Question / Help need help with odd lag
phyconate
So im streaming to twitch and im using obs and a elgato hd60 what is very weird is that when ever the game goes to a black screen like a loading screen or coming out of a cinematic screen or after a death when the game goes back to normal theres always this weird lag with both video and audio it also happens right before going to a dark screen ive never seen this before and im using windows 10 so that could be part of the problem i dont know but if anyone could help me out that would be awesome!!!
heres my log from my last session
https://gist.github.com/12e20232a366507fc287
FerretBomb
Nothing looks wrong with OBS according to that log. I'd assume something is going weird with the Elgato. USB 2.0 capture devices have to pre-encode video to fit over the rather restrictive USB 2.0 bus. So if it's not handling the transitions well, that could do it. I'd recommend recording a demonstration video, and contacting Elgato support.
phyconate
alright yea i mean i pluged it into a 3.0 usb but i dont think thats going to do anything i just not sure whats going on it use to be fine too and now its going weird so i was hoping it was something i was doing wrong tbh
FerretBomb
Nope, it's a USB 2.0 device. Plugging it into a 3.0 slot will do nothing, as it doesn't have the extra pins needed to take advantage of 3.0. Some devices will actually malfunction when plugged into a 3.0 port (most notably the Logitech c920) but not in a 2.0 port.
