OBS problem with capture card
That didn't fix it.
Must be either something in OBS or it's the onboard video that is causing the issue.
Does the issue present when not using OBS? For example, using an editor to capture screen recording from the capture card. That will eliminate if OBS is the issue.
I got the better processor and heatsink I used on the other identical computer.
Those should be here Saturday.
I'll install them and report back.
