Obs problem with plugin SE.LIVE
pabeloescobar
I have issue with obs studio. I install SE.LIVE plugin in obs and it's happening. How to fix it?
You need to contact streamelements support.
Or completely remove this plugin. use the uninstaller they provide, then go to %apdata%\obs-studio\ and delete the leftover files they keep in here for no real reason. This files keep interacting with OBS continuing causing problems.
Now uninstall OBS and reinstall OBS in order to fix any other change this plugin may have done.
This happens when the obs studio window is moved, i.e. it changes from the entire screen to a smaller one
