AxeloElPanda
OBS closes when I start the NDI output
youtu.be
I've seen the processor match, but I had already used this option months ago on the same computer.
github.com
Log 1
00:27:41.788: CoInitializeEx succeeded: 0x00000001
00:27:41.788: CPU Name: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
00:27:41.788: CPU Speed: 2394MHz
00:27:41.789: Physical Cores: 4, Logical Cores: 4
00:27:41.789: Physical Memory: 4029MB Total, 2463MB Free
00:27:41.789: Windows Version: 10.0 Build 18362 (release: 1909; revision: 900; 64-bit)
00:27:41.789: Running as administrator: false
00:27:41.789: Aero is Enabled (Aero is always on for windows 8 and above)
00:27:41.789: Windows 10 Gaming Features:
00:27:41.789: Game Bar: Off
00:27:41.789: Game DVR: Off
00:27:41.789: Game DVR Background Recording: Off
00:27:41.800: Game Mode: Off
00:27:41.850: Sec. Software Status:
00:27:41.855: Current Date/Time: 2020-06-11, 00:27:41
00:27:41.856: Browser Hardware Acceleration: true
00:27:41.856: Portable mode: false
00:27:44.565: OBS 25.0.8 (64-bit, windows)
00:27:44.565: ---------------------------------
00:27:44.568: ---------------------------------
00:27:44.568: audio settings reset:
00:27:44.568: samples per sec: 44100
00:27:44.568: speakers: 2
00:27:44.658: ---------------------------------
00:27:44.658: Initializing D3D11...
00:27:44.658: Available Video Adapters:
00:27:44.673: Adapter 0: AMD Radeon HD 5450
00:27:44.673: Dedicated VRAM: 1064120320
00:27:44.673: Shared VRAM: 1879048192
00:27:44.673: PCI ID: 1002:68f9
00:27:44.722: Driver Version: 8.17.10.1404
00:27:44.722: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=C24F390
00:27:44.891: Loading up D3D11 on adapter AMD Radeon HD 5450 (0)
00:27:45.008: D3D11 loaded successfully, feature level used: b000
00:27:45.008: DXGI increase maximum frame latency success
00:27:45.008: D3D11 GPU priority setup failed (not admin?)
00:27:46.869: ---------------------------------
00:27:46.870: video settings reset:
00:27:46.870: base resolution: 1920x1080
00:27:46.870: output resolution: 1280x720
00:27:46.870: downscale filter: Bicubic
00:27:46.870: fps: 30/1
00:27:46.870: format: NV12
00:27:46.870: YUV mode: 601/Partial
00:27:46.870: NV12 texture support enabled
00:27:46.873: Audio monitoring device:
00:27:46.873: name: Por defecto
00:27:46.873: id: default
00:27:46.874: ---------------------------------
00:27:47.118: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
00:27:47.190: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
00:27:47.681: [AMF] Unable to load 'amfrt64.dll', error code 126.
00:27:47.686: [AMF] AMF Test failed due to one or more errors.
00:27:47.687: Failed to initialize module 'enc-amf.dll'
00:27:49.425: [obs-browser]: Version 2.8.6
00:27:50.047: [obs-ndi] hello ! (version 4.9.0)
00:27:50.047: [obs-ndi] Trying 'C:\Program Files\NewTek\NDI 4 Runtime\v4'
00:27:50.047: [obs-ndi] Found NDI library at 'C:/Program Files/NewTek/NDI 4 Runtime/v4/Processing.NDI.Lib.x64.dll'
00:27:50.152: [obs-ndi] NDI runtime loaded successfully
00:27:50.178: [obs-ndi] NDI library initialized successfully (NDI SDK WIN64 06:20:19 Apr 1 2020 4.5.1.0)
00:27:51.793: Couldn't find VLC installation, VLC video source disabled
00:27:52.396: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
00:27:52.398: No blackmagic support
00:27:52.875: ---------------------------------
00:27:52.875: Loaded Modules:
00:27:52.875: win-wasapi.dll
00:27:52.875: win-mf.dll
00:27:52.875: win-dshow.dll
00:27:52.875: win-decklink.dll
00:27:52.875: win-capture.dll
00:27:52.875: vlc-video.dll
00:27:52.875: text-freetype2.dll
00:27:52.875: rtmp-services.dll
00:27:52.875: obs-x264.dll
00:27:52.875: obs-vst.dll
00:27:52.875: obs-transitions.dll
00:27:52.875: obs-text.dll
00:27:52.875: obs-qsv11.dll
00:27:52.875: obs-outputs.dll
00:27:52.875: obs-ndi.dll
00:27:52.875: obs-filters.dll
00:27:52.875: obs-ffmpeg.dll
00:27:52.875: obs-browser.dll
00:27:52.876: image-source.dll
00:27:52.876: frontend-tools.dll
00:27:52.876: enc-amf.dll
00:27:52.876: decklink-ouput-ui.dll
00:27:52.876: coreaudio-encoder.dll
00:27:52.876: ---------------------------------
00:27:52.876: ==== Startup complete ===============================================
00:27:52.878: Service '' not found
00:27:52.932: All scene data cleared
00:27:52.933: ------------------------------------------------
00:27:53.044: WASAPI: Device 'Altavoces (C-Media USB Headphone Set )' [48000 Hz] initialized
00:27:53.045: [Loaded global audio device]: 'Audio del escritorio'
00:27:53.050: Switched to scene 'Escena'
00:27:53.052: ------------------------------------------------
00:27:53.052: Loaded scenes:
00:27:53.052: - scene 'Escena':
00:28:51.825: Settings changed (general)
00:28:51.825: ------------------------------------------------
00:29:36.287: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Audio del escritorio)
00:29:36.287:
00:30:53.228: [obs-ndi] starting NDI main output with name 'OBS'
00:30:53.269: [obs-ndi] 'OBS': ndi output started
00:31:01.025: adding 557 milliseconds of audio buffering, total audio buffering is now 603 milliseconds (source: Audio del escritorio)
00:31:01.025:
00:31:01.081: Max audio buffering reached!
00:31:01.081: adding 441 milliseconds of audio buffering, total audio buffering is now 1044 milliseconds (source: Audio del escritorio)
00:31:01.081:
Log 2
01:59:53.285: CoInitializeEx succeeded: 0x00000001
01:59:53.285: CPU Name: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz
01:59:53.285: CPU Speed: 2394MHz
01:59:53.286: Physical Cores: 4, Logical Cores: 4
01:59:53.286: Physical Memory: 4029MB Total, 1363MB Free
01:59:53.286: Windows Version: 10.0 Build 18362 (release: 1909; revision: 900; 64-bit)
01:59:53.286: Running as administrator: false
01:59:53.286: Aero is Enabled (Aero is always on for windows 8 and above)
01:59:53.298: Windows 10 Gaming Features:
01:59:53.298: Game Bar: Off
01:59:53.298: Game DVR: Off
01:59:53.298: Game DVR Background Recording: Off
01:59:53.299: Game Mode: Off
01:59:53.308: Sec. Software Status:
01:59:53.313: Antivirus de Windows Defender: enabled (AV)
01:59:53.314: Firewall de Windows: enabled (FW)
01:59:53.320: Current Date/Time: 2020-06-11, 01:59:53
01:59:53.320: Browser Hardware Acceleration: true
01:59:53.320: Portable mode: false
01:59:55.304: OBS 25.0.8 (64-bit, windows)
01:59:55.304: ---------------------------------
01:59:55.325: ---------------------------------
01:59:55.325: audio settings reset:
01:59:55.325: samples per sec: 44100
01:59:55.325: speakers: 2
01:59:55.422: ---------------------------------
01:59:55.423: Initializing D3D11...
01:59:55.423: Available Video Adapters:
01:59:55.452: Adapter 0: AMD Radeon HD 5450
01:59:55.452: Dedicated VRAM: 1064120320
01:59:55.452: Shared VRAM: 1879048192
01:59:55.452: PCI ID: 1002:68f9
01:59:55.452: Driver Version: 8.17.10.1404
01:59:55.453: output 0: pos={0, 0}, size={1920, 1080}, attached=true, refresh=60, name=C24F390
01:59:55.457: Loading up D3D11 on adapter AMD Radeon HD 5450 (0)
01:59:55.545: D3D11 loaded successfully, feature level used: b000
01:59:55.545: DXGI increase maximum frame latency success
01:59:55.545: D3D11 GPU priority setup failed (not admin?)
01:59:57.730: ---------------------------------
01:59:57.730: video settings reset:
01:59:57.730: base resolution: 1920x1080
01:59:57.730: output resolution: 1280x720
01:59:57.730: downscale filter: Bicubic
01:59:57.730: fps: 30/1
01:59:57.730: format: NV12
01:59:57.730: YUV mode: 601/Partial
01:59:57.730: NV12 texture support enabled
01:59:57.750: Audio monitoring device:
01:59:57.750: name: Por defecto
01:59:57.750: id: default
01:59:57.750: ---------------------------------
01:59:58.055: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
01:59:58.193: Failed to load 'en-US' text for module: 'decklink-ouput-ui.dll'
01:59:58.523: [AMF] Unable to load 'amfrt64.dll', error code 126.
01:59:58.533: [AMF] AMF Test failed due to one or more errors.
01:59:58.533: Failed to initialize module 'enc-amf.dll'
02:00:00.701: [obs-browser]: Version 2.8.6
02:00:02.000: [obs-ndi] hello ! (version 4.9.0)
02:00:02.000: [obs-ndi] Trying 'C:\Program Files\NewTek\NDI 4 Runtime\v4'
02:00:02.000: [obs-ndi] Found NDI library at 'C:/Program Files/NewTek/NDI 4 Runtime/v4/Processing.NDI.Lib.x64.dll'
02:00:02.156: [obs-ndi] NDI runtime loaded successfully
02:00:02.212: [obs-ndi] NDI library initialized successfully (NDI SDK WIN64 06:20:19 Apr 1 2020 4.5.1.0)
02:00:04.725: Couldn't find VLC installation, VLC video source disabled
02:00:05.626: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
02:00:05.630: No blackmagic support
02:00:06.097: ---------------------------------
02:00:06.097: Loaded Modules:
02:00:06.097: win-wasapi.dll
02:00:06.097: win-mf.dll
02:00:06.097: win-dshow.dll
02:00:06.097: win-decklink.dll
02:00:06.097: win-capture.dll
02:00:06.097: vlc-video.dll
02:00:06.097: text-freetype2.dll
02:00:06.097: rtmp-services.dll
02:00:06.097: obs-x264.dll
02:00:06.097: obs-vst.dll
02:00:06.097: obs-transitions.dll
02:00:06.097: obs-text.dll
02:00:06.097: obs-qsv11.dll
02:00:06.097: obs-outputs.dll
02:00:06.098: obs-ndi.dll
02:00:06.098: obs-filters.dll
02:00:06.098: obs-ffmpeg.dll
02:00:06.098: obs-browser.dll
02:00:06.098: image-source.dll
02:00:06.098: frontend-tools.dll
02:00:06.098: enc-amf.dll
02:00:06.098: decklink-ouput-ui.dll
02:00:06.098: coreaudio-encoder.dll
02:00:06.098: ---------------------------------
02:00:06.139: ==== Startup complete ===============================================
02:00:06.290: Service '' not found
02:00:06.511: All scene data cleared
02:00:06.511: ------------------------------------------------
02:00:06.890: WASAPI: Device 'AMD HDMI Output (2- AMD High Definition Audio Device)' [48000 Hz] initialized
02:00:06.914: [Loaded global audio device]: 'Audio del escritorio'
02:00:06.964: Switched to scene 'Escena'
02:00:07.026: ------------------------------------------------
02:00:07.026: Loaded scenes:
02:00:07.026: - scene 'Escena':
02:00:09.025: [obs-ndi] starting NDI main output with name 'OBS'
02:00:09.077: [obs-ndi] 'OBS': ndi output started
02:00:20.669: WhatsNewInfoThread::run: Failed to fetch whatsnew file: schannel: failed to receive handshake, SSL/TLS connection failed
HELP, OBS closes when using ndi
bug starting obs with Ndi plugins · Issue #10 · robbi5/instreamer
hi guys please help me in my probleme it's obs who crash went i start ndi output hope you will help me this is the logs 13:41:20.587: CPU Name: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz 13:41:20....
Bug Report - NDI causing OBS 24.0.1 to Crash
Greetings everyone, i have a stream computer that is seeming to crash when ever i load OBS.. I have un-installed NDI and OBS opens and loads fine so i am suspecting it is something to do with that.. however here is the log.. 15:30:12.290: CPU Name: Intel(R) Core(TM)2 Quad CPU Q6600 @...
obsproject.com
Log 1
00:29:36.287:
00:31:01.025:
00:31:01.081:
Log 2
