Ive tried everything and i haven't gotten anywhere with the issue!
Heres examples:
https://imgur.com/fbPNgjN audio showcasing problem
https://imgur.com/a/3IdJ4DA audio's waveform
Log file:
https://obsproject.com/logs/ad6vTUfTjcmHSmyX
Microphone is not a problem or hardware, this problem is only in obs, i tried to record with audacity and my microphone have no problems there.
I use microphone on my laptop and i only have my mosue plugged in and microphone, nothing else.
no usb hubs or anything like that.
Heres things i tried:
Heres examples:
Log file:
- My mic is Fifine ampligame am8
- The CPU isn't under a heavy load during my streams/recordings. The issue persists even if no game is running.
- I've recorded using hardware AND software encoding.
- Problem is in both broadcasts and recordings.
- I've recorded in Audacity at the same time as OBS to confirm that the cutouts only happen in OBS recordings, so it doesn't seem like a hardware issue.
- The sample rate for all audio devices has been set to 44.1khz, which matches my OBS settings.
- I've tested the mic with filters and without.
- The gain knob on my mic is pretty low. It's definitely not peaking unless I shout into it point-blank.
- I've tried running Streamlabs as administrator.
- There doesn't seem to be any correlation with my speaking volume or keyboard/mouse inputs.
- I've tried using OBS as well as SLOBS. No discernable difference.
- I've tried "Exclusive Mode" on and off under Windows sound settings.
- No discernable difference when I change the audio bitrate.
