Hi !
As title says, it seems I have an artifact issue while recording, plus the overall is quite bad. I guess you don't need my specs since I assume they're in the logs. Here they are : https://gist.github.com/anonymous/43baca2bc5fa05a27173
If you need a sample of my stream, you can find it here : http://www.twitch.tv/samath24/b/528746779 ( no sound, it's intended. Tested it prior, it was fine ).
Speedtest, just in case : http://www.speedtest.net/my-result/3500666881.
What should I do ?
Thank you in advance !
What should I do ?
