Question / Help OBS configuration help for 480p transmission ?!
Ea1991
My name is Eduardo, I live in Argentina and I have not found in any other forum or on youtube.
Here in Argentina the internet connections are not very good that we say and the servers with less ping that we have nearby are Chile and Brazil. Question that at the time of transmitting much difficulty the issue of quality and optimization of the OBS, so clarify in the title, Transmission to 480p that here is the most acceptable and normal.
Next I detail my hardware and some data about my connection, my problem comes in that at the moment of transmitting I notice many falls, lost frames and slowness in it and I can not find a configuration that fits so that it goes smoothly as should be.
Hardware:
Intel i5 9600k microprocessor (9th)
Mother Aorus z390
Video card Nvidia 1070 (8Gb Ddr5)
Memory Ram 16GB 3000Mhz Dual Channel
Solid disk 240Gb
Mechanical disc 1TB
Two monitors 1x 144hz / 1x 60hz (Just in case I clarify)
Windows 10/64 Bit.
Connection information:
Downgrade 70 / 100MB
Upload 2.5 / 6 MB
Currently in the OBS I am using the output configuration:
Decoder: Nvenc
Apply encoder settings to streaming service: Disabled
Change output scale: Disabled
Frequency control: CBR
Bitrate: 2000/2500 (sometimes I use 1500)
Use custom cache size: Disabled
Interval of keyframes: 2
Profile CPU usage: Superfast
Profile: Default
Tune: None
Options x264: Nothing
Resolution Canvas: 1980x1080 (Monitor 144hz)
Output resolution: 853x480
FPS: 30
Downscale Filter: Bicubic
I appreciate your contributions and knowledge, excuse the vocabulary since I use google translator to be able to communicate with you.
