20:31:31: Open Broadcaster Software v0.554b - 32bit (´・ω・`)
20:31:31: -------------------------------
20:31:31: CPU Name: AMD Phenom(tm) II X4 955 Processor
20:31:31: CPU Speed: 3210MHz
20:31:31: Physical Memory: 4095MB Total, 4095MB Free
20:31:31: stepping id: 3, model 4, family 15, type 0, extmodel 8, extfamily 0, HTT 1, logical cores 4, total cores 4
20:31:31: monitor 1: pos={0, 0}, size={1920, 1080}
20:31:31: Windows Version: 6.1 Build 7601 S
20:31:31: Aero is Disabled
20:31:31: OBS Modules:
20:31:31: Base Address Module
20:31:31: 00BC0000 OBS.exe
20:31:31: 67580000 OBSApi.dll
20:31:31: 67340000 DShowPlugin.dll
20:31:31: 67820000 GraphicsCapture.dll
20:31:31: 67320000 NoiseGate.dll
20:31:31: 67300000 PSVPlugin.dll
20:31:31: ------------------------------------------
20:31:31: Adapter 1
20:31:31: Video Adapter: ATI Radeon HD 5450
20:31:31: Video Adapter Dedicated Video Memory: 523685888
20:31:31: Video Adapter Shared System Memory: 3771215872
20:31:31: =====Stream Start: 2013-09-19, 20:31:31===============================================
20:31:31: Multithreaded optimizations: On
20:31:31: Base resolution: 1920x1080
20:31:31: Output resolution: 1920x1080
20:31:31: Loading up D3D10 on ATI Radeon HD 5450...
20:31:31: C:/Users/XularusXIII/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture.pShader.blob
20:31:31: C:/Users/XularusXIII/AppData/Roaming/OBS/shaderCache/shaders/DrawSolid.pShader.blob
20:31:31: C:/Users/XularusXIII/AppData/Roaming/OBS/shaderCache/shaders/DrawYUVTexture.pShader.blob
20:31:31: Playback device Default
20:31:31: Using desktop audio input: Speakers (VIA High Definition Audio)
20:31:31: Using auxilary audio input: Stereo Mix (VIA High Definition Audio)
20:31:31: Audio Encoding: AAC
20:31:31: bitrate: 160
20:31:31: Using graphics capture
20:31:31: C:/Users/XularusXIII/AppData/Roaming/OBS/shaderCache/shaders/InvertTexture.pShader.blob
20:31:31: C:/Users/XularusXIII/AppData/Roaming/OBS/shaderCache/shaders/DrawTexture_ColorAdjust.pShader.blob
20:31:31: Using custom x264 settings: "keyint=X"
20:31:32: The custom x264 command 'keyint=X' failed
20:31:32: ------------------------------------------
20:31:32: Video Encoding: x264
20:31:32: fps: 30
20:31:32: width: 1920, height: 1080
20:31:32: preset: veryfast
20:31:32: CBR: yes
20:31:32: CFR: yes
20:31:32: max bitrate: 2500
20:31:32: buffer size: 2500
20:31:32: MMDeviceAudioSource: Frequency for device 'Speakers (VIA High Definition Audio)' is 384000, samples per sec is 48000
20:31:32: MMDeviceAudioSource: Frequency for device 'Stereo Mix (VIA High Definition Audio)' is 352800, samples per sec is 44100
20:31:33: Using RTMP service: Twitch / Justin.tv
20:31:33: Server selection: rtmp://live-iad.justin.tv/app
20:31:33: Interface: Realtek PCIe GBE Family Controller (ethernet, 100 mbps)
20:31:34: using memory capture
20:31:34: SO_SNDBUF was at 8192
20:31:34: SO_SNDBUF is now 65536
20:31:39: RTMPPublisher::Socketloop: Increasing send buffer to ISB 131072 (buffer: 0 / 339968)
20:32:02: Total frames rendered: 912, number of late frames: 1 (0.11%) (it's okay for some frames to be late)
20:32:02: Total duplicated frames to ensure constant framerate: 0 (0.00%)
20:32:03: RTMPPublisher::SocketLoop: Graceful loop exit
20:32:03: Number of times waited to send: 0, Waited for a total of 0 bytes
20:32:03: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
20:32:03:
20:32:03: Profiler results:
20:32:03:
20:32:03: ==============================================================
20:32:03: frame - [100%] [avg time: 8.397 ms (cpu time: avg 6.773 ms, total 6177.64 ms)] [avg calls per frame: 1] [children: 99.9%] [unaccounted: 0.131%]
20:32:03: | frame preprocessing and rendering - [42.8%] [avg time: 3.595 ms (cpu time: avg 3.318 ms, total 3026.41 ms)] [avg calls per frame: 1] [children: 0.0238%] [unaccounted: 42.8%]
20:32:03: | | scene->Preprocess - [0.0238%] [avg time: 0.002 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 1]
20:32:03: | video encoding and uploading - [57.1%] [avg time: 4.791 ms (cpu time: avg 3.455 ms, total 3151.23 ms)] [avg calls per frame: 1] [children: 56.3%] [unaccounted: 0.715%]
20:32:03: | | flush - [10.4%] [avg time: 0.875 ms (cpu time: avg 0.102 ms, total 93.601 ms)] [avg calls per frame: 1]
20:32:03: | | CopyResource - [0.131%] [avg time: 0.011 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
20:32:03: | | conversion to 4:2:0 - [0.607%] [avg time: 0.051 ms (cpu time: avg 0 ms, total 0 ms)] [avg calls per frame: 0]
20:32:03: | | call to encoder - [44.3%] [avg time: 3.722 ms (cpu time: avg 3.25 ms, total 2964.03 ms)] [avg calls per frame: 0]
20:32:03: | | sending stuff out - [0.857%] [avg time: 0.072 ms (cpu time: avg 0.051 ms, total 46.8 ms)] [avg calls per frame: 0]
20:32:03: | Convert444Threads - [779%] [avg time: 65.43 ms (cpu time: avg 3.9 ms, total 3556.82 ms)] [avg calls per frame: 1]
20:32:03:
20:32:03: =====Stream End: 2013-09-19, 20:32:03=================================================
Last game capture log:
2013-09-19, 20:31:31: we're booting up:
20:31:32: GL Present
20:31:32: (half life scientist) everything.. seems to be in order
20:31:34: SwapBuffers(2617322969) Called
20:31:34: setting up gl data
20:31:34: DoGLCPUHook: success
20:31:34: wglSwapBuffers(2617322969) Called
20:31:34: successfully capturing gl frames via RAM
20:31:58: wglDeleteContext Called
20:31:58: ---------------------- Cleared OpenGL Capture ----------------------
