No sound recorded
HariThakur
I downloaded your software and unable to use the MIC, The mic is Blue, It is connected through the USB Port. I can use it to record normally in windows 10 Professional.
I am unable to use them with your software, any help would be appreciated. I don't know what is wrong.
Thanks for any help
Hello,
i also had the same problem a few months ago. Maybe you just need to change the Sound Settings in OBS so it can identify the Mic. Or try to use another mic to be sure it is an error of OBS. Good Luck
