Hello, I need help with my settings. I keep getting dropped frames.
My Internet Connection:
16:25:31: =====Stream Start: 2013-08-25, 16:25:31===============================================
16:25:31: Multithreaded optimizations: On
16:25:31: Base resolution: 1280x720
16:25:31: Output resolution: 1280x720
16:25:31: ------------------------------------------
16:25:31: Loading up D3D10 on NVIDIA GeForce 8800 GT...
16:25:31: Playback device {0.0.0.00000000}.{d240f364-8549-4991-93a6-996b7856f7e9}
16:25:31: Using desktop audio input: FHeadsert (Realtek High Definition Audio)
16:25:31: Using auxilary audio input: Mic in at front panel (Pink) (Realtek High Definition Audio)
16:25:31: Audio Encoding: AAC
16:25:31: bitrate: 160
16:25:31: Using bitmap image
16:25:32: Using bitmap image
16:25:32: ------------------------------------------
16:25:32: Video Encoding: x264
16:25:32: fps: 60
16:25:32: width: 1280, height: 720
16:25:32: preset: faster
16:25:32: CBR: yes
16:25:32: CFR: no
16:25:32: max bitrate: 3800
16:25:32: MMDeviceAudioSource: Frequency for device 'FHeadsert (Realtek High Definition Audio)' is 384000, samples per sec is 48000
16:25:32: MMDeviceAudioSource: Frequency for device 'Mic in at front panel (Pink) (Realtek High Definition Audio)' is 352800, samples per sec is 44100
16:25:33: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
16:25:34: SO_SNDBUF was at 65536
16:25:34: SO_SNDBUF is now 65536
16:25:35: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 151418 / 506880)
16:25:36: RTMPPublisher::Socketloop: Increasing send buffer to ISB 262144 (buffer: 532 / 506880)
16:25:36: RTMPPublisher::Socketloop: Increasing send buffer to ISB 524288 (buffer: 23519 / 506880)
16:25:37: RTMPPublisher::Socketloop: Increasing send buffer to ISB 1048576 (buffer: 0 / 506880)
16:26:20: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
16:26:20: New Scene
16:26:20: ------------------------------------------
16:26:20: device: Logitech HD Pro Webcam C920,
16:26:20: device id \\?\usb#vid_046d&pid_082d&mi_00#6&58f59c6&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083},
16:26:20: chosen type: I420, usingFourCC: false, res: 640x360 - 640x360, frameIntervals: 333333-2000000, fourCC: 'I420'
16:26:20: audio device: Disable,
16:26:20: audio device id Disabled,
16:26:20:
16:26:20: Using directshow input
16:26:20: Using Window Capture
16:26:20: device: AVerMedia HD Capture C985 Bus 2,
16:26:20: device id \\?\pci#ven_1af2&dev_a001&subsys_a0011af2&rev_00#4&31ebfed0&0&0020#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{957bd672-7934-4b55-b81a-3e22b14c679a},
16:26:20: chosen type: YV12, usingFourCC: true, res: 1280x720 - 1280x720, frameIntervals: 166666-666666, fourCC: 'YV12'
16:26:20:
16:26:21: PERFORMANCE WARNING: Scene change took 592 ms, maybe some sources should be global sources?
16:52:58: RTMPPublisher::SocketLoop: Aborting due to FD_CLOSE, error 0
16:52:59: Total frames rendered: 97994, number of late frames: 6677 (6.81%) (it's okay for some frames to be late)
16:53:02: Number of times waited to send: 4, Waited for a total of 16395 bytes
16:53:02: Number of b-frames dropped: 86 (0.088%), Number of p-frames dropped: 147 (0.15%), Total 233 (0.24%)
16:53:02:
16:53:02: Profiler results:
16:53:02:
16:53:02: ==============================================================
16:53:02: frame - [100%] [avg time: 13.553 ms (cpu time: avg 11.22 ms, total 1.09953e+006 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.0738%]
16:53:02: | frame preprocessing and rendering - [52.9%] [avg time: 7.165 ms (cpu time: avg 6.658 ms, total 652521 ms)] [avg calls per frame: 1] [children: 47.2%] [unaccounted: 5.64%]
16:53:02: | | scene->Preprocess - [47.2%] [avg time: 6.4 ms (cpu time: avg 5.981 ms, total 586158 ms)] [avg calls per frame: 1]
16:53:02: | video encoding and uploading - [47.1%] [avg time: 6.378 ms (cpu time: avg 4.553 ms, total 446241 ms)] [avg calls per frame: 1] [children: 46.9%] [unaccounted: 0.207%]
16:53:02: | | flush - [0.716%] [avg time: 0.097 ms (cpu time: avg 0.093 ms, total 9157.26 ms)] [avg calls per frame: 1]
16:53:02: | | CopyResource - [30.5%] [avg time: 4.136 ms (cpu time: avg 2.567 ms, total 251583 ms)] [avg calls per frame: 0]
16:53:02: | | conversion to 4:2:0 - [0.598%] [avg time: 0.081 ms (cpu time: avg 0.027 ms, total 2652.02 ms)] [avg calls per frame: 0]
16:53:02: | | call to encoder - [14.8%] [avg time: 2.008 ms (cpu time: avg 1.819 ms, total 178262 ms)] [avg calls per frame: 0]
16:53:02: | | sending stuff out - [0.207%] [avg time: 0.028 ms (cpu time: avg 0.025 ms, total 2496.02 ms)] [avg calls per frame: 0]
16:53:02: | Convert444Threads - [496%] [avg time: 67.186 ms (cpu time: avg 2.547 ms, total 249664 ms)] [avg calls per frame: 3]
16:53:02:
16:53:02: =====Stream End: 2013-08-25, 16:53:02=================================================
