIA Corporation GeForce 9800 GT/PCIe/SSE2
03:06:33 PM.294: OpenGL loaded successfully, version 3.2.0 NVIDIA 340.107, shading language 1.50 NVIDIA via Cg compiler
03:06:33 PM.303: ---------------------------------
03:06:33 PM.303: video settings reset:
03:06:33 PM.303: base resolution: 1280x1024
03:06:33 PM.303: output resolution: 1280x1024
03:06:33 PM.303: downscale filter: Bicubic
03:06:33 PM.303: fps: 60/1
03:06:33 PM.303: format: NV12
03:06:33 PM.303: YUV mode: 601/Partial
03:06:33 PM.303: NV12 texture support not available
03:06:33 PM.303: Audio monitoring device:
03:06:33 PM.303: name: Default
03:06:33 PM.303: id: default
03:06:33 PM.304: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
03:06:33 PM.426: No blackmagic support
03:06:33 PM.428: NVENC supported
03:06:33 PM.428: FFMPEG VAAPI supported
03:06:33 PM.452: ---------------------------------
03:06:33 PM.452: Loaded Modules:
03:06:33 PM.452: text-freetype2.so
03:06:33 PM.452: rtmp-services.so
03:06:33 PM.452: obs-x264.so
03:06:33 PM.452: obs-transitions.so
03:06:33 PM.452: obs-outputs.so
03:06:33 PM.452: obs-libfdk.so
03:06:33 PM.452: obs-filters.so
03:06:33 PM.452: obs-ffmpeg.so
03:06:33 PM.452: linux-v4l2.so
03:06:33 PM.453: linux-pulseaudio.so
03:06:33 PM.453: linux-decklink.so
03:06:33 PM.453: linux-capture.so
03:06:33 PM.453: image-source.so
03:06:33 PM.453: gnome-screencast.so
03:06:33 PM.453: frontend-tools.so
03:06:33 PM.453: decklink-ouput-ui.so
03:06:33 PM.453: ---------------------------------
03:06:33 PM.453: ==== Startup complete ===============================================
03:06:33 PM.453: Service '' not found
03:06:33 PM.455: All scene data cleared
03:06:33 PM.455: ------------------------------------------------
03:06:33 PM.458: pulse-input: Server name: 'pulseaudio 11.1'
03:06:33 PM.458: pulse-input: Audio format: s16le, 48000 Hz, 1 channels
03:06:33 PM.459: pulse-input: Started recording from 'alsa_output.pci-0000_05_00.0.analog-mono.monitor'
03:06:33 PM.460: pulse-input: Server name: 'pulseaudio 11.1'
03:06:33 PM.460: pulse-input: Audio format: s16le, 48000 Hz, 1 channels
03:06:33 PM.460: pulse-input: Started recording from 'alsa_output.pci-0000_05_00.0.analog-mono.monitor'
03:06:33 PM.461: pulse-input: Server name: 'pulseaudio 11.1'
03:06:33 PM.461: pulse-input: Audio format: s16le, 44100 Hz, 1 channels
03:06:33 PM.461: pulse-input: Started recording from 'alsa_input.pci-0000_05_00.0.analog-mono'
03:06:33 PM.462: xshm-input: Geometry 1280x1024 @ 0,0
03:06:33 PM.463: v4l2-input: Start capture from /dev/video0
03:06:33 PM.463: v4l2-input: Input: 0
03:06:33 PM.463: v4l2-input: Resolution: 640x480
03:06:33 PM.463: v4l2-input: Pixelformat: 21UY
03:06:33 PM.463: v4l2-input: Linesize: 640 Bytes
03:06:33 PM.463: v4l2-input: Framerate: -nan fps
03:06:33 PM.479: Switched to scene 'Scene'
03:06:33 PM.479: ------------------------------------------------
03:06:33 PM.479: Loaded scenes:
03:06:33 PM.479: - scene 'Scene':
03:06:33 PM.479: - source: 'Screen Capture (XSHM)' (xshm_input)
03:06:33 PM.479: - scene 'Scene 2':
03:06:33 PM.479: - source: 'Video Capture Device (V4L2)' (v4l2_input)
03:06:33 PM.479: - source: 'Text (FreeType 2)' (text_ft2_source)
03:06:33 PM.479: - scene 'Scene 3':
03:06:34 PM.018: adding 69 milliseconds of audio buffering, total audio buffering is now 69 milliseconds (source: Mic/Aux)
03:06:34 PM.018:
