Question / Help Need help with optimization (fps drops and ping spikes)
colesie
I'm experiencing dropped frames and major ping spikes when attempting to stream games such as Darkfall: Unholy Wars and Chivalry. Turn-based games and less graphically demanding games have less of an issue obviously but I would like to be able to play more fps games without being handicapped by my fps loss and ping issues.
Here is a copy of my obs logs from Darkfall Unholy Wars. During this time I was experiencing about 60 fps drops and spikes up to 500 ping from a normal rate of around 43.
*My computer's specs are in my fourth post of this thread*
Last game capture log:
2015-04-19, 01:06:39: we're booting up:
01:06:39: CaptureThread: attached to process CMW.exe
01:06:39: D3D9 Present
01:06:39: D3D9EndScene called
01:06:39: D3DPRESENT_PARAMETERS {
01:06:39:     BackBufferWidth: 1908
01:06:39:     BackBufferHeight: 1012
01:06:39:     BackBufferFormat: D3DFMT_A8R8G8B8
01:06:39:     BackBufferCount: 1
01:06:39:     MultiSampleType: D3DMULTISAMPLE_NONE
01:06:39:     MultiSampleQuality: 0
01:06:39:     SwapEffect: D3DSWAPEFFECT_COPY
01:06:39:     hDeviceWindow: 1967870
01:06:3914:10:26: ---------------------- Cleared D3D10 Capture ----------------------
thStencilFormat: D3DFMT_UNKNOWN
01:06:39:     Flags: D3DPRESENTFLAG_LOCKABLE_BACKBUFFER
01:06:39:     FullScreen_RefreshRateInHz: 0
01:06:39:     PresentationInterval: 1
01:06:39: };
01:06:39: successfully set up d3d9 hooks
01:06:39: D3D9Present called
01:06:39: DXGI Present
01:06:39: (half life scientist) everything..  seems to be in order
01:06:39: DoD3D9GPUHook: success
01:06:39: D3DSURFACE_DESC {
01:06:39:     Format: D3DFMT_A8R8G8B8
01:06:39:     Type: D3DRTYPE_SURFACE
01:06:39:     Usage: D3DUSAGE_RENDERTARGET
01:06:39:     Pool: D3DPOOL_DEFAULT
01:06:39:     Width: 1908
01:06:39:     Height: 1012
01:06:39: };
01:06:39: successfully capturing d3d9 frames via GPU
01:06:40: ---------------------- Cleared D3D9 Capture ----------------------
01:06:40: D3D9EndScene called
01:06:40: D3D9Present called
01:06:41: received restart event, capturing
01:06:41: DoD3D9GPUHook: success
01:06:41: D3DSURFACE_DESC {
01:06:41:     Format: D3DFMT_A8R8G8B8
01:06:41:     Type: D3DRTYPE_SURFACE
01:06:41:     Usage: D3DUSAGE_RENDERTARGET
01:06:41:     Pool: D3DPOOL_DEFAULT
01:06:41:     MultiSampleType: D3DMULTISAMPLE_NONE
01:06:41:     MultiSampleQuality: 0
01:06:41:     Width: 1908
01:06:41:     Height: 1012
01:06:41: };
01:06:41: successfully capturing d3d9 frames via GPU
Logs will continue in my next post*
14:39:49: Open Broadcaster Software v0.651b - 64bit ( ^ω^)
14:39:49: -------------------------------
14:39:49: CPU Name: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
14:39:49: CPU Speed: 3402MHz
14:39:49: Physical Memory:  16267MB Total, 9772MB Free
14:39:49: stepping id: 9, model 58, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
14:39:49: monitor 1: pos={0, 0}, size={1920, 1080}
14:39:49: monitor 2: pos={1920, 0}, size={1920, 1080}
14:39:49: Windows Version: 6.1 Build 7601 S
14:39:49: Aero is Disabled
14:39:49: OBS Modules:
14:39:49: Base Address     Module
14:39:49: 000000003FD30000 OBS.exe
14:39:49: 00000000F4160000 OBSApi.dll
14:39:49: 00000000F4920000 DShowPlugin.dll
14:39:49: 00000000F4040000 GraphicsCapture.dll
14:39:49: 00000000F5500000 NoiseGate.dll
14:39:49: 00000000F49D0000 PSVPlugin.dll
14:39:49: 00000000F3FE0000 scenesw.dll
14:39:49: ------------------------------------------
14:39:49: Adapter 1
14:39:49:   Video Adapter: AMD Radeon HD 7800 Series
14:39:49:   Video Adapter Dedicated Video Memory: 2120388608
14:39:49:   Video Adapter Shared System Memory: 3965233152
14:39:49:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
14:39:49: Adapter 2
14:39:49:   Video Adapter: Intel(R) HD Graphics 4000
14:39:49:   Video Adapter Dedicated Video Memory: 67108864
14:39:49:   Video Adapter Shared System Memory: 1711276032
14:39:49:   Video Adapter Output 1: pos={1920, 0}, size={1920, 1080}, attached=true
14:39:49: =====Stream Start: 2015-04-19, 14:39:49===============================================
14:39:49:   Multithreaded optimizations: On
14:39:49:   Base resolution: 1920x1080
14:39:49:   Output resolution: 1280x720
14:39:49: Loading up D3D10 on AMD Radeon HD 7800 Series (Adapter 1)...
14:39:49: Audio Format: 48000 Hz
14:39:49: Audio Channels: 2 Ch
14:39:49: Playback device Default
14:39:49: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:39:49: Global Audio time adjust: 0
14:39:49: Using auxilary audio input: Microphone (HD Webcam C525)
14:39:49: Mic time offset: 0
14:39:49: Audio Encoding: AAC
14:39:49:     bitrate: 96
14:39:49: Using Monitor Capture
14:39:49: Using graphics capture
14:39:49: Trying to hook process: dfuw.exe
14:39:49: Scene buffering time set to 700
14:39:49: Using custom x264 settings: "Custom x264 parameters: crf=15"
14:39:49: x264: VBV maxrate specified, but no bufsize, ignored
14:39:49: Video Encoding: x264
14:39:49:     fps: 30
14:39:49:     width: 1280, height: 720
14:39:49:     preset: veryfast
14:39:49:     profile: high
14:39:49:     keyint: 250
14:39:49:     CBR: yes
14:39:49:     CFR: yes
14:39:49:     max bitrate: 3000
14:39:49:     buffer size: 0
14:39:49: SharedTexCapture hooked
14:39:50: Audio timestamp for device 'Microphone (HD Webcam C525)' was behind target timestamp by 62886831
14:40:48: FlushBufferedVideo: Flushing 3 packets over 66 ms
14:40:48: Total frames encoded: 1745, total frames duplicated: 180 (10.32%)
14:40:48: Total frames rendered: 1767, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
14:40:48:
14:40:48: Profiler time results:
14:40:48:
14:40:48: ==============================================================
14:40:48: video thread frame - [100%] [avg time: 21.317 ms] [children: 66.6%] [unaccounted: 33.4%]
14:40:48: | scene->Preprocess - [63.9%] [avg time: 13.618 ms]
14:40:48: | GPU download and conversion - [2.68%] [avg time: 0.571 ms] [children: 2.5%] [unaccounted: 0.178%]
14:40:48: | | flush - [2.35%] [avg time: 0.5 ms]
14:40:48: | | CopyResource - [0.103%] [avg time: 0.022 ms]
14:40:48: | | conversion to 4:2:0 - [0.0516%] [avg time: 0.011 ms]
14:40:48: Convert444Threads - [100%] [avg time: 1.01 ms] [children: 99.6%] [unaccounted: 0.396%]
14:40:48: | Convert444toNV12 - [99.6%] [avg time: 1.006 ms]
14:40:48: encoder thread frame - [100%] [avg time: 1.98 ms] [children: 0.253%] [unaccounted: 99.7%]
14:40:48: | sending stuff out - [0.253%] [avg time: 0.005 ms]
14:40:48:
14:40:48:
14:40:48: Profiler CPU results:
14:40:48:
14:40:48: video thread frame - [cpu time: avg 7.477 ms, total 13213.3 ms] [avg calls per frame: 1]
14:40:48: | scene->Preprocess - [cpu time: avg 5.438 ms, total 9609.66 ms] [avg calls per frame: 1]
14:40:48: | GPU download and conversion - [cpu time: avg 0.141 ms, total 249.6 ms] [avg calls per frame: 1]
14:40:48: | | flush - [cpu time: avg 0.114 ms, total 202.8 ms] [avg calls per frame: 1]
14:40:48: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
14:40:48: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
14:40:48: Convert444Threads - [cpu time: avg 0.859 ms, total 2995.22 ms] [avg calls per frame: 2]
14:40:48: | Convert444toNV12 - [cpu time: avg 0.859 ms, total 2995.22 ms] [avg calls per frame: 2]
14:40:48: encoder thread frame - [cpu time: avg 1.343 ms, total 2340.02 ms] [avg calls per frame: 1]
14:40:48: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
14:40:48:
14:40:48: =====Stream End: 2015-04-19, 14:40:48=================================================
14:40:53: =====Stream Start: 2015-04-19, 14:40:53===============================================
14:40:53:   Multithreaded optimizations: On
14:40:53:   Base resolution: 1920x1080
14:40:53:   Output resolution: 1280x720
14:40:53: ------------------------------------------
14:40:53: Loading up D3D10 on AMD Radeon HD 7800 Series (Adapter 1)...
14:40:53: Audio Format: 48000 Hz
14:40:53: Audio Channels: 2 Ch
14:40:53: Playback device Default
14:40:53: Using desktop audio input: Speakers (Realtek High Definition Audio)
14:40:53: Global Audio time adjust: 0
14:40:53: Using auxilary audio input: Microphone (HD Webcam C525)
14:40:53: Mic time offset: 0
14:40:53: Audio Encoding: AAC
14:40:53:     bitrate: 96
14:40:53: Using Monitor Capture
14:40:53: Using graphics capture
14:40:53: Trying to hook process: dfuw.exe
14:40:53: Scene buffering time set to 700
14:40:53: Using custom x264 settings: "Custom x264 parameters: crf=15"
14:40:53: x264: VBV maxrate specified, but no bufsize, ignored
14:40:53: Video Encoding: x264
14:40:53:     fps: 30
14:40:53:     width: 1280, height: 720
14:40:53:     preset: veryfast
14:40:53:     profile: high
14:40:53:     keyint: 250
14:40:53:     CBR: yes
14:40:53:     CFR: yes
14:40:53:     max bitrate: 3000
14:40:53:     buffer size: 0
14:40:53: SharedTexCapture hooked
14:40:55: Using RTMP service: Twitch
14:40:55:   Server selection: rtmp://live-jfk.twitch.tv/app
14:40:55:   Interface: Broadcom NetLink (TM) Gigabit Ethernet (ethernet, 1000 mbps)
14:40:55: Completed handshake with rtmp://live-jfk.twitch.tv/app in 483 ms.
14:40:56: SO_SNDBUF was at 8192
14:40:56: SO_SNDBUF is now 65536
14:43:32: Audio timestamp for device 'Microphone (HD Webcam C525)' was behind target timestamp by 80
14:46:52: Audio timestamp for device 'Microphone (HD Webcam C525)' was behind target timestamp by 90
14:48:53: Audio timestamp for device 'Microphone (HD Webcam C525)' was behind target timestamp by 100
14:52:53: Audio timestamp for device 'Microphone (HD Webcam C525)' was behind target timestamp by 110
14:56:53: Audio timestamp for device 'Microphone (HD Webcam C525)' was behind target timestamp by 120
14:58:54: Audio timestamp for device 'Microphone (HD Webcam C525)' was behind target timestamp by 130
15:00:31: FlushBufferedVideo: Flushing 8 packets over 234 ms
15:00:32: Total frames encoded: 35314, total frames duplicated: 6081 (17.22%)
15:00:32: Total frames rendered: 35045, number of late frames: 249 (0.71%) (it's okay for some frames to be late)
Logs con't.
15:00:32:
15:00:32: Profiler time results:
15:00:32:
15:00:32: ==============================================================
15:00:32: video thread frame - [100%] [avg time: 24.124 ms] [children: 80.1%] [unaccounted: 19.9%]
15:00:32: | scene->Preprocess - [77.2%] [avg time: 18.625 ms]
15:00:32: | GPU download and conversion - [2.93%] [avg time: 0.706 ms] [children: 1.8%] [unaccounted: 1.13%]
15:00:32: | | flush - [1.64%] [avg time: 0.396 ms]
15:00:32: | | CopyResource - [0.0995%] [avg time: 0.024 ms]
15:00:32: | | conversion to 4:2:0 - [0.058%] [avg time: 0.014 ms]
15:00:32: Convert444Threads - [100%] [avg time: 1.173 ms] [children: 99.5%] [unaccounted: 0.512%]
15:00:32: | Convert444toNV12 - [99.5%] [avg time: 1.167 ms]
15:00:32: encoder thread frame - [100%] [avg time: 2.456 ms] [children: 2.85%] [unaccounted: 97.1%]
15:00:32: | sending stuff out - [2.85%] [avg time: 0.07 ms]
15:00:32:
15:00:32:
15:00:32: Profiler CPU results:
15:00:32:
15:00:32: video thread frame - [cpu time: avg 8.534 ms, total 299085 ms] [avg calls per frame: 1]
15:00:32: | scene->Preprocess - [cpu time: avg 7.024 ms, total 246170 ms] [avg calls per frame: 1]
15:00:32: | GPU download and conversion - [cpu time: avg 0.157 ms, total 5522.43 ms] [avg calls per frame: 1]
15:00:32: | | flush - [cpu time: avg 0.112 ms, total 3931.22 ms] [avg calls per frame: 1]
15:00:32: | | CopyResource - [cpu time: avg 0.018 ms, total 639.604 ms] [avg calls per frame: 1]
15:00:32: | | conversion to 4:2:0 - [cpu time: avg 0.004 ms, total 140.4 ms] [avg calls per frame: 1]
15:00:32: Convert444Threads - [cpu time: avg 1.152 ms, total 80746.1 ms] [avg calls per frame: 2]
15:00:32: | Convert444toNV12 - [cpu time: avg 1.148 ms, total 80465.3 ms] [avg calls per frame: 2]
15:00:32: encoder thread frame - [cpu time: avg 1.956 ms, total 69077.2 ms] [avg calls per frame: 1]
15:00:32: | sending stuff out - [cpu time: avg 0.048 ms, total 1700.41 ms] [avg calls per frame: 1]
15:00:32:
15:00:32: =====Stream End: 2015-04-19, 15:00:32=================================================
15:00:32: ~RTMPPublisher: Packet flush completed in 138 ms
15:00:32: ~RTMPPublisher: Send thread terminated in 0 ms
15:00:32: RTMPPublisher::SocketLoop: Graceful loop exit
15:00:32: ~RTMPPublisher: Socket thread terminated in 0 ms
15:00:42: ~RTMPPublisher: Final socket shutdown completed in 10122 ms
15:00:42: Average send payload: 12206 bytes, average send interval: 27 ms
15:00:42: Number of times waited to send: 128, Waited for a total of 520602 bytes
15:00:42: Number of b-frames dropped: 60 (0.17%), Number of p-frames dropped: 123 (0.35%), Total 183 (0.52%)
15:00:42: Number of bytes sent: 524879588
15:01:55: Terminating 0x2408
15:01:55: Terminating 0x1d20
2015-04-19, 14:39:49: we're booting up:
14:39:49: CaptureThread: attached to process DFUW.exe
14:39:49: D3D9 Present
14:39:49: (half life scientist) everything..  seems to be in order
14:39:49: D3D9EndScene called
14:39:49: D3DPRESENT_PARAMETERS {
14:39:49:     BackBufferWidth: 1920
14:39:49:     BackBufferHeight: 1080
14:39:49:     BackBufferFormat: D3DFMT_X8R8G8B8
14:39:49:     BackBufferCount: 2
14:39:49:     MultiSampleType: D3DMULTISAMPLE_NONE
14:39:49:     MultiSampleQuality: 0
14:39:49:     SwapEffect: D3DSWAPEFFECT_DISCARD
14:39:49:     hDeviceWindow: 330064
14:39:49:     Windowed: true
14:39:49:     EnableAutoDepthStencil: true
14:39:49:     AutoDepthStencilFormat: D3DFMT_D24S8
14:39:49:     Flags: D3DPRESENTFLAG_DISCARD_DEPTHSTENCIL
14:39:49:     FullScreen_RefreshRateInHz: 0
14:39:49:     PresentationInterval: 2147483648
14:39:49: };
14:39:49: successfully set up d3d9 hooks
14:39:49: D3D9Present called
14:39:49: DoD3D9GPUHook: success
14:39:49: D3DSURFACE_DESC {
14:39:49:     Format: D3DFMT_X8R8G8B8
14:39:49:     Type: D3DRTYPE_SURFACE
14:39:49:     Usage: D3DUSAGE_RENDERTARGET
14:39:49:     Pool: D3DPOOL_DEFAULT
14:39:49:     Width: 1920
14:39:49:     Height: 1080
14:39:49: };
14:39:49: successfully capturing d3d9 frames via GPU
14:40:48: ---------------------- Cleared D3D9 Capture ----------------------
14:40:48: D3D9EndScene called
14:40:48: D3D9Present called
14:40:53: received restart event, capturing
14:40:53: DoD3D9GPUHook: success
14:40:53: D3DSURFACE_DESC {
14:40:53:     Format: D3DFMT_X8R8G8B8
14:40:53:     Type: D3DRTYPE_SURFACE
14:40:53:     Usage: D3DUSAGE_RENDERTARGET
14:40:53:     Pool: D3DPOOL_DEFAULT
14:40:53:     MultiSampleType: D3DMULTISAMPLE_NONE
14:40:53:     MultiSampleQuality: 0
14:40:53:     Width: 1920
14:40:53:     Height: 1080
14:40:53: };
14:40:53: successfully capturing d3d9 frames via GPU
15:00:32: ---------------------- Cleared D3D9 Capture ----------------------
15:00:32: D3D9EndScene called
15:00:32: D3D9Present called
Here are my PC's specs taken from dxdiag
System Information
Time of this report: 4/19/2015, 14:02:31
  Machine name: USER-PC
  Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.150316-1654)
   Language: English (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
  System Model: To Be Filled By O.E.M.
  BIOS: BIOS Date: 01/17/13 12:08:38 Ver: 04.06.05
  Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.4GHz
  Memory: 16384MB RAM
Available OS Memory: 16268MB RAM
  Page File: 7211MB used, 25320MB available
  Windows Dir: C:\Windows
  DirectX Version: DirectX 11
DX Setup Parameters: Not found
  User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
  DWM DPI Scaling: Disabled
  DxDiag Version: 6.01.7601.17514 32bit Unicode
Display Devices
  Card name: AMD Radeon HD 7800 Series
   Manufacturer: Advanced Micro Devices, Inc.
  Chip type: AMD Radeon Graphics Processor (0x6819)
  DAC type: Internal DAC(400MHz)
  Device Key: Enum\PCI\VEN_1002&DEV_6819&SUBSYS_E221174B&REV_00
  Display Memory: 4095 MB
   Dedicated Memory: 2022 MB
  Shared Memory: 2073 MB
  Current Mode: 1920 x 1080 (32 bit) (60Hz)
  Monitor Name: Generic PnP Monitor
  Monitor Model: S24B350
  Monitor Id: SAM08D9
  Native Mode: 1920 x 1080(p) (60.000Hz)
  Output Type: HD15
  Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1230 (English)
  Driver Version: 13.152.1.8000
  DDI Version: 11
  Driver Model: WDDM 1.1
  Driver Attributes: Final Retail
  Driver Date/Size: 10/8/2013 10:01:02, 1237200 bytes
  WHQL Logo'd: Yes
  WHQL Date Stamp:
  Device Identifier: {D7B71EE2-2B59-11CF-3570-2BC2BEC2C535}
  Vendor ID: 0x1002
  Device ID: 0x6819
  SubSys ID: 0xE221174B
  Revision ID: 0x0000
 Driver Strong Name: oem21.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_R575B:13.152.1.8000:pci\ven_1002&dev_6819
  Rank Of Driver: 00E62001
  Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
  D3D9 Overlay: Not Supported
  DXVA-HD: Not Supported
  DDraw Status: Enabled
  D3D Status: Enabled
  AGP Status: Enabled
  Card name: Intel(R) HD Graphics 4000
  Manufacturer: Intel Corporation
  Chip type: Intel(R) HD Graphics Family
  DAC type: Internal
  Device Key: Enum\PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09
  Display Memory: 1696 MB
  Dedicated Memory: 64 MB
  Shared Memory: 1632 MB
  Monitor Model: S22D390
  Monitor Id: SAM0B62
  Output Type: HD15
  Driver Name: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10umd32
Driver File Version: 9.17.0010.2932 (English)
  Driver Version: 9.17.10.2932
  DDI Version: 11
  Driver Date/Size: 12/14/2012 03:42:34, 12615680 bytes
  WHQL Logo'd: Yes
  WHQL Date Stamp:
  Device Identifier: {D7B78E66-4222-11CF-8D70-6821B7C2C435}
  Vendor ID: 0x8086
  Device ID: 0x0162
   SubSys ID: 0x01621849
  Revision ID: 0x0009
 Driver Strong Name: oem23.inf:Intel.Mfg.NTamd64:iIVBD0:9.17.10.2932:pci\ven_8086&dev_0162
  Rank Of Driver: 00E02001
  Video Accel: ModeMPEG2_A ModeMPEG2_C ModeWMV9_C ModeVC1_C
  D3D9 Overlay: Supported
  DXVA-HD: Supported
  D3D Status: Enabled
  AGP Status: Enabled
  Drive: E:
 Free Space: 460.6 GB
Total Space: 953.9 GB
File System: NTFS
  Model: Seagate FreeAgent GoFlex USB Device
System Devices
  Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E26
Device ID: PCI\VEN_8086&DEV_1E26&SUBSYS_1E261849&REV_04\3&11583659&0&E8
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_1E02&SUBSYS_1E021849&REV_04\3&11583659&0&FA
  Driver: n/a
  Name: High Definition Audio Controller
Device ID: PCI\VEN_1002&DEV_AAB0&SUBSYS_AAB0174B&REV_00\4&15001D53&0&0108
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family SMBus Host Controller - 1E22
Device ID: PCI\VEN_8086&DEV_1E22&SUBSYS_1E221849&REV_04\3&11583659&0&FB
  Driver: n/a
  Name: Intel(R) HD Graphics 4000
Device ID: PCI\VEN_8086&DEV_0162&SUBSYS_01621849&REV_09\3&11583659&0&10
  Driver: n/a
  Name: AMD Radeon HD 7800 Series
Device ID: PCI\VEN_1002&DEV_6819&SUBSYS_E221174B&REV_00\4&15001D53&0&0008
  Driver: n/a
Device ID: PCI\VEN_8086&DEV_1E20&SUBSYS_18981849&REV_04\3&11583659&0&D8
  Driver: n/a
  Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor PCI Express Root Port - 0151
Device ID: PCI\VEN_8086&DEV_0151&SUBSYS_01511849&REV_09\3&11583659&0&08
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 8 - 1E1E
Device ID: PCI\VEN_8086&DEV_1E1E&SUBSYS_1E1E1849&REV_C4\3&11583659&0&E7
  Driver: n/a
  Name: Xeon(R) processor E3-1200 v2/3rd Gen Core processor DRAM Controller - 0150
Device ID: PCI\VEN_8086&DEV_0150&SUBSYS_01501849&REV_09\3&11583659&0&00
  Driver: n/a
  Name: Intel(R) Z77 Express Chipset LPC Controller - 1E44
Device ID: PCI\VEN_8086&DEV_1E44&SUBSYS_1E441849&REV_04\3&11583659&0&F8
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 6 - 1E1A
Device ID: PCI\VEN_8086&DEV_1E1A&SUBSYS_1E1A1849&REV_C4\3&11583659&0&E5
  Driver: n/a
  Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1B21&DEV_1080&SUBSYS_10801849&REV_03\4&C7A4F95&0&00E5
  Driver: n/a
  Name: Intel(R) Management Engine Interface
Device ID: PCI\VEN_8086&DEV_1E3A&SUBSYS_1E3A1849&REV_04\3&11583659&0&B0
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 5 - 1E18
Device ID: PCI\VEN_8086&DEV_1E18&SUBSYS_1E181849&REV_C4\3&11583659&0&E4
  Driver: n/a
  Name: ASMedia XHCI Controller
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_10421849&REV_00\4&37A73C8A&0&00E7
  Driver: n/a
  Name: Intel(R) USB 3.0 eXtensible Host Controller
Device ID: PCI\VEN_8086&DEV_1E31&SUBSYS_1E311849&REV_04\3&11583659&0&A0
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 4 - 1E16
Device ID: PCI\VEN_8086&DEV_1E16&SUBSYS_1E161849&REV_C4\3&11583659&0&E3
  Driver: n/a
  Name: Asmedia 106x SATA Controller
Device ID: PCI\VEN_1B21&DEV_0612&SUBSYS_06121849&REV_01\4&33B94F4C&0&00E3
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family USB Enhanced Host Controller - 1E2D
Device ID: PCI\VEN_8086&DEV_1E2D&SUBSYS_1E2D1849&REV_04\3&11583659&0&D0
  Driver: n/a
  Name: Intel(R) 7 Series/C216 Chipset Family PCI Express Root Port 1 - 1E10
Device ID: PCI\VEN_8086&DEV_1E10&SUBSYS_1E101849&REV_C4\3&11583659&0&E0
  Driver: n/a
  Name: Broadcom NetLink (TM) Gigabit Ethernet
Device ID: PCI\VEN_14E4&DEV_16B1&SUBSYS_96B11849&REV_10\4&2B8260C3&0&00E4
  Driver: n/a
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.18741
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7601.17514
Fraps Video Decompressor,0x00200000,1,1,qcap.dll,6.06.7601.17514
Logitech Video (I420),0x00200000,1,1,qcap.dll,6.06.7601.17514
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Lagarith Lossless Codec,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7601.17514
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7601.17514
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.18741
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.18741
WDM Streaming Capture Devices:
Realtek HD Audio Front Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
XSplit Wave,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
HD Webcam C525,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Logitech HD Webcam C525,0x00200000,2,2,ksproxy.ax,6.01.7601.17514
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
Video Capture Sources:
WDM Streaming Communication Transforms:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
  Enabled:
  Force throttling
  Allow half deinterlace
  Allow scaling
  Decode Power Usage: 100
  Balanced Flags: 1424
  Enabled:
  Force throttling
  Allow batching
  Force half deinterlace
  Force scaling
  Decode Power Usage: 50
  PowerFlags: 1424
  Enabled:
  Force throttling
  Allow batching
  Force scaling
  Decode Power Usage: 0
Bump. Please let me know if there's a better way for me to organize the information to get an answer from someone
PC specs?
System Information
Memory: 16384MB RAM
Display Devices
Monitor Id: SAM08D9
Output Type: HD15
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x1002
Device ID: 0x6819
Revision ID: 0x0000
D3D Status: Enabled
AGP Status: Enabled
DAC type: Internal
Monitor Id: SAM0B62
Output Type: HD15
DDI Version: 11
WHQL Logo'd: Yes
WHQL Date Stamp:
Vendor ID: 0x8086
Device ID: 0x0162
Revision ID: 0x0009
DXVA-HD: Supported
D3D Status: Enabled
AGP Status: Enabled
Drive: E:
File System: NTFS
System Devices
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Driver: n/a
Video Compressors:
Midi Renderers:
Quality Flags: 2576
Enabled:
Force throttling
Allow scaling
Enabled:
Force throttling
Allow batching
Force scaling
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
