OBS Crashing right after starting recording
2thache
logs
OBS keeps crashing every time I press record, after 2-3 seconds. Nothing shows up after the crash, and there are no crash logs. Just before this I had changed some encoder settings and audio settings, but I hadn't recorded in a long time before this, so I am not sure if this was the cause.
You are running Windows 11 Insider build 22635. Because insider builds are test versions, you may have problems that would not happen with release versions of Windows 11. Does this happen with the release version of Windows 11?
Hmm I'll try halting my insider updates then. I've been running with insider builds ever since I upgraded to Windows 11 around a year ago, so I won't be sure until next Windows update (not really willing to reinstall windows at the moment). I'll check back then, thanks!
