01:03:49: Open Broadcaster Software v0.522b - 32bit (´・ω・`)
01:03:49: -------------------------------
01:03:49: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
01:03:49: CPU Speed: 3292MHz
01:03:49: Physical Memory: 4095MB Total, 4095MB Free
01:03:49: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
01:03:49: monitor 1: pos={0, 0}, size={1920, 1080}
01:03:49: Windows Version: 6.1 Build 7601 S
01:03:49: Aero is Enabled
01:03:49: OBS Modules:
01:03:49: Base Address Module
01:03:49: 00C60000 OBS.exe
01:03:49: 6F0A0000 OBSApi.dll
01:03:49: 6EEC0000 DShowPlugin.dll
01:03:49: 71F10000 GraphicsCapture.dll
01:03:49: 6EEA0000 NoiseGate.dll
01:03:49: ------------------------------------------
01:03:49: Adapter 1
01:03:49: Video Adapter: NVIDIA GeForce GTX 560 Ti
01:03:49: Video Adapter Dedicated Video Memory: 1025966080
01:03:49: Video Adapter Shared System Memory: 3220779008
01:03:49: Adapter 2
01:03:49: Video Adapter: Intel(R) HD Graphics 3000
01:03:49: Video Adapter Dedicated Video Memory: 67108864
01:03:49: Video Adapter Shared System Memory: 1711276032
01:03:49: =====Stream Start: 2013-06-24, 01:03:49===============================================
01:03:49: Multithreaded optimizations: On
01:03:49: Base resolution: 1920x1080
01:03:49: Output resolution: 1920x1080
01:03:49: Loading up D3D10...
01:03:49: Playback device Default
01:03:49: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:03:49: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:03:49: Audio Encoding: AAC
01:03:49: bitrate: 128
01:03:49: device: Elgato Game Capture HD,
01:03:49: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:03:49: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:03:49:
01:03:49: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:03:49: Using directshow input
01:03:49: Video Encoding: x264
01:03:49: fps: 30
01:03:49: width: 1920, height: 1080
01:03:49: preset: veryfast
01:03:49: CBR: yes
01:03:49: CFR: no
01:03:49: max bitrate: 1000
01:04:15: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:04:15: New Scene
01:04:22: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:04:22: New Scene
01:04:22: ------------------------------------------
01:04:22: device: Elgato Game Capture HD,
01:04:22: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:04:22: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:04:22:
01:04:22: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:04:22: Using directshow input
01:04:23: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:04:23: New Scene
01:04:42: Using bitmap image
01:04:55: Total frames rendered: 1978, number of frames that lagged: 1 (0.05%) (it's okay for some frames to lag)
01:04:55: =====Stream End: 2013-06-24, 01:04:55=================================================
01:04:56: =====Stream Start: 2013-06-24, 01:04:56===============================================
01:04:56: Multithreaded optimizations: On
01:04:56: Base resolution: 1920x1080
01:04:56: Output resolution: 1920x1080
01:04:56: ------------------------------------------
01:04:56: Loading up D3D10...
01:04:56: Playback device Default
01:04:56: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:04:56: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:04:56: Audio Encoding: AAC
01:04:56: bitrate: 128
01:04:56: Using bitmap image
01:04:56: Video Encoding: x264
01:04:56: fps: 30
01:04:56: width: 1920, height: 1080
01:04:56: preset: veryfast
01:04:56: CBR: yes
01:04:56: CFR: no
01:04:56: max bitrate: 1000
01:04:58: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:04:58: New Scene
01:04:58: ------------------------------------------
01:04:58: device: Elgato Game Capture HD,
01:04:58: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:04:58: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:04:58:
01:04:58: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:04:58: Using directshow input
01:05:05: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
01:05:05: New Scene
01:05:05: Using bitmap image
01:05:09: Total frames rendered: 391, number of frames that lagged: 1 (0.26%) (it's okay for some frames to lag)
01:05:09: =====Stream End: 2013-06-24, 01:05:09=================================================
01:05:47: =====Stream Start: 2013-06-24, 01:05:47===============================================
01:05:47: Multithreaded optimizations: On
01:05:47: Base resolution: 1920x1080
01:05:47: Output resolution: 1920x1080
01:05:47: ------------------------------------------
01:05:47: Loading up D3D10...
01:05:47: Playback device Default
01:05:47: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:05:47: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:05:47: Audio Encoding: AAC
01:05:47: bitrate: 128
01:05:47: Using bitmap image
01:05:47: device: Elgato Game Capture HD,
01:05:47: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:05:47: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:05:47:
01:05:47: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:05:47: Using directshow input
01:05:47: Video Encoding: x264
01:05:47: fps: 30
01:05:47: width: 1920, height: 1080
01:05:47: preset: veryfast
01:05:47: CBR: yes
01:05:47: CFR: no
01:05:47: max bitrate: 1000
01:05:58: Total frames rendered: 343, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:05:59: =====Stream End: 2013-06-24, 01:05:59=================================================
01:06:36: =====Stream Start: 2013-06-24, 01:06:36===============================================
01:06:36: Multithreaded optimizations: On
01:06:36: Base resolution: 1920x1080
01:06:36: Output resolution: 1920x1080
01:06:36: ------------------------------------------
01:06:36: Loading up D3D10...
01:06:36: Playback device Default
01:06:36: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:06:36: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:06:36: Audio Encoding: AAC
01:06:36: bitrate: 128
01:06:36: Using text output
01:06:36: Using bitmap image
01:06:36: device: Elgato Game Capture HD,
01:06:36: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:06:36: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:06:36:
01:06:36: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:06:36: Using directshow input
01:06:36: Video Encoding: x264
01:06:36: fps: 30
01:06:36: width: 1920, height: 1080
01:06:36: preset: veryfast
01:06:36: CBR: yes
01:06:36: CFR: no
01:06:36: max bitrate: 1000
01:07:02: ------------------------------------------
01:07:02: device: Elgato Game Capture HD,
01:07:02: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:07:02: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:07:02:
01:07:02: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:07:02: Using directshow input
01:07:57: Total frames rendered: 2405, number of frames that lagged: 2 (0.08%) (it's okay for some frames to lag)
01:07:57: =====Stream End: 2013-06-24, 01:07:57=================================================
01:08:00: =====Stream Start: 2013-06-24, 01:08:00===============================================
01:08:00: Multithreaded optimizations: On
01:08:00: Base resolution: 1920x1080
01:08:00: Output resolution: 1920x1080
01:08:00: ------------------------------------------
01:08:00: Loading up D3D10...
01:08:01: Playback device Default
01:08:01: ------------------------------------------
01:08:01: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:08:01: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:08:01: Audio Encoding: AAC
01:08:01: bitrate: 128
01:08:01: Using text output
01:08:01: Using bitmap image
01:08:01: device: Elgato Game Capture HD,
01:08:01: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:08:01: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:08:01:
01:08:01: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:08:01: Using directshow input
01:08:01: Video Encoding: x264
01:08:01: fps: 30
01:08:01: width: 1920, height: 1080
01:08:01: preset: veryfast
01:08:01: CBR: yes
01:08:01: CFR: no
01:08:01: max bitrate: 1000
01:08:02: Using RTMP service: Twitch / Justin.tv
01:08:02: Server selection: rtmp://live-lax.justin.tv/app
01:08:03: librtmp error: rtmp://live-lax.justin.tv/app:
01:08:03: NetStream.Publish.Rejected (Authentication Failed.)
01:08:03: Connection to rtmp://live-lax.justin.tv/app failed: Could not access the specified channel or stream key. This could be because the key/channel is invalid, or because the server still thinks you are logged in.
01:08:03:
01:08:03: rtmp://live-lax.justin.tv/app:
01:08:03:
01:08:03: Total frames rendered: 58, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:08:03: Number of times waited to send: 0, Waited for a total of 0 bytes
01:08:03: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
01:08:03: =====Stream End: 2013-06-24, 01:08:03=================================================
01:08:44: =====Stream Start: 2013-06-24, 01:08:44===============================================
01:08:44: Multithreaded optimizations: On
01:08:44: Base resolution: 1920x1080
01:08:44: Output resolution: 1920x1080
01:08:44: ------------------------------------------
01:08:44: Loading up D3D10...
01:08:44: Playback device Default
01:08:44: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:08:44: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:08:44: Audio Encoding: AAC
01:08:44: bitrate: 128
01:08:44: Using text output
01:08:44: Using bitmap image
01:08:44: device: Elgato Game Capture HD,
01:08:44: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:08:44: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:08:44:
01:08:44: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:08:44: Using directshow input
01:08:44: Video Encoding: x264
01:08:44: fps: 30
01:08:44: width: 1920, height: 1080
01:08:44: preset: veryfast
01:08:44: CBR: yes
01:08:44: CFR: no
01:08:44: max bitrate: 1000
01:08:46: Using RTMP service: Twitch / Justin.tv
01:08:46: Server selection: rtmp://live-lax.justin.tv/app
01:08:46: librtmp error: rtmp://live-lax.justin.tv/app:
01:08:46: NetStream.Publish.Rejected (Authentication Failed.)
01:08:46: Connection to rtmp://live-lax.justin.tv/app failed: Could not access the specified channel or stream key. This could be because the key/channel is invalid, or because the server still thinks you are logged in.
01:08:46:
01:08:46: rtmp://live-lax.justin.tv/app:
01:08:46:
01:08:46: Total frames rendered: 57, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:08:46: Number of times waited to send: 0, Waited for a total of 0 bytes
01:08:46: Number of b-frames dropped: 0 (-1.$%), Number of p-frames dropped: 0 (-1.$%), Total 0 (-1.$%)
01:08:46: =====Stream End: 2013-06-24, 01:08:46=================================================
01:09:10: =====Stream Start: 2013-06-24, 01:09:10===============================================
01:09:10: Multithreaded optimizations: On
01:09:10: Base resolution: 1920x1080
01:09:10: Output resolution: 1920x1080
01:09:10: ------------------------------------------
01:09:10: Loading up D3D10...
01:09:10: Playback device Default
01:09:10: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:09:10: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:09:10: Audio Encoding: AAC
01:09:10: bitrate: 128
01:09:10: Using text output
01:09:10: Using bitmap image
01:09:10: device: Elgato Game Capture HD,
01:09:10: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:09:10: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:09:10:
01:09:10: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:09:10: Using directshow input
01:09:10: Video Encoding: x264
01:09:10: fps: 30
01:09:10: width: 1920, height: 1080
01:09:10: preset: veryfast
01:09:10: CBR: yes
01:09:10: CFR: no
01:09:10: max bitrate: 1000
01:09:39: Total frames rendered: 883, number of frames that lagged: 3 (0.34%) (it's okay for some frames to lag)
01:09:40: =====Stream End: 2013-06-24, 01:09:40=================================================
01:09:45: =====Stream Start: 2013-06-24, 01:09:45===============================================
01:09:45: Multithreaded optimizations: On
01:09:45: Base resolution: 1920x1080
01:09:45: Output resolution: 1920x1080
01:09:45: ------------------------------------------
01:09:45: Loading up D3D10...
01:09:45: Playback device Default
01:09:45: Using desktop audio input: Speakers (Realtek High Definition Audio)
01:09:45: Using auxilary audio input: Microphone (Realtek High Definition Audio)
01:09:45: Audio Encoding: AAC
01:09:45: bitrate: 128
01:09:45: device: Elgato Game Capture HD,
01:09:45: device id {39F50F4C-99E1-464a-B6F9-D605B4FB5918},
01:09:45: chosen type: UYVY, usingFourCC: false, res: 1280x720 - 1280x720, frameIntervals: 333333-333333, fourCC: 'UYVY'
01:09:45:
01:09:45: device audio info - bits per sample: 16, channels: 2, samples per sec: 48000, block size: 4
01:09:45: Using directshow input
01:09:45: Video Encoding: x264
01:09:45: fps: 30
01:09:45: width: 1920, height: 1080
01:09:45: preset: veryfast
01:09:45: CBR: yes
01:09:45: CFR: no
01:09:45: max bitrate: 1000
01:09:49: Total frames rendered: 127, number of frames that lagged: 0 (0.00%) (it's okay for some frames to lag)
01:09:50: =====Stream End: 2013-06-24, 01:09:50=================================================
01:09:52:
01:09:52: Profiler results:
01:09:52:
01:09:52: ==============================================================
01:09:52: frame - [100%] [avg time: 3.47 ms] [avg calls per frame: 1] [children: 77.2%] [unaccounted: 22.8%]
01:09:52: | scene->Preprocess - [12.9%] [avg time: 0.448 ms] [avg calls per frame: 1]
01:09:52: | video encoding and uploading - [64.3%] [avg time: 2.231 ms] [avg calls per frame: 1] [children: 63.7%] [unaccounted: 0.634%]
01:09:52: | | CopyResource - [0.49%] [avg time: 0.017 ms] [avg calls per frame: 0]
01:09:52: | | conversion to 4:2:0 - [0.346%] [avg time: 0.012 ms] [avg calls per frame: 0]
01:09:52: | | call to encoder - [62.8%] [avg time: 2.179 ms] [avg calls per frame: 0]
01:09:52: | | sending stuff out - [0.0288%] [avg time: 0.001 ms] [avg calls per frame: 0]
01:09:52:
