As above after starting up OBS I am suddenly without any Desktop sound capture at all. Was working fine just the other day. I have tried every tutorial and solution possible, changing the device from default to my headphones, making sure OBS isn't muted and making sure spatial sound wasn't on. Uninstalling OBS, and then a FRESH install wiped all my settings. Still the same, no Desktop Audio whatsoever.
Input works perfectly.
Uploading logs, don't know if I'm doing it correctly or if they'll help.
