Lymkwi
Hi,
I've been using OBS ever since I had something to record, circa 2014, almost always on Debian Linux. As of recently, OBS Studio was behaving fine, albeit for the occasional flashing of my X window captures.
Last night I decided to stream. After dealing with a few errors like "Output ID 'rtmp_output' not found", I realized I was running a version of OBS I had compiled myself almost a year and a half prior (when said flickering issues appeared and weren't being fixed).
So I removed it and tried the debian package.
Didn't work.
My guess is that OBS Studio is trying to translate a string into a language for a local it doesn't understand, and things go haywire.
Here my output for "localectl".
After that I decided I was absolutely not gonna try and debug OBS on my own because this is not my responsibility, and I decided to go look on the official website for advice. I saw detailed instructions for compiling on Debian and Debian-based linux distros, and I followed them to a tee, until I ran into two compiling errors, documented in the log file attached.
For info on my setup, I'm running Debian Testing (so, I guess, bullseye), up to date (as of about thirty minutes ago) and rebooted (as of about twenty minutes ago). I'd gladly like to receive some assistance, as I am quite done with dealing with OBS misbehaving on my own, and I know no reasonable alternative to it.
EDIT: I tried to compile the current master of OBS Studio's repo.
Didn't work.
Attempted path: share/obs/obs-studio/locale/en-US.ini
Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
Attempted path: share/obs/obs-studio/locale.ini
Attempted path: /usr/share/obs/obs-studio/locale.ini
Attempted path: share/obs/obs-studio/themes/Acri.qss
Attempted path: /usr/share/obs/obs-studio/themes/Acri.qss
info: Command Line Arguments: --verbose
info: CPU Name: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz
info: CPU Speed: 2793.787MHz
info: Physical Cores: 4, Logical Cores: 8
info: Physical Memory: 24081MB Total, 10504MB Free
info: Kernel Version: Linux 4.19.0-5-amd64
info: Distribution: "Debian GNU/Linux" Unknown
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.4
info: Portable mode: false
Unknown property overflow
[... roughly a hundred times that same message ...]
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_clicked()
QMetaObject::connectSlotsByName: No matching signal for on_advAudioProps_destroyed()
QMetaObject::connectSlotsByName: No matching signal for on_program_customContextMenuRequested(QPoint)
info: OBS 0.0.1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 44100
speakers: 2
info: Initializing OpenGL...
info: Loading up OpenGL on adapter NVIDIA Corporation GeForce GTX 560M/PCIe/SSE2
info: OpenGL loaded successfully, version 3.2.0 NVIDIA 390.116, shading language 1.50 NVIDIA via Cg compiler
info: video settings reset:
base resolution: 1920x1080
output resolution: 1920x1080
downscale filter: Bilinear
fps: 30/1
format: NV12
YUV mode: 601/Partial
info: NV12 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
fish: “obs” terminated by signal SIGSEGV (Address boundary error)
System Locale: LANG=en_US
LANGUAGE=en_US:en
VC Keymap: n/a
X11 Layout: fr
X11 Model: pc105
X11 Variant: oss
X11 Options: terminate:ctrl_alt_bksp
