Hello guys,
So i tried (maybe )everything to get a better video quality , but it's just crap overall...how can i improove it? Here is my internet connection download / upload speed http://i.imgur.com/RiAEhXH.jpg ( according to speedtest.net ).
My pc spec's :
Monitor 1680x1050 ( main resolution )
CPU - amd fx 6300 ( not oc'ed )
GPU - gtx 660 twin frozr ( not oce'd )
RAM - 8gb DDR3 , DUAL , NB Frequancy 2006 mhz or DRAM Frequancy 807mhz ( i just copye'd what i saw on program ;_;)
Motherboard - M5A97 LE R2.0 ( asus )
PSU - 650W
CPU Cooler - evo 212
According to obs estimator , these the stats i should be running -
CPU ADVICE -
Here are some videos i uploaded to youtoube for the quality check - https://www.youtube.com/watch?v=CvkGSIFrZXE&feature=youtu.be ////// https://www.youtube.com/watch?v=RTiMeQHF0lY&feature=youtu.be /// EVERYTHING IS IN THE DESCRIPTION BOX FOR WHAT OBS SETTINGS I USED. Sorry for the long letter,but it's better to tell everything,when u'l get less question , and u'l get straight answers :)
Thanks all,
Sincerely,
eTno
My pc spec's :
PSU - 650W
CPU ADVICE -
- Set FPS to 25
- Try to aim for the highest bitrate possible for high motion games
- Use game capture if possible for maximum performance.
- Use window capture with Aero enabled if game capture is unavailable.
- Your upload speed is sufficient for 720p / 1080p
- Enable CFR for compatibility with streaming services
- Enable CBR for improved stream stability
- Recommended max bitrate: 3500
- Recommended buffer size: 3500
Thanks all,
Sincerely,
eTno
