Question / Help No Desktop Audio recording while using Headset
Kyou
Edit: The issue was that OBS was set to 0 volume on the volume mixer
About 2 days ago I noticed that OBS was no longer picking up Desktop Audio (green desktop audio bar doesn't move in mixer) without me having changed anything. Before 2 days ago, everything was working as normal. I also noticed that this issue disappears when I unplug my USB headset (Cloud Hyperx 2 ) and use the speakers on my monitor, however this is impossible to stream with due to my setup.
This issue persists after reinstalling OBS, reinstalling and resettings settings, trying older versions of OBS, and adjusting the audio source for every possibility. I've seen a few topics regarding this but no one has had an answer that's solved it for me. If anyone has any suggestions, it would be very welcome
Log:
20:11:55.927: CPU Name: Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
20:11:55.927: CPU Speed: 4200MHz
20:11:55.927: Physical Cores: 4, Logical Cores: 8
20:11:55.927: Physical Memory: 8119MB Total, 3020MB Free
20:11:55.927: Windows Version: 10.0 Build 16299 (revision: 192; 64-bit)
20:11:55.927: Running as administrator: false
20:11:55.927: Aero is Enabled (Aero is always on for windows 8 and above)
20:11:55.928: Windows 10 Gaming Features:
20:11:55.928: Game Bar: Off
20:11:55.928: Game DVR: Off
20:11:55.928: Game DVR Background Recording: Off
20:11:55.929: Sec. Software Status:
20:11:55.931: Windows Defender Antivirus: enabled (AV)
20:11:55.931: Windows Firewall: enabled (FW)
20:11:55.931: Windows Defender Antivirus: enabled (ASW)
20:11:55.932: Portable mode: false
20:11:55.942: OBS 21.0.1 (64bit, windows)
20:11:55.942: ---------------------------------
20:11:55.942: audio settings reset:
20:11:55.942: samples per sec: 44100
20:11:55.942: speakers: 2
20:11:55.944: ---------------------------------
20:11:55.944: Initializing D3D11...
20:11:55.944: Available Video Adapters:
20:11:55.945: Adapter 1: NVIDIA GeForce GTX 1080
20:11:55.945: Dedicated VRAM: 4176478208
20:11:55.945: Shared VRAM: 4257038336
20:11:55.945: output 1: pos={0, 0}, size={2560, 1440}, attached=true
20:11:55.945: output 2: pos={2560, 349}, size={1920, 1080}, attached=true
20:11:55.947: Loading up D3D11 on adapter NVIDIA GeForce GTX 1080 (0)
20:11:55.971: D3D11 loaded successfully, feature level used: 45056
20:11:56.449: ---------------------------------
20:11:56.449: video settings reset:
20:11:56.449: base resolution: 1920x1080
20:11:56.449: output resolution: 1280x720
20:11:56.449: downscale filter: Bicubic
20:11:56.449: fps: 60/1
20:11:56.449: format: NV12
20:11:56.451: Audio monitoring device:
20:11:56.451: name: Default
20:11:56.451: id: default
20:11:56.451: ---------------------------------
20:11:56.452: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
20:11:56.453: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
20:11:56.494: [AMF] <obs_module_load> AMF not supported (no AMD graphics)
20:11:56.494: Failed to initialize module 'enc-amf.dll'
20:11:56.505: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
20:11:56.506: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
20:11:56.506: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
20:11:56.507: Failed to load 'en-US' text for module: 'obs-browser.dll'
20:11:56.507: [browser_source: 'Version: 1.29.0']
20:11:56.510: NVENC supported
20:11:56.595: VLC found, VLC video source enabled
20:11:56.600: No blackmagic support
20:11:56.679: ---------------------------------
20:11:56.679: Loaded Modules:
20:11:56.679: win-wasapi.dll
20:11:56.679: win-mf.dll
20:11:56.679: win-dshow.dll
20:11:56.679: win-decklink.dll
20:11:56.679: win-capture.dll
20:11:56.679: vlc-video.dll
20:11:56.679: text-freetype2.dll
20:11:56.679: rtmp-services.dll
20:11:56.679: obs-x264.dll
20:11:56.679: obs-vst.dll
20:11:56.679: obs-transitions.dll
20:11:56.679: obs-text.dll
20:11:56.679: obs-qsv11.dll
20:11:56.679: obs-outputs.dll
20:11:56.679: obs-filters.dll
20:11:56.679: obs-ffmpeg.dll
20:11:56.679: obs-browser.dll
20:11:56.679: image-source.dll
20:11:56.679: frontend-tools.dll
20:11:56.679: enc-amf.dll
20:11:56.679: coreaudio-encoder.dll
20:11:56.679: ==== Startup complete ===============================================
20:11:56.681: All scene data cleared
20:11:56.681: ------------------------------------------------
20:11:56.700: WASAPI: Device 'ASUS VH238 (NVIDIA High Definition Audio)' initialized
20:11:56.701: [WASAPISource::WASAPISource] Device 'default' not found. Waiting for device
20:11:56.812: Switched to scene 'Scene'
20:11:56.812: ------------------------------------------------
20:11:56.812: Loaded scenes:
20:11:56.812: - scene 'Scene':
20:11:56.812: - source: 'Image' (image_source)
Seems like a bunch of recent threads on this (my issue is here https://obsproject.com/forum/threads/another-no-audio-question.81127 ). I'm having the same issue. I wonder if it's something in Windows that changed that's causing the issue? I'm running in 64-bit mode. Was hoping someone might find something in our log files that would lend a clue as to what's happening? I also have a USB audio interface, so it might be the same answer.
