Question / Help No sound through Bluetooth headphones when OBS starts
I attach what I did to fix it.
I go under OBS settings > Audio > Mic/Auxiliary Audio > and here i select a microphone that i have plugged, in this case via USB.
The spotify music that i have in the backround, plays instantly.
I found a fix for bluetooth headsets with mic, you can go to Settings - System - Sound - Sound Control Panel - If you have a microphone built into your headset you can go into Recording tab and disable the microphone from the headset. No additional settings required, im using Sennheiser Momentum 4
thank you guys, this help me too. just want to mention you must disable bluetooth mic but not just switch to others or set others default.
The post made by harold gave me good information, I had this problem and I fixed it on windows 10 by going to bluetooth configuration and selecting in the bottom part of that window "Sound configuration". There my bluetooth headphones were listed twice, once as the headset + Microphone and again just as the headset. I removed the Headset + Microphone and leave just the headset and it works fine with OBJ. But I am not using microphone as I don't need it, I don't know if this will cause problems later with the microphone.
THANK YOU SO MUCH! I have been dealing with this for over a year and not understanding why OBS would not use my Stereo setting. Since I also use Voicemeeter I was troubleshooting both programs and getting nowhere. Doing as you advised, I went and disabled my headset as a recording device from the Bluetooth setting and IT WORKED. I could literally cry tears of joy right now.
