Question / Help No way to fix the audio!
dageruk
Hi !
I'm having troubles to trying to fix the audio from OBS, I'm working with 2 computer trying to do streaming, my gaming computer, and a laptop which is doing the work as a stream.
I have a video capture device Elgato to through the image from my gaming computer to my laptop, as well I installed an audio cloning program, Voicemeeter which I think it does its work.
I've changed hdmi, ethernet wires and all kind of settings you can change at obs studio, but there is no way to make it work, the audio works for a while, like 5 or 10 min, after that, it disapears and there isn't any sound.
Here is my log file https://obsproject.com/logs/3-T7bI1gz97iqqBR
I hope it helps to fix the problem, because I don't know what else to do
