The IOS camera source is causing the crash. Look for updates on this particular third party plugin (and any other you have installed) and make sure is compatible with the OBS version you're using.
Sometimes it's an issue within the OS itself so you need to restart your computer (restart, not turn off/on).
If the issue persist you should contact dev (and other users) of this plugin via the Discussion section on the particular plugins' page or wherever the dev have set for this.
