SmitheryLC
I have OBS 21.1.2 installed on my computer and I cannot hear the audio from my elgato HD60s capture card. I can hear the audio when using elgato's software, but not when using OBS itself. I have contacted OBS multiple times and they seem to believe it has to do with OBS and/or the Spring update for Windows. Is there anyway to fix this so that I can hear my PS4 and Switch when trying to stream via my computer? I do not have speakers and am trying to use my headphones jacked into my computer. It worked before the OBS and Windows update (Updated both on same day). But now it does not. Thank you in advance!
