Question / Help Obs Lossless Quality for Sony Vegas
Is there a way to fix the grey screen that displays on Sony Vegas? Playing the video without the software looks just like how I recorded it. I also tried this on Premiere Pro and it displays fine as well.
Boildown
Post the media info from the file you're trying to add into Vegas and the OBS log file from when you recorded it.
Boildown
16:08:21.819: [NVENC encoder: 'recording_h264'] settings:
16:08:21.819: rate_control: lossless
16:08:21.819: bitrate: 0
16:08:21.819: cqp: 0
16:08:21.819: keyint: 250
16:08:21.819: preset: default
16:08:21.819: profile: main
16:08:21.819: level: auto
16:08:21.819: width: 1920
16:08:21.819: height: 1080
16:08:21.819: 2-pass: true
16:08:21.819: b-frames: 2
16:08:21.819: GPU: 0
So Vegas probably can't handle the video output by these settings. Instead follow this guide: https://obsproject.com/forum/resour...ality-recording-and-multiple-audio-tracks.221
Since you're using NVEnc, where it says this in the guide:
NVENC
  • Rate Control: CQP
  • CQP: 15-25
  • Preset: High-Quality
  • Profile: high
Do all these things and use a CQP of 15, to approximate "lossless". It won't technically be lossless but it will be indistinguishable from it, which is just as good, and has the benefit of making a file that will be useable in Vegas.
NVENC
  • Rate Control: CQP
  • CQP: 15-25
  • Profile: high
Ok thanks. Also here are the video info if ever necessary:
