OBS 29.0.0 capture problem during cutscenes in HyperDimension Neptunia Re;Birth1
PaddyMac
There have been other issues with older OBS versions and HyperDimension Neptunia games, and at least it works now. It was just black screen according to the reports back in 2016. The issue I'm having now with OBS and Hyperdimension Neptunia is that in the video captured by OBS, there are lines around the characters mouths and shadows on their faces. I'm assuming most of the scenes are still images, and the only parts animated are their mouths and faces -- mostly their eyes. The lines and shadows are probably some kind of internally-used separator in the game. It appears normal on my monitor. It is only in OBS's captured video that these visual issues appear. So maybe OBS is failing to capture part of the video that is overlayed on the characters' faces or something.
A recent log can be found here: https://obsproject.com/logs/BT8gO4e272oKLIOR
I am attaching a screen shot showing the visual problem in the captured video.
  • Hyperdimension Nuptunia ReBirth1 OBS capture problem Screenshot 2023-01-22 205122.png
