Xciles
Hi all.
We are currently facing a strange audio delay (or out of sync) issue that requires some help after trying out various scenarios. I duo stream with my girlfriend on one channel and mainly use NDI to send both of our PCs sources to a network server which encodes and sends to Twitch.
Setup:
PC - v (NDI)
Server (Encoding -> Twitch)
PC - ^ (NDI)
Both PCs have 4 NDI sources: 2 Video (Main Display capture 1080p (rendered down from 1440p native), Webcam capture 720p) and 2 Audio (Desktop Audio and Microphone). All sources are sent to the server which does the rest and combines additional shared scenes. We get no (or almost no) rendering issues or other dropped frames using this setup.
Splitting everything into different sources should have, as other topics described, resulted into everything being synced properly. For some reason, this is not the case using our setup.
All 3 PCs are rather beefy and (should) have no issues regarding CPU or GPU limitations and are connected with a proper router on a gigabit network. Both source PCs are using 10%-ish CPU and 15/20% GPU and are sending roughly 120/160mbits of data. The server receives roughly 250/350mbits of data, uses 20%-ish CPU and 25/30%-ish GPU. We connect to the server using remote desktop with hardware graphics adapter enabled for remote sessions (which should resolve other rendering issues), however connecting without Remote Desktop and using a monitor with mouse and keyboard does result in the same issues.
In the below scenarios we tried all different sync methods, Internal, Network and Source Timing, which still results into the audio being de-synced. Some scenarios de-sync more and faster than others.
What we tried so far (and resulted in audio being de-synced (after a while >1 hour and faster <1 hour):
Testing with one PC (sending data to the server using NDI) will result in the same issue.
We tried a lot of setups and a lot of potential fixes, but currently ran into a dead end with no idea what to do next.
Any help would be appreciated!
PS:
Demo of issue: https://clips.twitch.tv/SmokyLovelyPotUWot
Link to logs on gist: https://gist.github.com/Xciles/e7d5c03b68f7cc30c2008d0636eecf21
Setup:
PC - v (NDI)
PC - ^ (NDI)
- 4 NDI Sources per PC and using different sync methods.
- The above scenario, 4 sources: 2 vid, 2 audio.
- We tried this setup using OBS 25.* and NDI 4.8 or 4.9.
- In this scenario all sources have a different delay. OBS NDI 4.9 makes the problem worse and increases the delay at a faster rate.
- 2 NDI Sources per PC and using different sync methods.
- The above scenario, using 2 sources instead of 4. We combined the audio-only sources into the corresponding video sources:
- Desktop capture with desktop audio source.
- Webcam with microphone source.
- This results in a -somewhat- workable solution. The audio and video within the combination source are synced correctly, but there is still a delay between the two combination sources (i.e. (webcam+mic) is a full second ahead of (desktop+audio)).
- Using OBS NDI 4.9 results into the audio streams, within 1 NDI Source, being delayed again as well. (we do not have this issue with the 4.8 version)
PS:
