OBS Capturing in Low Quality
Hissam
I'm trying to record in 1080p 60fps but the video quality (as well as obs preview) is quite blurry and low res compared to the game itself. The difference is a bit slight, but it's still noticeable and looks bad.
I have an amd rx 7600 and intel i5 12400
Log: https://obsproject.com/logs/MThHpwAMqwqDsYtr
First, update Windows. Move the display capture to it's own scene.
Don't use advanced output mode. Keep it in Simple. Ese the presets already made for better quality.
CQP level 12 is demential.
Run the Auto-configuration Wizard and apply the settings it gives. Restart OBS.
Notice you are on simple output mode. Keep it as is. Don't change a dot.
Test it. Try a better quality preset (stay on simple mode).
