Question / Help Need my Mic, Desktop Sound, and Capture Card sound!
Petch
Hi, I can get the desktop and mic sounds working in OBS, but not my capture card (Dazzle 100).
I've tried checking the box on the dazzle video input that says to include audio, but nothing happens (since the dazzle video and the dazzle audio are different devices to the computer, and only the video device shows up in the global settings).
I also have virtual audio cables, but when I try that either no sound comes out or I get an error about no sound, then OBS closes.
Is there any other option? There's a high chance I'm using virtual audio cables incorrectly, so if someone knows what they're doing could kindly tell me what to do with them?
Cheers!
paibox
heros in an halfshel
The Dazzle does not carries audio in a non-standard way, and audio for most USB capture cards is not currently supported. It's being looked at, but I'm afraid I can't currently give you an ETA for a fix.
In the meantime, you can window capture another capture application that does support the sound, or use AmarecTV's Live DirectShow passthrough feature.
Lain
Forum Admin
Lain
Forum Moderator
Developer
USB capture devices still are problematic for audio unfortunately, somewhat of an oversight on my part admittedly, but requires a significant amount of code to fix. quite frustrating.
Petch
Ah, oh well!
Can anyone help me out with a workaround? I have AmarecTV but I can't actually get it working properly with my Dazzle (I can get the audio, but no video)
