OBS constantly freezing using replay buffer.
acme420
I keep trying to find a setting that allows me to save replay files that are resized to 720 with max quality and smallest size. it seems like everything is working fine, saves the replays. then out of the blue... either the replays suddenly stop saving. or if they do save its nothing but AUDIO and several still frames like 15 seconds apart.
i only save 60 seconds at a time and i gave it more and more ram from 512 to 768 now i think i got it at 2048 and it's still doing it. when i try to Stop Replay Buffer so i can reload. the application justhangs and i have to exit and restart. here is link PLEASE HELP /legit tears over here at all the moments I DIDNT ACTUALLY SAVE
You don't have a keyframe interval set, so because the encoder isn't giving a quick-cut point that OBS can use for replays, it's perpetually waiting.
Set a keyframe interval of 2 seconds or less in your encoding settings.
it's automatically on 2 by default for all the settings. any other things i could try?
