Bug Report OBS 21 and Elgato 4K Pro Catpure Card Rendering stalls
InsertValue
Hi,
capturing 4K 30fps with the Elgato 4K Pro Capture Card on the new OBS 21 version results in ~24% lagged frames due to rendering lags/stalls. I am pretty sure that this is connected to OBS 21 as I never had the issue before with hours of captured gameplay on the same setup. Capturing via the Elgato 4k Capture tool works fine without issues.
I rolled back to version 20.1.3 and the issue was gone. I captured the same scene on 20.1.3 0 lagged frames, on 21.0.1 its 24% - both log files are attached, its a short clip but longer recordings had the same result. I had a longer recording (1 hour) with the same result but the log file is gone.
Best
Michael
