Question / Help OBS not recording desktop audio using Audio-gd R2R 15 dac/amp)
Schmidter
It works if I use my blue yeti as source. OBS shows audio is being played by the audio-gd dac amp. but it doesn't record nor stream it. I tried every setting I could find in OBS. And more as well. Plus spending several hours searching google and Youtube.
Link to dac amp: http://www.audio-gd.com/R2R/R2R15/R2R15CH.htm
USB interface + drivers: http://www.audio-gd.com/Pro/dac/Amanero/AmaneroCH.htm
official website for usb interface/drivers
EDIT: Also tried OBS Classic. OBS classic works as well.
EDIT2: Since it works with OBS Classic. Is there a way to copy the file or files that handles audio drivers onto obs studio? Perhaps it will work together, and fix this issue?
EDIT3: It also works in OBS 13.1. But not in a few earlier versions. Gonna see recent I can get with the versions where it is working. Maybe later files if not the same are more compatible if it where to work copy pasting them over current version which does not work for me.
EDIT4 IMPORTAN!!: It works in OBS Studio up until 13.1. But the audio has scratches, so not fluid audio. 13.2 has these things regarding audio in the notes. "
  • Fixed a case where audio would completely stop outputting from certain sources
  • Fixed a case where audio for certain sources would go out of sync
  • Fixed multiple cases where audio latency would increase unnecessarily
  • Fixed a bug where multi-track audio outputs would potentially not be in sync
One of these changes made it so the audio is not captured at all by my dac/amp. However 13.1 still had bad audio. OBS Classic had great audio, no stuttering or scratches. Could go back to see what version of OBS Studio had the good audio quality. But man I'm tired, spend hours upon hours trying to fix this. Hope someone out there can help me.
EDIT5: Another possible solution. Driver signature file, wherever and whatever it's called in OBS Classic and the new one. Copy paste settings from old, so perhaps it work? I don't know.. Just wild guesses. :)
Cheers
The problem persists with the current (22.0.1) version of OBS Studio and Audio-GD R2R-11. Mixer shows audio coming from the DAC but none comes through to recordings. The latest that i could get to work was 13.1 as well.
Okay, scratch that. I don't know what went different this time but disabling "use device timestamps" for approximately tenth time worked.
