DexterNemrod
Hi,
I'm trying to record/stream a video with OBS (what else ;))
(here's the log https://obsproject.com/logs/5wZMRgYvLqJjjok1)
As VideoSource I use my Smartphone (OnePlus 3T) over Droidcam which works fine (over WIFI and USB).
But I can't get any Audion input.
I tried it on two different laptops but both only show me the Desktop Audio/SystemSound with working levels in the mixer and the recordings.
I tried different sources and settings for my Audio-input but (using my Smartphone+Droidcam as an ext. mic or my build in mic).nothing works.
A mic-test in the browser showed me that both sources work in win 10 and the internal mic worket in Linux (did not try Droidcam).
In a later setup I want to try a real external mic.
Any Ideas?
Thank you in advance.
Any Ideas?
