Hey guys, I'm not really sure what I am doing on OBS yet. There are a few options I have no idea what they do and after a few hours of tweaking and changing stuff I can't seem to improve anything noticeably. I'm going to post my specs and internet speed below and hopefully some of you can recommend some settings for me to try. I'm using the test client of OBS for the mic silence option.
Specs:
Processor: Core™ i7-2600K Processor, 4GHz w/ 8MB Cache
CPU Cooler: H100 Corsair Liquid Cooler
Motherboard: GA-Z68X-UD3H-B3
Memory: Vengeance LP 16GB DDR3 1600MHz
Videocard: GTX 570 1.2 GB DDR5
These are my current OBS settings.
Video Encoding:
Use CBR: unchecked
Quality Balance: 10
Max Bitrate: 1400
Buffer Size: 1400
Audio Encoding:
ACC 128 bitrate
Video:
1366 x 768 (Yea this is my recommended resolution for my monitor 32") =/
Resolution Downscale: None.
FPS: 30 (I tried 60 with no drop frames or lag)
Advanced:
Use Multithreaded Optimizations
Process Priority Class: Above Normal
Scene buffering time: 400
Video:
x264 CPU preset: Fast
Use CFR: checked
What I'm trying to do is fix my stream quality to make it more clear, I use to stream like 7 months ago with the same internet speed on dayz. I'm trying to stream CS:GO, from what people say its clear when I'm standing still and not moving. But when I start moving around and shooting at people it gets pixel and isn't so clear anymore.
I'm open to all suggestions anything will help if you can, thanks.
Specs:
Video Encoding:
Use CBR: unchecked
Quality Balance: 10
Max Bitrate: 1400
Buffer Size: 1400
Audio Encoding:
ACC 128 bitrate
Video:
Advanced:
Video:
Use CFR: checked
