Question / Help Need some help
xsmashx88x
so.. have a problem I use obs to record
encoder:nvenc h.264
rate control:cbr
bitrate:45000
preset:default
profile:main or high
and obs was working fine.. was able to record with obs keeping 1080 at 60fps easy.. now i am having issues.
so fortnite runs fine and can record just fine with settings on max and fps uncapped on fortite obs has no issues with obs open and not recording and recording obs stays at 60fps with no frames missed due to rendering lag..
how ever games like warface/ironsight obs shows fps going down to 50 or 40 at sometimes 30 fps and i get the frames missed due to rendering lag, now this is with the game capture window if i do window capture its fine it stays at 60fps with no frames missed... this just started few days ago cause everything had been working fine..
i read that the game capture is better for games as supports diff games where the window capture can be buggy..I have tweaked the two games and nothing has changed, also i never had a issues with warface before so not sure whats fully going on, bandicam and dxtory an shadowplay dont have issues with recording..
nvm, turns out the new windows update broke the shared texture for game capture for dx9 games... have to wait for obs to update i guess to fix this :(
