Question / Help Need Help Setting Up Streaming On Twitch With OBS
mayhembro
I'm recently been getting into broadcasting, my question overall is what are the best settings for a high quality no lagging stream based on my equipment and connection for Xbox 360.
On The PC :
Open Broadcasting Software (64 Bit)
2.0 Upload speed
AMD A8-4500M APU Processor
1.9GHz,
AMD Radeon HD 7640G GFX card
Hardware :
Elgato Game Capture
Guitar Hero Microphone
Xbox 360
I Need To Know What My (Blank) Needs To Be Or Is :
Max bit Rate
Max Buffer Size
Quality Balance (Unless I need to use CBR)
Codec For Audio
Bitrate For Audio
Format For Audio (If I need one) I want to add that last stream my audio was behind my video
Highest Base Resolution (With no lag on stream)
Highest FPS (With no lag on stream)
Do I Need To Use :
CBR Padding
I will be playing games like call of duty and multiple MMOs and lots of fast paced high action games.stuff like that. Also I need to be able to play online with no lag while streaming.
Thanks in advance!
