To sum it up, I stream Fortnite on a 144hz monitor perfectly fine with normal obs streaming on my gaming pc. The issue is late game in competitive fortnite frames drop heavily as well as ping increase because of their bad servers. The frames drop heavily and they are much higher if the stream is turned off/streaming via ndi settings on my second pc. Here lies the issue. When I stream via Ndi dual pc, my frames drop heavily so much that the stream disconnects, my internet crashes for 10-15 seconds and then obs lags/disconnects. I've lowered my bit-rate. I've lowered settings so I would get better frames. I don't know what to do. I want to stream competitive fortnite but I can't do so when I'm getting severe fps drop because it hinders my performance heavily. Any solutions/ things I could try. I just want the ndi dual pc stream setup to work properly.
TL:DR: I need help fixing NDI Obs so it streams properly instead of disconnecting every 2-4 minutes/crashes.
OBS Crash Log: https://obsproject.com/logs/ll0EA7v703lZ6dFw
Another crash log that looks different the the one above?: https://pastebin.com/GKUSPk6v
Gaming PC Hardware:
AMD Threadripper 1950x
X399 AORUS Gaming 7 Motherboard
GTX 1080
Samsung SSD 850 EVO 500GB
32gb Ram I forget the brand
Stream PC:
Amd Ryzen 1800x
32gb Ram
Asus b350 Motherboard
Gtx 970
Samsung SSD 850 evo
Gaming PC Hardware:
GTX 1080
Stream PC:
Amd Ryzen 1800x
32gb Ram
Gtx 970
Samsung SSD 850 evo
