Question / Help Need help with audio sounds underwater
22:43:03.578: WASAPI: Device 'Microphone Array (Realtek(R) Audio)' [48000 Hz] initialized
What is this actually? OBS doesn't do anything with the audio unless you tell it to -- if it's being fed garbled audio, it will record garbled audio.
Sounds like you may have a Noise Suppression filter applied. The normal speech sounds OK but when the tune plays the filter sees that as noise.
is that not just the mic in my laptop plus its muted in obs and ive tried to remove it and record and still same issuse
