Question / Help Need help to get a better quality on my stream
sbimz
Hey,
I finally got a good internet (100/50 fiber) for streaming, my stream run fine but the quality seems low to me for the preset i use :
20:26:34: Open Broadcaster Software v0.542b - 32bit (´・ω・`)
20:26:34: -------------------------------
20:26:34: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
20:26:34: CPU Speed: 3300MHz
20:26:34: Physical Memory:  4095MB Total, 4095MB Free
20:26:34: stepping id: 7, model 10, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
20:26:34: monitor 1: pos={0, 0}, size={1920, 1200}
20:26:34: monitor 2: pos={1920, 0}, size={1366, 768}
20:26:34: Windows Version: 6.1 Build 7601 S
20:26:34: Aero is Enabled
20:26:34: OBS Modules:
20:26:34: Base Address     Module
20:26:34: 00070000         OBS.exe
20:26:34: 67C00000         OBSApi.dll
20:26:34: 69180000         DShowPlugin.dll
20:26:34: 6D820000         GraphicsCapture.dll
20:26:34: 69160000         NoiseGate.dll
20:26:34: 69000000         PSVPlugin.dll
20:26:34: ------------------------------------------
20:26:34: Adapter 1
20:26:34:   Video Adapter: NVIDIA GeForce GTX 660 Ti
20:26:34:   Video Adapter Dedicated Video Memory: 2086993920
20:26:34:   Video Adapter Shared System Memory: 2147807232
20:26:34: =====Stream Start: 2013-08-02, 20:26:34===============================================
20:26:34:   Multithreaded optimizations: On
20:26:34:   Base resolution: 1920x1200
20:26:34:   Output resolution: 1536x960
20:26:34: Loading up D3D10...
20:26:34: Playback device {0.0.0.00000000}.{0ea65fdf-9278-43e3-b896-681b3bb2b210}
20:26:34: Using desktop audio input: Line 1 (Breakaway Pipeline)
20:26:34: Using auxilary audio input: Microphone (Yeti Stereo Microphone)
20:26:34: Audio Encoding: AAC
20:26:34:     bitrate: 192
Warning -- D3D10Texture::CreateFromFile: Could not get information about texture file 'C:\Users\v1\Desktop\images.jpg'
Warning -- BitmapImageSource::UpdateSettings: could not create texture 'C:\Users\v1\Desktop\images.jpg'
20:26:34: Using bitmap image
20:26:34: Using graphics capture
20:26:34: Video Encoding: x264
20:26:34:     fps: 30
20:26:34:     width: 1536, height: 960
20:26:34:     preset: veryfast
20:26:34:     CBR: yes
20:26:34:     CFR: no
20:26:34:     max bitrate: 3500
20:26:34: SharedTexCapture hooked
20:26:36: Using RTMP service: Twitch / Justin.tv
20:26:36:   Server selection: rtmp://live-fra.justin.tv/app
20:26:38: SO_SNDBUF was at 8192
20:26:38: SO_SNDBUF is now 65536
20:32:29: GraphicsCaptureSource::NewCapture:  eliminating old capture
20:32:29: SharedTexCapture hooked
20:33:00: Using bitmap image
23:53:06: Total frames rendered: 370940, number of frames that lagged: 999 (0.27%) (it's okay for some frames to lag)
23:53:06: RTMPPublisher::SocketLoop: Aborting due to bStopping
23:53:06: Number of times waited to send: 0, Waited for a total of 0 bytes
23:53:06: Number of b-frames dropped: 0 (0%), Number of p-frames dropped: 0 (0%), Total 0 (0%)
23:53:06: =====Stream End: 2013-08-02, 23:53:06=================================================
00:02:04:
00:02:04: Profiler results:
00:02:04:
00:02:04: ==============================================================
00:02:04: frame - [100%] [avg time: 3.326 ms (cpu time: avg 1.421 ms, total 527377 ms)] [avg calls per frame: 1] [children: 99.6%] [unaccounted: 0.421%]
00:02:04: | frame preprocessing and rendering - [4.66%] [avg time: 0.155 ms (cpu time: avg 0.055 ms, total 20576.5 ms)] [avg calls per frame: 1] [children: 0.12%] [unaccounted: 4.54%]
00:02:04: | | scene->Preprocess - [0.12%] [avg time: 0.004 ms (cpu time: avg 0.002 ms, total 920.409 ms)] [avg calls per frame: 1]
00:02:04: | video encoding and uploading - [94.9%] [avg time: 3.157 ms (cpu time: avg 1.364 ms, total 506208 ms)] [avg calls per frame: 1] [children: 92.1%] [unaccounted: 2.86%]
00:02:04: | | flush - [29.7%] [avg time: 0.987 ms (cpu time: avg 0.034 ms, total 12948.1 ms)] [avg calls per frame: 1]
00:02:04: | | CopyResource - [5.38%] [avg time: 0.179 ms (cpu time: avg 0.013 ms, total 5116.83 ms)] [avg calls per frame: 0]
00:02:04: | | conversion to 4:2:0 - [2.53%] [avg time: 0.084 ms (cpu time: avg 0.005 ms, total 2028.01 ms)] [avg calls per frame: 0]
00:02:04: | | call to encoder - [53.3%] [avg time: 1.773 ms (cpu time: avg 1.275 ms, total 473292 ms)] [avg calls per frame: 0]
00:02:04: | | sending stuff out - [1.17%] [avg time: 0.039 ms (cpu time: avg 0.017 ms, total 6552.03 ms)] [avg calls per frame: 0]
00:02:04: | Convert444Threads - [2.01e+003%] [avg time: 66.803 ms (cpu time: avg 1.111 ms, total 412233 ms)] [avg calls per frame: 1]
00:02:04:
The vod of the stream i made yesterday : http://fr.twitch.tv/sbimz/b/439781569
My cpu was going up to 95% load when i stream (i5 2500k @4.4ghz), but it's guild wars 2 who take most of it.
Do you think i can get a better quality by tweaking some things?
sbimz
Thanks i say that because i've seen some streams at 720p and probably lower bitrate looking better, that's why i am wondering, but for sure it's already decent. :)
Is it because they use something better than the "veryfast" preset?
EDIT : oh and i just noticed i use the standart filter for downscaling, i just switched to lanczos may be it will help and not stress my cpu too much
EDIT2 : yeah the lanczos filter gave me slightly better quality
