nvidia noise removal stops working midstream
meraki
mind you, i've had a lot of other issues with my stream latelny including renmderlag and encoding overload- but now i got a new issue.
my audio has been working fine until yesterday/ or the day before.
i updated my nvidia broadcast thing from here
and chose the option for 30series
but after that the nosie removal filter has not worked properly.
it works in the beginnin of the stream, then 10-15 mins into the stream it jsut stops working. trying to add it back on crashes the stream.
i see lots of ppl have issues with the noise removal, but im really dependant on having it as i dont hav et he option to stream from a room thats quiet
i tried deleting the filter, uninstall the soundeffect, reisntall and readding, but still the same error.
is there anything else that would need to be unistalled too that i might not be thinking of?
i think the error in the log is this?
[NVIDIA Audio Effects: '2. NVIDIA Audio Effects'] NVAFX SDK redist path was found here C:\Program Files\NVIDIA Corporation\NVIDIA Audio Effects SDK
is there any other good options to the noise removal from nvidia?
i feel like ive seen Nutty use soemthing from elgato wave that acted in a similar way?
