Question / Help Need Noise Gate Help
unearth72
I've always used the noise gate and it's worked fine. I haven't changed any of my settings and all of a sudden it is keeping the mic open even thought he noise gate is enabled. If I disable and re enable the noise gate it will keep everything muted until I talk again then it stays open from there on out. I've checked and double checked that the ambient noise it below the threshold so it should't be staying open all the time. Anyone had this issue and fixed it?
FerretBomb
Usually this happens when someone has the 'close' volume set higher than the 'open' volume. Close must be set below the open value for it to work properly.
