OBS only recording 1st audio track
sparkybruh
Hi all,
I'm a bit new to OBS so this is probably a bit of a beginner question, but I would like to separate my audio tracks for my recordings (one separate track each for discord, game audio, and my microphone) and in every recording OBS will only capture the first recording in order. What I mean by 'in order' is, for instance, if I have track #2 selected to record, all other tracks (3, 4) are ignored and it will only record that. Yes, I have advanced audio settings on. 3,4, and 5 tracks- the ones I'm using- are enabled, and they are enabled in the advanced audio properties as well. I cannot think of anything else that would cause this to happen. Thanks in advance.
How did you check the recorded audio tracks in a finished recording? Media players will play back only one track at a time. You need to switch tracks within the media player to access other tracks. Use information software such as ffprobe or MediaInfo to check the actual number of audio tracks in a video file.
