Question / Help OBS Problem [Very uncommon] Please help!
Denisseriful
Hello everybody so all good 'till the last update appeared,so when i was pressisng " start recording" it was a delay like 5 seconds ,and the Windows 10 loading icon,ok then i tried to re-open obs and tried again,modyfied some settings,nothing,reinstalled the porgram nothing.I didn't had this problem 'till yesterday.Thanks
MSI Radeon R9 270X OC EDITION Twin Frozr
Intel Core i5 4460 3.2 Ghz Quad-Core
Gigabyte GA-B85-HD3
HyperX Blu 8GB (2x4GB) DDR3 1600MHz CL9 1.65V
Western Digital Blue 1TB SATA-III 7200RPM,64MB
RAIDMAX Super Aoleus Black
:Samsung SH-224-BB,Bare Bulk
RAIDMAX Hybrid 2 RX-730SS 730 W
Cooler Master Slient Fan 120 Sl1
AOC E2270 SWN 1920X1080,21,5''
Speedlink Gaming THEBE Stereo
My internet is ubergood so no troubles here and my settings are supercool too,so no lagg in videos even 1080p 60 fps,other settings won't help me.
Denisseriful
OBS log missing.
Sorry,forgot about that, here's the link:https://obsproject.com/analyzer?url=https://gist.github.com/11fd7b5d3242d877b87d
It sais that the bitrate it's too hight ,yeah because i use 10.000 to record only,i use only 3500 when live streaming and the audio bitrate it's just perfect for my headphones i tried 128 too.So i don't need to change any settings just tell me how to solve the problem please.And i recorded a black screen just to show the problem,it doesn't change anything if I try thin on desktop or in-game.
dping
with that log, you have no sources. change to a scene with sources or make a new scene and add the sources you need
dping
Hello,ok i'll try that with a desktop scene + 1 in-game scene.I will send you 2 gyazos soon.Thanks for your help.
I dont need screen caps as much as you need to post a log while using only game capture OR windows capture (not both trying to grab the same scene)
Denisseriful
Well okay but i will still upload monitor capture too,maybe it helps you.Here it is the monitor capture log: https://obsproject.com/analyzer?url=https://gist.github.com/5215dc77335733446bd4 and here it is game capture log:https://obsproject.com/analyzer?url=https://gist.github.com/d53a91259b13d0686a3d i was capturing CS:GO,no other recording software installed.
Denisseriful
The same thing happens with the problem explained below when i go to settings>encoding i must wait 3-4 seconds and if i click it's not responind for a second.Hope this helps you,.
Denisseriful
I would attempt to update your intel GPU drivers. if this issue is only happening with QSV then that is where your troubleshooting needs to start.
Thank you very much sir,i will try this and if the problem occurs again i will come back to in maximum 24h.Thank you again for all :)
