Question / Help Need some help with quality balance/process priority/x264
Rough
Hey,
Settings that I used:
No CBR
Quality banalce 6
Max bitrate 1500
Buffer size 1500
Resolution downscale from 1920x1080 to 1280x720
Filter Lanczos
Fps 48
Process priority class set to above normal (? not sure what its about tho)
x264 cpu preset set to faster
Link to recorded stream:
http://www.twitch.tv/irs0osooom/b/383807640
In fast movement scenes it goes a bit blurry.
Anything that I can change here ?
Open Broadcaster Software v0.48.003b (experimental test build) - 64bit ( ^ω^)
CPU Name: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
CPU Speed: 3500MHz
Physical Memory:  16331MB Total, 12197MB Free
stepping id: 9, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
monitor 1: pos={0, 0}, size={1920, 1080}
Aero is Enabled
Adapter 1
  Video Adapter: NVIDIA GeForce GTX 560 Ti
  Video Adapter Dedicated Video Memory: 1025966080
  Video Adapter Shared System Memory: 3220779008
Using fixed low latency mode, factor 20
  Base resolution: 1920x1080
  Output resolution: 1280x720
Loading up D3D10...
Playback device {0.0.0.00000000}.{520a509a-14b9-4666-b5f6-7871eee2d7fb}
Using desktop audio input: Siberia V2 Usb Sound Card (USB PnP Sound Device)
Using 7.1 surround speaker setup (experimental)
Using auxilary audio input: Microphone (USB PnP Sound Device)
Audio Encoding: AAC
    bitrate: 64
Using graphics capture
Video Encoding: x264
    fps: 48
    width: 1280, height: 720
    preset: faster
    CBR: no
    CFR: no
    max bitrate: 1500
    buffer size: 1500
    quality: 8
SharedTexCapture hooked
  Server selection: rtmp://live-lhr-backup.justin.tv/app
SO_SNDBUF was at 8192
SO_SNDBUF is now 65536
Total frames rendered: 19463, number of frames that lagged: 5 (0.03%) (it's okay for some frames to lag)
Total duplicated frames: 20 (0.10%)
RTMPPublisher::SocketLoop: Aborting due to loop exit
Number of times waited to send: 0, Waited for a total of 0 bytes
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 64
    fps: 48
    preset: faster
    CBR: no
    CFR: no
    max bitrate: 1500
    buffer size: 1500
    quality: 6
Total frames rendered: 13473, number of frames that lagged: 5 (0.04%) (it's okay for some frames to lag)
Total duplicated frames: 16 (0.12%)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 64
    fps: 48
    preset: faster
    CBR: no
    CFR: no
    max bitrate: 1500
    buffer size: 1500
    quality: 6
Total frames rendered: 15413, number of frames that lagged: 3 (0.02%) (it's okay for some frames to lag)
Total duplicated frames: 20 (0.13%)
Profiler results:
frame - [100%] [avg time: 1.376 ms] [avg calls per frame: 1] [children: 86%] [unaccounted: 14%]
| scene->Preprocess - [0.218%] [avg time: 0.003 ms] [avg calls per frame: 1]
| video encoding and uploading - [85.8%] [avg time: 1.18 ms] [avg calls per frame: 1] [children: 82.2%] [unaccounted: 3.56%]
| | CopyResource - [0.727%] [avg time: 0.01 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.363%] [avg time: 0.005 ms] [avg calls per frame: 0]
| | call to encoder - [80.2%] [avg time: 1.104 ms] [avg calls per frame: 0]
| | sending stuff out - [0.872%] [avg time: 0.012 ms] [avg calls per frame: 0]
paibox
heros in an halfshel
Re: Need some help with quality balance/process priority/x26
Even with the preset set to faster, your frame rate is set too high for the bit rate you've specified. I stream at a similar bit rate (1600), and i find that you don't really want to go above 30 frames per second for 1280x720.
Rough
So I should keep all the settings above,but to change only the fps from 48 to 30 ?
Helixia
I should change your fps to 30 that's high enough for your stream and use cbr.
And if you can try to increase your bitrate to 2000.
What's your upload speed? (try speedtest.net to measure your speed)
Rough
dodgepong
Administrator
Community Helper
As Helixia said, 1500 bit rate is kinda low for 1280x720, especially for a shooter with higher motion. Have you tried bumping it up to 2000? Is your internet able to handle it?
Rough
I think it can handle it,but I'm getting lag spikes,even with minimize latency impact.
What about the settings besides the max bitrate on my first post?
Rough
I tried to change couple options in OBS
here is the log,anything wrong with it ?
Open Broadcaster Software v0.48.007b (experimental test build) - 64bit ( ^ω^)
CPU Speed: 3500MHz
Physical Memory:  16331MB Total, 13526MB Free
Aero is Enabled
Adapter 1
Loading up D3D10...
Using 5.1 surround speaker setup
Audio Encoding: AAC
    bitrate: 64
    fps: 60
    preset: veryfast
    CBR: no
    CFR: yes
    max bitrate: 2000
    buffer size: 2300
    quality: 9
  Server selection: rtmp://live-fra.justin.tv/app
Total frames rendered: 1223, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
Total duplicated frames: 0 (0.00%)
Loading up D3D10...
Audio Encoding: AAC
    bitrate: 64
    fps: 60
    preset: veryfast
    CBR: no
    CFR: yes
    max bitrate: 2000
    buffer size: 2300
    quality: 9
Total frames rendered: 156472, number of frames that lagged: 4 (0.00%) (it's okay for some frames to lag)
Profiler results:
frame - [100%] [avg time: 1.192 ms] [avg calls per frame: 1] [children: 91%] [unaccounted: 8.98%]
| scene->Preprocess - [0.168%] [avg time: 0.002 ms] [avg calls per frame: 1]
| video encoding and uploading - [90.9%] [avg time: 1.083 ms] [avg calls per frame: 1] [children: 89.3%] [unaccounted: 1.51%]
| | CopyResource - [0.671%] [avg time: 0.008 ms] [avg calls per frame: 0]
| | conversion to 4:2:0 - [0.923%] [avg time: 0.011 ms] [avg calls per frame: 0]
| | call to encoder - [86.2%] [avg time: 1.027 ms] [avg calls per frame: 0]
| | sending stuff out - [1.59%] [avg time: 0.019 ms] [avg calls per frame: 0]
Krazy
Town drunk
If you weren't happy with the quality of 48FPS and 1500 bitrate, you aren't going to be happy with the quality of 60fps and only 2000 bitrate. Also, is there a reason you enabled CFR?
Rough
To be honest?
I just asked someone who streams about his settings,and he got
3k bitrate/buffer
quality at 9
cpu at veryfast
and CFR enabled.
Why I shouldn't use CFR?
Muf
Forum Moderator
I think the most important point in this thread has not yet been mentioned:
You shouldn't be changing these settings if you don't know what you're doing. Making a thread about it doesn't help. You should ESPECIALLY not be touching things like process priority and x264 preset. Did you completely ignore the big fat warning you got when you tried to change those settings?
Rough
Actually I changed the priority and preset back to its default,normal and veryfast.
Changes that Im using now:
No CBR
Yes to CFR
Quality banalce 9
Max bitrate 2000
Buffer size 2300
Filter Bilinear
Fps 48
Process priority class set to normal
x264 cpu preset set to veryfast.
What about delay?
With simple logic,it should help with the stream,right ?
For example delay of 1 minute,you have the time before the streams shown to people.....So,in that time,from my pc it goes to the server,and then being streamed to others. With this logic,stream should actually go smoother without hiccups? Or it just doesn't work this way ?
dodgepong
Administrator
Community Helper
It doesn't work that way. You'll drop frames if you have a bad connection to the server regardless if you are making OBS buffer the video for 1 minute on your own computer.
Rough
which quality balance should I use with this bitrate? 6 or 9 ?
