Question / Help Need help with settings with streaming League Of Legends.
RachaelPassive
16:41:48: Settings::Video: Disabling Aero
16:42:34: Open Broadcaster Software v0.552b - 32bit (´・ω・`)
16:42:34: -------------------------------
16:42:34: CPU Name: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
16:42:34: CPU Speed: 3392MHz
16:42:34: Physical Memory:  4095MB Total, 4095MB Free
16:42:34: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
16:42:34: monitor 1: pos={0, 0}, size={1920, 1200}
16:42:34: Windows Version: 6.1 Build 7601 S
16:42:34: Aero is Disabled
16:42:34: OBS Modules:
16:42:34: Base Address     Module
16:42:34: 013E0000         OBS.exe
16:42:34: 65D70000         OBSApi.dll
16:42:34: 6E240000         DShowPlugin.dll
16:42:34: 70AE0000         GraphicsCapture.dll
16:42:34: 74900000         NoiseGate.dll
16:42:34: 70A10000         PSVPlugin.dll
16:42:34: ------------------------------------------
16:42:34: Adapter 1
16:42:34:   Video Adapter: NVIDIA GeForce GT 530
16:42:34:   Video Adapter Dedicated Video Memory: 1041694720
16:42:34:   Video Adapter Shared System Memory: 3221065728
16:42:34: =====Stream Start: 2013-08-25, 16:42:34===============================================
16:42:34:   Multithreaded optimizations: On
16:42:34:   Base resolution: 1920x1200
16:42:34:   Output resolution: 1096x684
16:42:34: Loading up D3D10 on NVIDIA GeForce GT 530...
16:42:34: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:42:34: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:42:35: ------------------------------------------
16:42:35: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:42:35: Audio Encoding: AAC
16:42:35:     bitrate: 128
16:42:35:     device: Logitech QuickCam Communicate STX,
16:42:35:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:42:35:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:42:35:     audio device: Disable,
16:42:35:     audio device id Disabled,
16:42:35:
16:42:35: Using directshow input
16:42:35: Using graphics capture
16:42:35: Using Monitor Capture
16:42:35: Video Encoding: x264
16:42:35:     fps: 30
16:42:35:     width: 1096, height: 684
16:42:35:     preset: veryfast
16:42:35:     CBR: yes
16:42:35:     CFR: no
16:42:35:     max bitrate: 1000
16:42:35: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:42:35: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:43:25: SharedTexCapture hooked
16:43:46: GraphicsCaptureSource::NewCapture:  eliminating old capture
16:43:46: SharedTexCapture hooked
16:44:03: GraphicsCaptureSource::NewCapture:  eliminating old capture
16:44:03: SharedTexCapture hooked
16:44:27: Total frames rendered: 3253, number of late frames: 284 (8.73%) (it's okay for some frames to be late)
16:44:28:
16:44:28: Profiler results:
16:44:28:
16:44:28: ==============================================================
16:44:28: frame - [100%] [avg time: 9.736 ms (cpu time: avg 5.092 ms, total 16567.3 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0514%]
16:44:28: | frame preprocessing and rendering - [79.3%] [avg time: 7.725 ms (cpu time: avg 3.337 ms, total 10857.7 ms)] [avg calls per frame: 1] [children: 68.2%] [unaccounted: 11.1%]
16:44:28: | | scene->Preprocess - [68.2%] [avg time: 6.64 ms (cpu time: avg 2.666 ms, total 8673.65 ms)] [avg calls per frame: 1]
16:44:28: | video encoding and uploading - [20.6%] [avg time: 2.006 ms (cpu time: avg 1.755 ms, total 5709.64 ms)] [avg calls per frame: 1] [children: 14.5%] [unaccounted: 6.09%]
16:44:28: | | flush - [1.31%] [avg time: 0.128 ms (cpu time: avg 0.119 ms, total 390.002 ms)] [avg calls per frame: 1]
16:44:28: | | CopyResource - [0.103%] [avg time: 0.01 ms (cpu time: avg 0.009 ms, total 31.2 ms)] [avg calls per frame: 0]
16:44:28: | | conversion to 4:2:0 - [0.205%] [avg time: 0.02 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:44:28: | | call to encoder - [12.9%] [avg time: 1.253 ms (cpu time: avg 1.155 ms, total 3759.63 ms)] [avg calls per frame: 0]
16:44:28: | | sending stuff out - [0.0205%] [avg time: 0.002 ms (cpu time: avg 0.004 ms, total 15.6 ms)] [avg calls per frame: 0]
16:44:28: | Convert444Threads - [701%] [avg time: 68.236 ms (cpu time: avg 1.242 ms, total 4040.43 ms)] [avg calls per frame: 1]
16:44:28:
16:44:28: =====Stream End: 2013-08-25, 16:44:28=================================================
16:44:29: =====Stream Start: 2013-08-25, 16:44:29===============================================
16:44:29:   Multithreaded optimizations: On
16:44:29:   Base resolution: 1920x1200
16:44:29:   Output resolution: 1096x684
16:44:29: ------------------------------------------
16:44:29: Loading up D3D10 on NVIDIA GeForce GT 530...
16:44:29: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:44:29: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:44:29: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:44:29: Audio Encoding: AAC
16:44:29:     bitrate: 128
16:44:29:     device: Logitech QuickCam Communicate STX,
16:44:29:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:44:29:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:44:29:     audio device: Disable,
16:44:29:     audio device id Disabled,
16:44:29:
16:44:29: Using directshow input
16:44:29: Using graphics capture
16:44:29: Using Monitor Capture
16:44:30: ------------------------------------------
16:44:30: Video Encoding: x264
16:44:30:     fps: 30
16:44:30:     width: 1096, height: 684
16:44:30:     preset: veryfast
16:44:30:     CBR: yes
16:44:30:     CFR: no
16:44:30:     max bitrate: 1400
16:44:30: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:44:30: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:44:34: SharedTexCapture hooked
16:44:50: Total frames rendered: 506, number of late frames: 240 (47.43%) (it's okay for some frames to be late)
16:44:50:
16:44:50: Profiler results:
16:44:50:
16:44:50: ==============================================================
16:44:50: frame - [100%] [avg time: 24.561 ms (cpu time: avg 6.998 ms, total 3541.22 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0163%]
16:44:50: | frame preprocessing and rendering - [85%] [avg time: 20.867 ms (cpu time: avg 4.162 ms, total 2106.01 ms)] [avg calls per frame: 1] [children: 80.8%] [unaccounted: 4.17%]
16:44:50: | | scene->Preprocess - [80.8%] [avg time: 19.844 ms (cpu time: avg 3.206 ms, total 1622.41 ms)] [avg calls per frame: 1]
16:44:50: | video encoding and uploading - [15%] [avg time: 3.69 ms (cpu time: avg 2.836 ms, total 1435.21 ms)] [avg calls per frame: 1] [children: 5.91%] [unaccounted: 9.11%]
16:44:50: | | flush - [0.537%] [avg time: 0.132 ms (cpu time: avg 0.246 ms, total 124.8 ms)] [avg calls per frame: 1]
16:44:50: | | CopyResource - [0.0407%] [avg time: 0.01 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:44:50: | | conversion to 4:2:0 - [0.057%] [avg time: 0.014 ms (cpu time: avg 0.03 ms, total 15.6 ms)] [avg calls per frame: 0]
16:44:50: | | call to encoder - [5.27%] [avg time: 1.294 ms (cpu time: avg 0.986 ms, total 499.205 ms)] [avg calls per frame: 0]
16:44:50: | | sending stuff out - [0.00814%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:44:50: | Convert444Threads - [304%] [avg time: 74.684 ms (cpu time: avg 1.14 ms, total 577.202 ms)] [avg calls per frame: 1]
16:44:50:
16:44:50: =====Stream End: 2013-08-25, 16:44:50=================================================
16:44:51: Using fixed low latency mode, factor 20
16:44:51: =====Stream Start: 2013-08-25, 16:44:51===============================================
16:44:51:   Multithreaded optimizations: On
16:44:51:   Base resolution: 1920x1200
16:44:51:   Output resolution: 1096x684
16:44:51: ------------------------------------------
16:44:51: Loading up D3D10 on NVIDIA GeForce GT 530...
16:44:51: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:44:51: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:44:51: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:44:51: Audio Encoding: AAC
16:44:51:     bitrate: 128
16:44:51:     device: Logitech QuickCam Communicate STX,
16:44:51:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:44:51:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:44:51:     audio device: Disable,
16:44:51:     audio device id Disabled,
16:44:51:
16:44:51: Using directshow input
16:44:51: Using graphics capture
16:44:51: Using Monitor Capture
16:44:52: ------------------------------------------
16:44:52: Video Encoding: x264
16:44:52:     fps: 30
16:44:52:     width: 1096, height: 684
16:44:52:     preset: veryfast
16:44:52:     CBR: yes
16:44:52:     CFR: no
16:44:52:     max bitrate: 1400
16:44:52: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:44:52: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:44:54: Using RTMP service: Twitch / Justin.tv
16:44:54:   Server selection: rtmp://live-ord.justin.tv/app
16:44:54:   Interface: DW1501 Wireless-N WLAN Half-Mini Card (802.11, 81 mbps)
16:44:55: SharedTexCapture hooked
16:44:55: SO_SNDBUF was at 64512
16:44:55: SO_SNDBUF is now 65536
16:45:24: Total frames rendered: 889, number of late frames: 188 (21.15%) (it's okay for some frames to be late)
16:45:24: RTMPPublisher::SocketLoop: Graceful loop exit
16:45:24: Number of times waited to send: 197, Waited for a total of 685861 bytes
16:45:24: Number of b-frames dropped: 159 (20%), Number of p-frames dropped: 158 (20%), Total 317 (40%)
16:45:24:
16:45:24: Profiler results:
16:45:24:
16:45:24: ==============================================================
16:45:24: frame - [100%] [avg time: 14.344 ms (cpu time: avg 5.58 ms, total 4960.83 ms)] [avg calls per frame: 1] [children: 100%] [unaccounted: 0.0349%]
16:45:24: | frame preprocessing and rendering - [83.2%] [avg time: 11.928 ms (cpu time: avg 3.509 ms, total 3120.02 ms)] [avg calls per frame: 1] [children: 76.8%] [unaccounted: 6.34%]
16:45:24: | | scene->Preprocess - [76.8%] [avg time: 11.018 ms (cpu time: avg 2.684 ms, total 2386.82 ms)] [avg calls per frame: 1]
16:45:24: | video encoding and uploading - [16.8%] [avg time: 2.411 ms (cpu time: avg 2.07 ms, total 1840.81 ms)] [avg calls per frame: 1] [children: 9.91%] [unaccounted: 6.89%]
16:45:24: | | flush - [0.948%] [avg time: 0.136 ms (cpu time: avg 0.122 ms, total 109.2 ms)] [avg calls per frame: 1]
16:45:24: | | CopyResource - [0.0697%] [avg time: 0.01 ms (cpu time: avg 0.017 ms, total 15.6 ms)] [avg calls per frame: 0]
16:45:24: | | conversion to 4:2:0 - [0.112%] [avg time: 0.016 ms (cpu time: avg 0.017 ms, total 15.6 ms)] [avg calls per frame: 0]
16:45:24: | | call to encoder - [8.62%] [avg time: 1.237 ms (cpu time: avg 1.158 ms, total 1029.61 ms)] [avg calls per frame: 0]
16:45:24: | | sending stuff out - [0.16%] [avg time: 0.023 ms (cpu time: avg 0.017 ms, total 15.601 ms)] [avg calls per frame: 0]
16:45:24: | Convert444Threads - [484%] [avg time: 69.382 ms (cpu time: avg 0.982 ms, total 873.604 ms)] [avg calls per frame: 1]
16:45:24:
16:45:24: =====Stream End: 2013-08-25, 16:45:24=================================================
16:46:59: Using fixed low latency mode, factor 20
16:46:59: =====Stream Start: 2013-08-25, 16:46:59===============================================
16:46:59:   Multithreaded optimizations: On
16:46:59:   Base resolution: 1920x1200
16:46:59:   Output resolution: 1096x684
16:46:59: ------------------------------------------
16:46:59: Loading up D3D10 on NVIDIA GeForce GT 530...
16:46:59: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:46:59: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:46:59: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:46:59: Audio Encoding: AAC
16:46:59:     bitrate: 128
16:46:59:     device: Logitech QuickCam Communicate STX,
16:46:59:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:46:59:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:46:59:     audio device: Disable,
16:46:59:     audio device id Disabled,
16:46:59:
16:46:59: Using directshow input
16:46:59: Using graphics capture
16:47:00: ------------------------------------------
16:47:00: Video Encoding: x264
16:47:00:     fps: 30
16:47:00:     width: 1096, height: 684
16:47:00:     preset: veryfast
16:47:00:     CBR: yes
16:47:00:     CFR: no
16:47:00:     max bitrate: 1400
16:47:00: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:47:00: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:47:02: Using RTMP service: Twitch / Justin.tv
16:47:02:   Server selection: rtmp://live-ord.justin.tv/app
16:47:02:   Interface: DW1501 Wireless-N WLAN Half-Mini Card (802.11, 84 mbps)
16:47:03: SO_SNDBUF was at 64512
16:47:03: SO_SNDBUF is now 65536
16:47:51: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 10874 / 195584)
16:47:54: SharedTexCapture hooked
16:48:07: GraphicsCaptureSource::NewCapture:  eliminating old capture
16:48:07: SharedTexCapture hooked
16:48:28: GraphicsCaptureSource::NewCapture:  eliminating old capture
16:48:28: SharedTexCapture hooked
16:49:17: Total frames rendered: 4083, number of late frames: 7 (0.17%) (it's okay for some frames to be late)
16:49:17: RTMPPublisher::SocketLoop: Graceful loop exit
16:49:17: Number of times waited to send: 202, Waited for a total of 682520 bytes
16:49:17: Number of b-frames dropped: 50 (1.3%), Number of p-frames dropped: 31 (0.78%), Total 81 (2%)
16:49:17:
16:49:17: Profiler results:
16:49:17:
16:49:17: ==============================================================
16:49:17: frame - [100%] [avg time: 3.611 ms (cpu time: avg 1.967 ms, total 8034.04 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.166%]
16:49:17: | frame preprocessing and rendering - [25.7%] [avg time: 0.928 ms (cpu time: avg 0.703 ms, total 2870.42 ms)] [avg calls per frame: 1] [children: 1.88%] [unaccounted: 23.8%]
16:49:17: | | scene->Preprocess - [1.88%] [avg time: 0.068 ms (cpu time: avg 0.061 ms, total 249.605 ms)] [avg calls per frame: 1]
16:49:17: | video encoding and uploading - [74.1%] [avg time: 2.677 ms (cpu time: avg 1.264 ms, total 5163.63 ms)] [avg calls per frame: 1] [children: 36.6%] [unaccounted: 37.5%]
16:49:17: | | flush - [4.49%] [avg time: 0.162 ms (cpu time: avg 0.095 ms, total 390.004 ms)] [avg calls per frame: 1]
16:49:17: | | CopyResource - [0.36%] [avg time: 0.013 ms (cpu time: avg 0.007 ms, total 31.2 ms)] [avg calls per frame: 0]
16:49:17: | | conversion to 4:2:0 - [0.415%] [avg time: 0.015 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:49:17: | | call to encoder - [30.9%] [avg time: 1.117 ms (cpu time: avg 1.046 ms, total 4274.42 ms)] [avg calls per frame: 0]
16:49:17: | | sending stuff out - [0.443%] [avg time: 0.016 ms (cpu time: avg 0.011 ms, total 46.8 ms)] [avg calls per frame: 0]
16:49:17: | Convert444Threads - [1.84e+003%] [avg time: 66.46 ms (cpu time: avg 1.062 ms, total 4336.83 ms)] [avg calls per frame: 1]
16:49:17:
16:49:17: =====Stream End: 2013-08-25, 16:49:17=================================================
16:49:19: Using fixed low latency mode, factor 20
16:49:19: =====Stream Start: 2013-08-25, 16:49:19===============================================
16:49:19:   Multithreaded optimizations: On
16:49:19:   Base resolution: 1920x1200
16:49:19:   Output resolution: 1096x684
16:49:19: ------------------------------------------
16:49:19: Loading up D3D10 on NVIDIA GeForce GT 530...
16:49:19: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:49:19: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:49:19: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:49:19: Audio Encoding: AAC
16:49:19:     bitrate: 128
16:49:19:     device: Logitech QuickCam Communicate STX,
16:49:19:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:49:19:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:49:19:     audio device: Disable,
16:49:19:     audio device id Disabled,
16:49:19:
16:49:19: Using directshow input
16:49:19: Using graphics capture
16:49:20: ------------------------------------------
16:49:20: Video Encoding: x264
16:49:20:     fps: 30
16:49:20:     width: 1096, height: 684
16:49:20:     preset: veryfast
16:49:20:     CBR: yes
16:49:20:     CFR: no
16:49:20:     max bitrate: 300
16:49:20: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:49:20: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:49:21: Using RTMP service: Twitch / Justin.tv
16:49:21:   Server selection: rtmp://live-ord.justin.tv/app
16:49:21:   Interface: DW1501 Wireless-N WLAN Half-Mini Card (802.11, 77 mbps)
16:49:23: SharedTexCapture hooked
16:49:23: SO_SNDBUF was at 64512
16:49:23: SO_SNDBUF is now 65536
16:49:47: GraphicsCaptureSource::NewCapture:  eliminating old capture
16:49:47: SharedTexCapture hooked
16:50:14: Total frames rendered: 1605, number of late frames: 4 (0.25%) (it's okay for some frames to be late)
16:50:14: RTMPPublisher::SocketLoop: Graceful loop exit
16:50:14: Number of times waited to send: 0, Waited for a total of 0 bytes
16:50:14: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:50:14:
16:50:14: Profiler results:
16:50:14:
16:50:14: ==============================================================
16:50:14: frame - [100%] [avg time: 5.041 ms (cpu time: avg 2.206 ms, total 3541.22 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.119%]
16:50:14: | frame preprocessing and rendering - [35.9%] [avg time: 1.811 ms (cpu time: avg 0.894 ms, total 1435.21 ms)] [avg calls per frame: 1] [children: 1.51%] [unaccounted: 34.4%]
16:50:14: | | scene->Preprocess - [1.51%] [avg time: 0.076 ms (cpu time: avg 0.058 ms, total 93.601 ms)] [avg calls per frame: 1]
16:50:14: | video encoding and uploading - [64%] [avg time: 3.224 ms (cpu time: avg 1.312 ms, total 2106.01 ms)] [avg calls per frame: 1] [children: 27.2%] [unaccounted: 36.7%]
16:50:14: | | flush - [3.35%] [avg time: 0.169 ms (cpu time: avg 0.077 ms, total 124.801 ms)] [avg calls per frame: 1]
16:50:14: | | CopyResource - [0.298%] [avg time: 0.015 ms (cpu time: avg 0.009 ms, total 15.6 ms)] [avg calls per frame: 0]
16:50:14: | | conversion to 4:2:0 - [0.258%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:50:14: | | call to encoder - [23.1%] [avg time: 1.164 ms (cpu time: avg 0.981 ms, total 1575.61 ms)] [avg calls per frame: 0]
16:50:14: | | sending stuff out - [0.218%] [avg time: 0.011 ms (cpu time: avg 0.009 ms, total 15.6 ms)] [avg calls per frame: 0]
16:50:14: | Convert444Threads - [1.31e+003%] [avg time: 66.048 ms (cpu time: avg 0.952 ms, total 1528.81 ms)] [avg calls per frame: 1]
16:50:14:
16:50:14: =====Stream End: 2013-08-25, 16:50:14=================================================
16:50:15: Using fixed low latency mode, factor 20
16:50:15: =====Stream Start: 2013-08-25, 16:50:15===============================================
16:50:15:   Multithreaded optimizations: On
16:50:15:   Base resolution: 1920x1200
16:50:15:   Output resolution: 1096x684
16:50:15: ------------------------------------------
16:50:15: Loading up D3D10 on NVIDIA GeForce GT 530...
16:50:15: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:50:15: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:50:15: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:50:15: Audio Encoding: AAC
16:50:15:     bitrate: 128
16:50:15:     device: Logitech QuickCam Communicate STX,
16:50:15:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:50:15:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:50:15:     audio device: Disable,
16:50:15:     audio device id Disabled,
16:50:15:
16:50:15: Using directshow input
16:50:15: Using graphics capture
16:50:16: ------------------------------------------
16:50:16: Video Encoding: x264
16:50:16:     fps: 30
16:50:16:     width: 1096, height: 684
16:50:16:     preset: veryfast
16:50:16:     CBR: yes
16:50:16:     CFR: no
16:50:16:     max bitrate: 300
16:50:16: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:50:16: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:50:18: Using RTMP service: Twitch / Justin.tv
16:50:18:   Server selection: rtmp://live-ord.justin.tv/app
16:50:18:   Interface: DW1501 Wireless-N WLAN Half-Mini Card (802.11, 77 mbps)
16:50:19: SO_SNDBUF was at 64512
16:50:19: SO_SNDBUF is now 65536
16:50:32: Settings::Encoding: Changing bitrate from 300kb/s to 500kb/s
16:50:39: Total frames rendered: 685, number of late frames: 1 (0.15%) (it's okay for some frames to be late)
16:50:40: RTMPPublisher::SocketLoop: Graceful loop exit
16:50:40: Number of times waited to send: 0, Waited for a total of 0 bytes
16:50:40: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:50:40:
16:50:40: Profiler results:
16:50:40:
16:50:40: ==============================================================
16:50:40: frame - [100%] [avg time: 2.479 ms (cpu time: avg 2.322 ms, total 1591.21 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.202%]
16:50:40: | frame preprocessing and rendering - [42.3%] [avg time: 1.048 ms (cpu time: avg 0.91 ms, total 624.003 ms)] [avg calls per frame: 1] [children: 2.5%] [unaccounted: 39.8%]
16:50:40: | | scene->Preprocess - [2.5%] [avg time: 0.062 ms (cpu time: avg 0.068 ms, total 46.8 ms)] [avg calls per frame: 1]
16:50:40: | video encoding and uploading - [57.5%] [avg time: 1.426 ms (cpu time: avg 1.389 ms, total 951.606 ms)] [avg calls per frame: 1] [children: 55.2%] [unaccounted: 2.3%]
16:50:40: | | flush - [5.49%] [avg time: 0.136 ms (cpu time: avg 0.113 ms, total 78.001 ms)] [avg calls per frame: 1]
16:50:40: | | CopyResource - [0.605%] [avg time: 0.015 ms (cpu time: avg 0.022 ms, total 15.6 ms)] [avg calls per frame: 0]
16:50:40: | | conversion to 4:2:0 - [0.565%] [avg time: 0.014 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:50:40: | | call to encoder - [48%] [avg time: 1.191 ms (cpu time: avg 1.184 ms, total 811.205 ms)] [avg calls per frame: 0]
16:50:40: | | sending stuff out - [0.524%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:50:40: | Convert444Threads - [2.62e+003%] [avg time: 65.006 ms (cpu time: avg 1.002 ms, total 686.404 ms)] [avg calls per frame: 1]
16:50:40:
16:50:40: =====Stream End: 2013-08-25, 16:50:40=================================================
16:50:41: Using fixed low latency mode, factor 20
16:50:41: =====Stream Start: 2013-08-25, 16:50:41===============================================
16:50:41:   Multithreaded optimizations: On
16:50:41:   Base resolution: 1920x1200
16:50:41:   Output resolution: 1096x684
16:50:41: ------------------------------------------
16:50:41: Loading up D3D10 on NVIDIA GeForce GT 530...
16:50:41: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:50:41: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:50:41: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:50:41: Audio Encoding: AAC
16:50:41:     bitrate: 128
16:50:41:     device: Logitech QuickCam Communicate STX,
16:50:41:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:50:41:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:50:41:     audio device: Disable,
16:50:41:     audio device id Disabled,
16:50:41:
16:50:41: Using directshow input
16:50:41: Using graphics capture
16:50:42: ------------------------------------------
16:50:42: Video Encoding: x264
16:50:42:     fps: 30
16:50:42:     width: 1096, height: 684
16:50:42:     preset: veryfast
16:50:42:     CBR: yes
16:50:42:     CFR: no
16:50:42:     max bitrate: 500
16:50:42: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:50:42: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:50:44: Using RTMP service: Twitch / Justin.tv
16:50:44:   Server selection: rtmp://live-ord.justin.tv/app
16:50:44:   Interface: DW1501 Wireless-N WLAN Half-Mini Card (802.11, 81 mbps)
16:50:44: SharedTexCapture hooked
16:50:45: SO_SNDBUF was at 64512
16:50:45: SO_SNDBUF is now 65536
16:51:09: Settings::Encoding: Changing bitrate from 500kb/s to 800kb/s
16:51:13: Total frames rendered: 929, number of late frames: 3 (0.32%) (it's okay for some frames to be late)
16:51:14: RTMPPublisher::SocketLoop: Graceful loop exit
16:51:14: Number of times waited to send: 0, Waited for a total of 0 bytes
16:51:14: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:51:14:
16:51:14: Profiler results:
16:51:14:
16:51:14: ==============================================================
16:51:14: frame - [100%] [avg time: 4.217 ms (cpu time: avg 2.468 ms, total 2293.22 ms)] [avg calls per frame: 1] [children: 99.8%] [unaccounted: 0.166%]
16:51:14: | frame preprocessing and rendering - [26.9%] [avg time: 1.133 ms (cpu time: avg 0.923 ms, total 858.005 ms)] [avg calls per frame: 1] [children: 1.66%] [unaccounted: 25.2%]
16:51:14: | | scene->Preprocess - [1.66%] [avg time: 0.07 ms (cpu time: avg 0.083 ms, total 78 ms)] [avg calls per frame: 1]
16:51:14: | video encoding and uploading - [73%] [avg time: 3.077 ms (cpu time: avg 1.544 ms, total 1435.21 ms)] [avg calls per frame: 1] [children: 32.4%] [unaccounted: 40.6%]
16:51:14: | | flush - [3.89%] [avg time: 0.164 ms (cpu time: avg 0.083 ms, total 78.002 ms)] [avg calls per frame: 1]
16:51:14: | | CopyResource - [0.285%] [avg time: 0.012 ms (cpu time: avg 0.016 ms, total 15.6 ms)] [avg calls per frame: 0]
16:51:14: | | conversion to 4:2:0 - [0.403%] [avg time: 0.017 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:51:14: | | call to encoder - [27.5%] [avg time: 1.159 ms (cpu time: avg 1.041 ms, total 967.206 ms)] [avg calls per frame: 0]
16:51:14: | | sending stuff out - [0.356%] [avg time: 0.015 ms (cpu time: avg 0.016 ms, total 15.6 ms)] [avg calls per frame: 0]
16:51:14: | Convert444Threads - [1.55e+003%] [avg time: 65.526 ms (cpu time: avg 1.024 ms, total 951.605 ms)] [avg calls per frame: 1]
16:51:14:
16:51:14: =====Stream End: 2013-08-25, 16:51:14=================================================
16:51:17: Using fixed low latency mode, factor 20
16:51:17: =====Stream Start: 2013-08-25, 16:51:17===============================================
16:51:17:   Multithreaded optimizations: On
16:51:17:   Base resolution: 1920x1200
16:51:17:   Output resolution: 1096x684
16:51:17: ------------------------------------------
16:51:17: Loading up D3D10 on NVIDIA GeForce GT 530...
16:51:17: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:51:17: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:51:17: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:51:17: Audio Encoding: AAC
16:51:17:     bitrate: 128
16:51:17:     device: Logitech QuickCam Communicate STX,
16:51:17:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:51:17:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:51:17:     audio device: Disable,
16:51:17:     audio device id Disabled,
16:51:17:
16:51:17: Using directshow input
16:51:17: Using graphics capture
16:51:18: ------------------------------------------
16:51:18: Video Encoding: x264
16:51:18:     fps: 30
16:51:18:     width: 1096, height: 684
16:51:18:     preset: veryfast
16:51:18:     CBR: yes
16:51:18:     CFR: no
16:51:18:     max bitrate: 800
16:51:18: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:51:18: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:51:20: Using RTMP service: Twitch / Justin.tv
16:51:20:   Server selection: rtmp://live-ord.justin.tv/app
16:51:20:   Interface: DW1501 Wireless-N WLAN Half-Mini Card (802.11, 90 mbps)
16:51:21: SharedTexCapture hooked
16:51:21: SO_SNDBUF was at 64512
16:51:21: SO_SNDBUF is now 65536
16:51:35: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 131072)
16:51:42: GraphicsCaptureSource::NewCapture:  eliminating old capture
16:51:42: SharedTexCapture hooked
16:52:14: Settings::Encoding: Changing bitrate from 800kb/s to 1000kb/s
16:52:19: Total frames rendered: 1789, number of late frames: 8 (0.45%) (it's okay for some frames to be late)
16:52:19: RTMPPublisher::SocketLoop: Graceful loop exit
16:52:19: Number of times waited to send: 0, Waited for a total of 0 bytes
16:52:19: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:52:19:
16:52:19: Profiler results:
16:52:19:
16:52:19: ==============================================================
16:52:19: frame - [100%] [avg time: 5.364 ms (cpu time: avg 2.703 ms, total 4836.03 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.112%]
16:52:19: | frame preprocessing and rendering - [18.1%] [avg time: 0.969 ms (cpu time: avg 0.741 ms, total 1326.01 ms)] [avg calls per frame: 1] [children: 1.32%] [unaccounted: 16.7%]
16:52:19: | | scene->Preprocess - [1.32%] [avg time: 0.071 ms (cpu time: avg 0.052 ms, total 93.601 ms)] [avg calls per frame: 1]
16:52:19: | video encoding and uploading - [81.8%] [avg time: 4.389 ms (cpu time: avg 1.962 ms, total 3510.02 ms)] [avg calls per frame: 1] [children: 24.5%] [unaccounted: 57.4%]
16:52:19: | | flush - [3.06%] [avg time: 0.164 ms (cpu time: avg 0.104 ms, total 187.202 ms)] [avg calls per frame: 1]
16:52:19: | | CopyResource - [0.242%] [avg time: 0.013 ms (cpu time: avg 0.017 ms, total 31.2 ms)] [avg calls per frame: 0]
16:52:19: | | conversion to 4:2:0 - [0.224%] [avg time: 0.012 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:52:19: | | call to encoder - [20.7%] [avg time: 1.108 ms (cpu time: avg 0.959 ms, total 1716.01 ms)] [avg calls per frame: 0]
16:52:19: | | sending stuff out - [0.28%] [avg time: 0.015 ms (cpu time: avg 0.017 ms, total 31.2 ms)] [avg calls per frame: 0]
16:52:19: | Convert444Threads - [1.23e+003%] [avg time: 66.211 ms (cpu time: avg 0.994 ms, total 1778.41 ms)] [avg calls per frame: 1]
16:52:19:
16:52:19: =====Stream End: 2013-08-25, 16:52:19=================================================
16:52:20: Using fixed low latency mode, factor 20
16:52:20: =====Stream Start: 2013-08-25, 16:52:20===============================================
16:52:20:   Multithreaded optimizations: On
16:52:20:   Base resolution: 1920x1200
16:52:20:   Output resolution: 1096x684
16:52:20: ------------------------------------------
16:52:20: Loading up D3D10 on NVIDIA GeForce GT 530...
16:52:20: Playback device {0.0.0.00000000}.{8418790c-fa70-4839-a470-3c6631c0e39c}
16:52:20: Using desktop audio input: Speakers (Realtek High Definition Audio)
16:52:20: Using auxilary audio input: FrontMic (Realtek High Definition Audio)
16:52:20: Audio Encoding: AAC
16:52:20:     bitrate: 128
16:52:20:     device: Logitech QuickCam Communicate STX,
16:52:20:     device id \\?\usb#vid_046d&pid_08d7&mi_00#7&62d8919&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{9b365890-165f-11d0-a195-0020afd156e4},
16:52:20:     chosen type: I420, usingFourCC: false, res: 320x240 - 320x240, frameIntervals: 100000-10000000, fourCC: 'I420'
16:52:20:     audio device: Disable,
16:52:20:     audio device id Disabled,
16:52:20:
16:52:20: Using directshow input
16:52:20: Using graphics capture
16:52:21: ------------------------------------------
16:52:21: Video Encoding: x264
16:52:21:     fps: 30
16:52:21:     width: 1096, height: 684
16:52:21:     preset: veryfast
16:52:21:     CBR: yes
16:52:21:     CFR: no
16:52:21:     max bitrate: 1000
16:52:21: MMDeviceAudioSource: Frequency for device 'Speakers (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:52:21: MMDeviceAudioSource: Frequency for device 'FrontMic (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:52:23: Using RTMP service: Twitch / Justin.tv
16:52:23:   Server selection: rtmp://live-ord.justin.tv/app
16:52:23:   Interface: DW1501 Wireless-N WLAN Half-Mini Card (802.11, 96 mbps)
16:52:24: SO_SNDBUF was at 64512
16:52:24: SO_SNDBUF is now 65536
16:52:27: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 144384)
16:52:27: SharedTexCapture hooked
16:52:43: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 0 / 144384)
16:52:45: Total frames rendered: 714, number of late frames: 4 (0.56%) (it's okay for some frames to be late)
16:52:46: RTMPPublisher::SocketLoop: Graceful loop exit
16:52:46: Number of times waited to send: 0, Waited for a total of 0 bytes
16:52:46: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
16:52:46:
16:52:46: Profiler results:
16:52:46:
16:52:46: ==============================================================
16:52:46: frame - [100%] [avg time: 6.773 ms (cpu time: avg 2.752 ms, total 1965.61 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0886%]
16:52:46: | frame preprocessing and rendering - [15.3%] [avg time: 1.034 ms (cpu time: avg 0.655 ms, total 468.002 ms)] [avg calls per frame: 1] [children: 1.28%] [unaccounted: 14%]
16:52:46: | | scene->Preprocess - [1.28%] [avg time: 0.087 ms (cpu time: avg 0.021 ms, total 15.6 ms)] [avg calls per frame: 1]
16:52:46: | video encoding and uploading - [84.6%] [avg time: 5.733 ms (cpu time: avg 2.097 ms, total 1497.61 ms)] [avg calls per frame: 1] [children: 18.7%] [unaccounted: 66%]
16:52:46: | | flush - [2.7%] [avg time: 0.183 ms (cpu time: avg 0.021 ms, total 15.6 ms)] [avg calls per frame: 1]
16:52:46: | | CopyResource - [0.266%] [avg time: 0.018 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:52:46: | | conversion to 4:2:0 - [0.192%] [avg time: 0.013 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:52:46: | | call to encoder - [15.3%] [avg time: 1.035 ms (cpu time: avg 0.917 ms, total 655.206 ms)] [avg calls per frame: 0]
16:52:46: | | sending stuff out - [0.236%] [avg time: 0.016 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
16:52:46: | Convert444Threads - [962%] [avg time: 65.17 ms (cpu time: avg 0.808 ms, total 577.203 ms)] [avg calls per frame: 1]
16:52:46:
16:52:46: =====Stream End: 2013-08-25, 16:52:46=================================================
Last game capture log:
2013-08-25, 16:47:49: we're booting up:
16:47:49: D3D9 Present
16:47:49: DXGI Present
16:47:49: NV Capture available
16:47:49: FBO available
16:47:49: GL Present
16:47:49: (half life scientist) everything..  seems to be in order
16:47:54: D3D9EndScene called
16:47:54: D3DPRESENT_PARAMETERS {
16:47:54: 	BackBufferWidth: 1920
16:47:54: 	BackBufferHeight: 1200
16:47:54: 	BackBufferFormat: D3DFMT_X8R8G8B8
16:47:54: 	BackBufferCount: 1
16:47:54: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:47:54: 	MultiSampleQuality: 0
16:47:54: 	SwapEffect: D3DSWAPEFFECT_DISCARD
16:47:54: 	hDeviceWindow: 3936660
16:47:54: 	Windowed: false
16:47:54: 	EnableAutoDepthStencil: true
16:47:54: 	AutoDepthStencilFormat: D3DFMT_D24X8
16:47:54: 	Flags: D3DPRESENTFLAG_DISCARD_DEPTHSTENCIL
16:47:54: 	FullScreen_RefreshRateInHz: 59
16:47:54: 	PresentationInterval: 2147483648
16:47:54: };
16:47:54: successfully set up d3d9 hooks
16:47:54: D3D9Present called
16:47:54: DoD3D9GPUHook: success
16:47:57: D3DSURFACE_DESC {
16:47:57: 	Format: D3DFMT_X8R8G8B8
16:47:57: 	Type: D3DRTYPE_SURFACE
16:47:57: 	Usage: D3DUSAGE_RENDERTARGET
16:47:57: 	Pool: D3DPOOL_DEFAULT
16:47:57: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:47:57: 	MultiSampleQuality: 0
16:47:57: 	Width: 1920
16:47:57: 	Height: 1200
16:47:57: };
16:47:57: successfully capturing d3d9 frames via GPU
16:48:07: D3D9Reset called
16:48:07: ---------------------- Cleared D3D9 Capture ----------------------
16:48:07: successfully set up d3d9 hooks
16:48:07: D3D9EndScene called
16:48:07: D3D9Present called
16:48:07: DoD3D9GPUHook: success
16:48:07: D3DSURFACE_DESC {
16:48:07: 	Format: D3DFMT_X8R8G8B8
16:48:07: 	Type: D3DRTYPE_SURFACE
16:48:07: 	Usage: D3DUSAGE_RENDERTARGET
16:48:07: 	Pool: D3DPOOL_DEFAULT
16:48:07: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:48:07: 	MultiSampleQuality: 0
16:48:07: 	Width: 1920
16:48:07: 	Height: 1200
16:48:07: };
16:48:07: successfully capturing d3d9 frames via GPU
16:48:28: D3D9Reset called
16:48:28: ---------------------- Cleared D3D9 Capture ----------------------
16:48:28: successfully set up d3d9 hooks
16:48:28: D3D9EndScene called
16:48:28: D3D9Present called
16:48:28: DoD3D9GPUHook: success
16:48:28: D3DSURFACE_DESC {
16:48:28: 	Format: D3DFMT_X8R8G8B8
16:48:28: 	Type: D3DRTYPE_SURFACE
16:48:28: 	Usage: D3DUSAGE_RENDERTARGET
16:48:28: 	Pool: D3DPOOL_DEFAULT
16:48:28: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:48:28: 	MultiSampleQuality: 0
16:48:28: 	Width: 1920
16:48:28: 	Height: 1200
16:48:28: };
16:48:28: successfully capturing d3d9 frames via GPU
16:49:22: D3D9Reset called
16:49:22: ---------------------- Cleared D3D9 Capture ----------------------
16:49:22: successfully set up d3d9 hooks
16:49:23: D3D9EndScene called
16:49:23: D3D9Present called
16:49:23: ---------------------- Cleared D3D9 Capture ----------------------
16:49:23: received restart event, capturing
16:49:23: DoD3D9GPUHook: success
16:49:23: D3DSURFACE_DESC {
16:49:23: 	Format: D3DFMT_X8R8G8B8
16:49:23: 	Type: D3DRTYPE_SURFACE
16:49:23: 	Usage: D3DUSAGE_RENDERTARGET
16:49:23: 	Pool: D3DPOOL_DEFAULT
16:49:23: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:49:23: 	MultiSampleQuality: 0
16:49:23: 	Width: 1920
16:49:23: 	Height: 1200
16:49:23: };
16:49:23: successfully capturing d3d9 frames via GPU
16:49:46: D3D9Reset called
16:49:46: ---------------------- Cleared D3D9 Capture ----------------------
16:49:47: successfully set up d3d9 hooks
16:49:47: D3D9EndScene called
16:49:47: D3D9Present called
16:49:47: DoD3D9GPUHook: success
16:49:47: D3DSURFACE_DESC {
16:49:47: 	Format: D3DFMT_X8R8G8B8
16:49:47: 	Type: D3DRTYPE_SURFACE
16:49:47: 	Usage: D3DUSAGE_RENDERTARGET
16:49:47: 	Pool: D3DPOOL_DEFAULT
16:49:47: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:49:47: 	MultiSampleQuality: 0
16:49:47: 	Width: 1920
16:49:47: 	Height: 1200
16:49:47: };
16:49:47: successfully capturing d3d9 frames via GPU
16:50:43: D3D9Reset called
16:50:43: ---------------------- Cleared D3D9 Capture ----------------------
16:50:43: successfully set up d3d9 hooks
16:50:44: D3D9EndScene called
16:50:44: D3D9Present called
16:50:44: ---------------------- Cleared D3D9 Capture ----------------------
16:50:44: received restart event, capturing
16:50:44: DoD3D9GPUHook: success
16:50:44: D3DSURFACE_DESC {
16:50:44: 	Format: D3DFMT_X8R8G8B8
16:50:44: 	Type: D3DRTYPE_SURFACE
16:50:44: 	Usage: D3DUSAGE_RENDERTARGET
16:50:44: 	Pool: D3DPOOL_DEFAULT
16:50:44: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:50:44: 	MultiSampleQuality: 0
16:50:44: 	Width: 1920
16:50:44: 	Height: 1200
16:50:44: };
16:50:44: successfully capturing d3d9 frames via GPU
16:51:20: D3D9Reset called
16:51:20: ---------------------- Cleared D3D9 Capture ----------------------
16:51:20: successfully set up d3d9 hooks
16:51:21: D3D9EndScene called
16:51:21: D3D9Present called
16:51:21: ---------------------- Cleared D3D9 Capture ----------------------
16:51:21: received restart event, capturing
16:51:21: DoD3D9GPUHook: success
16:51:21: D3DSURFACE_DESC {
16:51:21: 	Format: D3DFMT_X8R8G8B8
16:51:21: 	Type: D3DRTYPE_SURFACE
16:51:21: 	Usage: D3DUSAGE_RENDERTARGET
16:51:21: 	Pool: D3DPOOL_DEFAULT
16:51:21: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:51:21: 	MultiSampleQuality: 0
16:51:21: 	Width: 1920
16:51:21: 	Height: 1200
16:51:21: };
16:51:21: successfully capturing d3d9 frames via GPU
16:51:42: D3D9Reset called
16:51:42: ---------------------- Cleared D3D9 Capture ----------------------
16:51:42: successfully set up d3d9 hooks
16:51:42: D3D9EndScene called
16:51:42: D3D9Present called
16:51:42: DoD3D9GPUHook: success
16:51:42: D3DSURFACE_DESC {
16:51:42: 	Format: D3DFMT_X8R8G8B8
16:51:42: 	Type: D3DRTYPE_SURFACE
16:51:42: 	Usage: D3DUSAGE_RENDERTARGET
16:51:42: 	Pool: D3DPOOL_DEFAULT
16:51:42: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:51:42: 	MultiSampleQuality: 0
16:51:42: 	Width: 1920
16:51:42: 	Height: 1200
16:51:42: };
16:51:42: successfully capturing d3d9 frames via GPU
16:52:27: D3D9Reset called
16:52:27: ---------------------- Cleared D3D9 Capture ----------------------
16:52:27: successfully set up d3d9 hooks
16:52:27: D3D9EndScene called
16:52:27: D3D9Present called
16:52:27: received restart event, capturing
16:52:27: DoD3D9GPUHook: success
16:52:27: D3DSURFACE_DESC {
16:52:27: 	Format: D3DFMT_X8R8G8B8
16:52:27: 	Type: D3DRTYPE_SURFACE
16:52:27: 	Usage: D3DUSAGE_RENDERTARGET
16:52:27: 	Pool: D3DPOOL_DEFAULT
16:52:27: 	MultiSampleType: D3DMULTISAMPLE_NONE
16:52:27: 	MultiSampleQuality: 0
16:52:27: 	Width: 1920
16:52:27: 	Height: 1200
16:52:27: };
16:52:27: successfully capturing d3d9 frames via GPU
16:52:48: D3D9Reset called
16:52:48: ---------------------- Cleared D3D9 Capture ----------------------
16:52:48: successfully set up d3d9 hooks
16:52:48: D3D9EndScene called
16:52:48: D3D9Present called
16:52:48: received restart event, capturing
16:52:48: DoD3D9GPUHook: success
:::.. Upload Speed Test Result Details ..:::
Upload Connection Speed:: 3706 Kbps or 3.7 Mbps
Upload Speed Test Size:: 33 MB or 33792 kB or 34603008 bytes
Upload Binary File Transfer Speed:: 463 kB/s
Tested At:: http://TestMy.net Version 13
Validation:: http://testmy.net/db/yiGmobB
More Stats:: http://testmy.net/compID/615951146019
Test Time:: 2013-08-25 17:14:17 Local Time
 Destination:: Dallas, TX US
1MB Upload in 2.21 Seconds - 1GB Upload in ~38 Minutes - 66X faster than 56K
This test of exactly 33792 kB took 74.693 seconds to complete
Running at 108% of hosts average (Comcast Cable http://testmy.net/hoststats/comcast_cable)
User Agent:: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/28.0.1500.95 Safari/537.36 [!]
that is the results of my speedtest and one of my logs. The problem I am having currently is that when I have a bitrate anything above 500, the ping spikes around 200-300. it doesn't seem like it should do that when i have 3.7 up, I know that isn't great, but I didn't think it was THAT bad. I have network impact minimized checked. I searched this issue already but all I saw was people who had this issue with like less than 1mb of upload and I don't have that. Any help is much appreciated, I've tried to fix this and I just cant figure it out :(.
RachaelPassive
Re: Need help with settings with streaming League Of Legends
also it is stable without webcam, I just don't know why it is lagging THAT bad with webcam when i feel like I should be fine
Bombolero
If you suspect the webcam is the problem, you might want to check out http://obsproject.com/forum/viewtopic.php?f=18&t=1036.
Apart from that, I don't really have an idea of how the webcam is supposed to raise your ping if you don't change the bitrate... especially since your bitrate is far below your upload speed.
Bombolero
Another wild guess of mine: Have you enabled the "minimize network impact" option under broadcast settings?
Krazy
Town drunk
Try plugging your PC directly into the modem. It might be something in your router screwing things up.
