obs encoding settings help
soh20
hi everyone
ok so i have an iMac 2017 i7-7700K CPU 4.2Ghz
64GB RAM
Radoen Pro 8GB
i installed bootcamp and have windows 10 pro on it because I would like to play and stream Minecraft java on it.
Now I'm not sure what encoder i should use for twitch streaming.
I tried x264 but it lags also tried H264/AVC Encoder which works best but also loosing "skipped frames due to encoding lag"
i attached the settings i tried so far. Any help apprciated.
Btw my cpu usage is never higher than 15% max so I'm not sure what I'm doing wrong
If you need anymore screenshots or info let me know
thanks a lot in advance
