Question / Help Need help tweaking my settings to get more quality out of it
vswifty
Here's an Example video of my settings
http://www.twitch.tv/vmrswifty/b/504565571
And here's the VOD analyzer results
http://r-1.ch/analyze-twitch-vod.php?url=http://www.twitch.tv/vmrswifty/b/504565571
Here are my OBS settings
Here's a pic of my specs via Speccy
http://puu.sh/71JeT.png
And here's a pic of my Speedtest results
If anything else is needed I'd be glad to post, Been trying to figure out how to get rid of pixels splotches on my stream and been trying to atleast make the stream a bit sharper. Thanks!
dodgepong
Administrator
Community Helper
Re: Need help tweaking my settings to get more quality out o
First of all, you're on a very outdated version of OBS. 0.533b had a bug that disabled the auto-updater, so you'll need to update manually. The latest version is 0.612b as of this writing.
I'm not sure why you're using MP3 audio. AAC is better in pretty much every way.
You will bet better quality by streaming at 540p, though. In fact, I think that six-core might be able to stream at 720p, if you give it a shot. It would be easier to tell once you try it out and get an updated log from 0.612b.
vswifty
Here's an updated log with the latest version of OBS
http://pastebin.com/Q8fnHvt7
http://www.twitch.tv/vmrswifty/b/507197720
EDIT: Now it's showing up ^
For some reason the recent broadcast isn't showing up on Twitch.
dodgepong
Administrator
Community Helper
That looks like a great stream, though it would probably be better if it were 30fps.
