Hello, I am a streamer who streams Minecraft on twitch.tv
I am here in need of help of getting the best settings I can out of my PC specs and internet speed. I mostly want smoothness in my stream although better quality would be nice to. also here is a link to my most recent broadcast - http://www.twitch.tv/noxyii/b/427670637
PC SPECS:
Intel(R) Pentium(R) CPU B980 @ 2.40GHz
4.00 GB RAM
64-bit Operating System
Intel(R) HD Graphics
OBS Settings:
Encoding - Video
Quality = 5
Use custom buffer size = checked
Max bitrate = 2600
Buffer size = 2600
Encoding - Audio
Coding = AAC
Bitrate = 128
Broadcast settings -
Minimize Network Impact = checked
Video -
Custom = 1280x720
Resolution Downscale = 1.50 (852x480)
Filter = Bilinear(fastest)
FPS = 20
Advanced - General
Process Priority Class = Normal
Advanced - Video
x264 CPU Preset = Ultrafast
Speedtest:
http://www.speedtest.net/my-result/2810553269
LOG:
PC SPECS:
4.00 GB RAM
OBS Settings:
Encoding - Video
Quality = 5
Max bitrate = 2600
Buffer size = 2600
Encoding - Audio
Coding = AAC
Bitrate = 128
Video -
Custom = 1280x720
FPS = 20
Advanced - General
Advanced - Video
Speedtest:
LOG:
01:52:46: Open Broadcaster Software v0.522b - 64bit ( ^ω^)
01:52:46: -------------------------------
01:52:46: CPU Name: Intel(R) Pentium(R) CPU B980 @ 2.40GHz
01:52:46: CPU Speed: 2395MHz
01:52:46: Physical Memory: 3941MB Total, 1468MB Free
01:52:46: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 2, total cores 2
01:52:46: monitor 1: pos={0, 0}, size={1366, 768}
01:52:46: Windows Version: 6.2 Build 9200
01:52:46: Aero is Enabled
01:52:46: OBS Modules:
01:52:46: Base Address Module
01:52:46: 00000000EDC50000 OBS.exe
01:52:46: 00000000CD450000 OBSApi.dll
01:52:46: 00000000E2F40000 DShowPlugin.dll
01:52:46: 00000000E2950000 GraphicsCapture.dll
01:52:46: 00000000E87B0000 NoiseGate.dll
01:52:46: ------------------------------------------
01:52:46: Adapter 1
01:52:46: Video Adapter: Intel(R) HD Graphics
01:52:46: Video Adapter Dedicated Video Memory: 33554432
01:52:46: Video Adapter Shared System Memory: 1711276032
01:52:46: =====Stream Start: 2013-07-05, 01:52:46===============================================
01:52:46: Multithreaded optimizations: On
01:52:46: Base resolution: 1280x720
01:52:46: Output resolution: 1280x720
01:52:46: Loading up D3D10...
01:52:47: Playback device Default
01:52:47: ------------------------------------------
01:52:47: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:52:47: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:52:47: Audio Encoding: AAC
01:52:47: bitrate: 128
01:52:47: device: Lenovo EasyCamera,
01:52:47: device id \\?\usb#vid_5986&pid_0295&mi_00#7&34a8a6ce&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
01:52:47: chosen type: YUY2, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-10000000, fourCC: 'YUY2'
01:52:47: audio device: Disable,
01:52:47: audio device id Disabled,
01:52:47:
01:52:47: Using directshow input
01:52:47: Using text output
01:52:47: Using bitmap image
01:52:47: Using graphics capture
01:52:47: Video Encoding: x264
01:52:47: fps: 20
01:52:47: width: 1280, height: 720
01:52:47: preset: ultrafast
01:52:47: CBR: no
01:52:47: CFR: no
01:52:47: max bitrate: 2600
01:52:47: buffer size: 2600
01:52:47: quality: 5
01:52:47: using memory capture
02:09:32: Total frames rendered: 19942, number of frames that lagged: 144 (0.72%) (it's okay for some frames to lag)
02:09:33: =====Stream End: 2013-07-05, 02:09:33=================================================
02:14:10: Using fixed low latency mode, factor 20
02:14:10: =====Stream Start: 2013-07-05, 02:14:10===============================================
02:14:10: Multithreaded optimizations: On
02:14:10: Base resolution: 1280x720
02:14:10: Output resolution: 1280x720
02:14:10: ------------------------------------------
02:14:10: Loading up D3D10...
02:14:10: Playback device Default
02:14:10: Using desktop audio input: Speakers (Realtek High Definition Audio)
02:14:10: Using auxilary audio input: Microphone (Realtek High Definition Audio)
02:14:10: Audio Encoding: AAC
02:14:10: bitrate: 128
02:14:10: Using bitmap image
02:14:10: Using text output
02:14:10: Video Encoding: x264
02:14:10: fps: 20
02:14:10: width: 1280, height: 720
02:14:10: preset: ultrafast
02:14:10: CBR: no
02:14:10: CFR: no
02:14:10: max bitrate: 2600
02:14:10: buffer size: 2600
02:14:10: quality: 5
02:14:12: Using RTMP service: Twitch / Justin.tv
02:14:12: Server selection: rtmp://live.justin.tv/app
02:14:13: SO_SNDBUF was at 65536
02:14:13: SO_SNDBUF is now 65536
02:14:38: Total frames rendered: 541, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
02:14:38: RTMPPublisher::SocketLoop: Aborting due to loop exit
02:14:38: Number of times waited to send: 0, Waited for a total of 0 bytes
02:14:38: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
02:14:38: =====Stream End: 2013-07-05, 02:14:38=================================================
02:23:14:
02:23:14: Profiler results:
02:23:14:
02:23:14: ==============================================================
02:23:14: frame - [100%] [avg time: 9.9 ms] [avg calls per frame: 1] [children: 62.5%] [unaccounted: 37.5%]
02:23:14: | scene->Preprocess - [25.2%] [avg time: 2.498 ms] [avg calls per frame: 1]
02:23:14: | video encoding and uploading - [37.3%] [avg time: 3.693 ms] [avg calls per frame: 1] [children: 34.7%] [unaccounted: 2.65%]
02:23:14: | | CopyResource - [0.899%] [avg time: 0.089 ms] [avg calls per frame: 0]
02:23:14: | | conversion to 4:2:0 - [7.91%] [avg time: 0.783 ms] [avg calls per frame: 0]
02:23:14: | | call to encoder - [25.7%] [avg time: 2.548 ms] [avg calls per frame: 0]
02:23:14: | | sending stuff out - [0.111%] [avg time: 0.011 ms] [avg calls per frame: 0]
02:23:14:
