Question / Help No sound output headphones / need sound link
mrdummy
I used OBS without problems for church video stream
Here i set up:
2 PCS:
PC1: VNC installed. This pc does beamer pictures and plays also video when need. Sound is succesfully routed back to PC2.
PC2: VNC Installed. DScaler Installed. (VLC is little slower in video capturing - DScaler is more directer) OBS Installed.
VNC opened and set to show desktop from PC1.
DScaler opened to use USB video capture card. Sound is not heard here to headphones, because option input -> speakers is disabled. Why? Risk on "echo" sound: double sound heard in OBS video stream.
OBS started, 2 window captures set on VNC window and DScaler window.
Testing gives nice sound and video, but the speaker output is zero. So i cannot check immediately hear sound from headphone output.
Testing from internet has no sound problems, everything is perfect.
I have tried enable in capture card settings with audio in -> speakers output, but it causes echo. Which means sound from desktop is also recorded. I keep it disabled.
Is there plugin or solution to make recorded sound in OBS directly output to speakers? Just an internal link or forward mic sound to speakers. I must avoid echoing sound or loopback.
Who has good tip for my sound problem? OBS is working good with VNC and DScaler, this is only small problem.
