Question / Help OBS 32 Bit Problems
SeanTempleton
I have had to use the 64 bit version of OBS for a while now. I recently wanted to try out the night Follower Alert for OBS for my viewers. I did everything correctly in the initialization setup. OBS 32 bit has always gave me trouble, the issue I notice right now is something to do with my audio/headset. I use the Kracken Pro 7.1. It says I need to go to msconfig or services and make sure it is running. I checked and all the services/start up is running for the program. If anyone can help me out and figure out how to get my OBS 32 bit working, I would be excited.
Error: The Kracken Launcher is incompatible with OBS. Please disable it, or use the 64 bit version.(Which I do)
Next Error: Cannot initialize desktop audio sound.
https://gist.github.com/a740cd3738e4b373f6e4
Log file^^^
Krazy
Town drunk
Well, just like the error message says: "The Kracken Launcher is incompatible with OBS. Please disable it"
You can do this via pressing windows key + R and typing msconfig.exe and disable the Kraken Launcher in either Startup or Services, I don't remember which.
SeanTempleton
When I disable this, I can no longer use my headset on team speak or other voice programs. This is really dumb. Razer is a big brand, why would OBS randomly pick software to not be capable.
