Question / Help Need Help Opimizing OBS For My System
Vizaruu
Hello guys, I'm a new streamer and I'm looking for ways I can improve my performance while streaming. I have no issues with games frames or audio and my stream at the settings I have now isn't too bad but i occasionally will get choppy and lag a tad bit. Hopefully with the information i provide you can help me optimize the settings to work best for me.
|Network|
Upload:
4.5MBPS
Download: 35MBPS
|System|
CPU: Intel Core i5-2500K @ 3.3GHZ
RAM: 8GB DDR3 @1600MHZ
GPU: SLI 660ti
FULL LOG
19:17:11: Open Broadcaster Software v0.653b - 64bit ( ^ω^)
19:17:11: -------------------------------
19:17:11: CPU Name: Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz
19:17:11: CPU Speed: 3292MHz
19:17:11: Physical Memory: 8109MB Total, 5180MB Free
19:17:11: stepping id: 7, model 42, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 4, total cores 4
19:17:11: monitor 1: pos={0, 0}, size={1920, 1080}
19:17:11: Windows Version: 6.1 Build 7601 S
19:17:11: Aero is Enabled
19:17:11: OBS Modules:
19:17:11: Base Address Module
19:17:11: 000000003F5F0000 OBS.exe
19:17:11: 00000000FA0F0000 OBSApi.dll
19:17:11: 00000000FA930000 DShowPlugin.dll
19:17:11: 00000000FA0B0000 GraphicsCapture.dll
19:17:11: 00000000FA900000 NoiseGate.dll
19:17:11: 00000000FA640000 PSVPlugin.dll
19:17:11: 00000000FA080000 scenesw.dll
19:17:11: ------------------------------------------
19:17:11: Adapter 1
19:17:11: Video Adapter: NVIDIA GeForce GTX 660 Ti
19:17:11: Video Adapter Dedicated Video Memory: 2049859584
19:17:11: Video Adapter Shared System Memory: 2147807232
19:17:11: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
19:17:11: =====Stream Start: 2015-07-24, 19:17:11===============================================
19:17:11: Multithreaded optimizations: On
19:17:11: Base resolution: 1920x1080
19:17:11: Output resolution: 1280x720
19:17:11: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti (Adapter 1)...
19:17:11: Audio Format: 44100 Hz
19:17:11: Audio Channels: 2 Ch
19:17:11: Playback device Default
19:17:11: Using desktop audio input: Speakers (Siberia v2 Frost Blue)
19:17:11: Global Audio time adjust: 0
19:17:11: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
19:17:11: Mic time offset: 0
19:17:11: Audio Encoding: MP3
19:17:11: bitrate: 128
19:17:11: Using graphics capture
19:17:11: Scene buffering time set to 400
19:17:11: Video Encoding: x264
19:17:11: fps: 30
19:17:11: width: 1280, height: 720
19:17:11: preset: veryfast
19:17:11: profile: main
19:17:11: keyint: 60
19:17:11: CBR: yes
19:17:11: CFR: yes
19:17:11: max bitrate: 2500
19:17:11: buffer size: 2500
19:17:24: Using Window Capture
19:17:40: Total frames encoded: 842, total frames duplicated: 0 (0.00%)
19:17:40: Total frames rendered: 856, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
19:17:40:
19:17:40: Profiler time results:
19:17:40:
19:17:40: ==============================================================
19:17:40: video thread frame - [100%] [avg time: 1.012 ms] [children: 69.9%] [unaccounted: 30.1%]
19:17:40: | scene->Preprocess - [58.1%] [avg time: 0.588 ms]
19:17:40: | GPU download and conversion - [11.8%] [avg time: 0.119 ms] [children: 11.1%] [unaccounted: 0.692%]
19:17:40: | | flush - [10.6%] [avg time: 0.107 ms]
19:17:40: | | CopyResource - [0.395%] [avg time: 0.004 ms]
19:17:40: | | conversion to 4:2:0 - [0.0988%] [avg time: 0.001 ms]
19:17:40: Convert444Threads - [100%] [avg time: 0.389 ms] [children: 99.2%] [unaccounted: 0.771%]
19:17:40: | Convert444toNV12 - [99.2%] [avg time: 0.386 ms]
19:17:40: encoder thread frame - [100%] [avg time: 0.636 ms] [children: 0.472%] [unaccounted: 99.5%]
19:17:40: | sending stuff out - [0.472%] [avg time: 0.003 ms]
19:17:40:
19:17:40:
19:17:40: Profiler CPU results:
19:17:40:
19:17:40: video thread frame - [cpu time: avg 0.2 ms, total 171.601 ms] [avg calls per frame: 1]
19:17:40: | scene->Preprocess - [cpu time: avg 0.018 ms, total 15.6 ms] [avg calls per frame: 1]
19:17:40: | GPU download and conversion - [cpu time: avg 0.018 ms, total 15.6 ms] [avg calls per frame: 1]
19:17:40: | | flush - [cpu time: avg 0.018 ms, total 15.6 ms] [avg calls per frame: 1]
19:17:40: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:17:40: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:17:40: Convert444Threads - [cpu time: avg 0.083 ms, total 140.4 ms] [avg calls per frame: 2]
19:17:40: | Convert444toNV12 - [cpu time: avg 0.083 ms, total 140.4 ms] [avg calls per frame: 2]
19:17:40: encoder thread frame - [cpu time: avg 0.037 ms, total 31.2 ms] [avg calls per frame: 1]
19:17:40: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:17:40:
19:17:40: =====Stream End: 2015-07-24, 19:17:40=================================================
19:17:40: =====Stream Start: 2015-07-24, 19:17:40===============================================
19:17:40: Multithreaded optimizations: On
19:17:40: Base resolution: 1920x1080
19:17:40: Output resolution: 1280x720
19:17:40: ------------------------------------------
19:17:40: Loading up D3D10 on NVIDIA GeForce GTX 660 Ti (Adapter 1)...
19:17:40: Audio Format: 44100 Hz
19:17:40: Audio Channels: 2 Ch
19:17:40: Playback device Default
19:17:40: Using desktop audio input: Speakers (Siberia v2 Frost Blue)
19:17:40: Global Audio time adjust: 0
19:17:40: Using auxilary audio input: Microphone (Siberia v2 Frost Blue)
19:17:40: Mic time offset: 0
19:17:40: Audio Encoding: MP3
19:17:40: bitrate: 128
19:17:40: Using Window Capture
19:17:40: Using graphics capture
19:17:40: Scene buffering time set to 400
19:17:40: Video Encoding: x264
19:17:40: fps: 30
19:17:40: width: 1280, height: 720
19:17:40: preset: veryfast
19:17:40: profile: main
19:17:40: keyint: 60
19:17:40: CBR: yes
19:17:40: CFR: yes
19:17:40: max bitrate: 2500
19:17:40: buffer size: 2500
19:17:56: No Intel graphics adapter visible in QSVHelper.exe, Optimus problem?
19:17:56: CUDA loaded successfully
19:17:56: 2 CUDA capable devices found
19:17:56: [ GPU #0 - < GeForce GTX 660 Ti > has Compute SM 3.0, NVENC Available ]
19:17:56: [ GPU #1 - < GeForce GTX 660 Ti > has Compute SM 3.0, NVENC Available ]
19:24:07: Total frames encoded: 11593, total frames duplicated: 0 (0.00%)
19:24:07: Total frames rendered: 11608, number of late frames: 1 (0.01%) (it's okay for some frames to be late)
19:24:07:
19:24:07: Profiler time results:
19:24:07:
19:24:07: ==============================================================
19:24:07: video thread frame - [100%] [avg time: 1.379 ms] [children: 79.3%] [unaccounted: 20.7%]
19:24:07: | scene->Preprocess - [68.7%] [avg time: 0.947 ms]
19:24:07: | GPU download and conversion - [10.7%] [avg time: 0.147 ms] [children: 10%] [unaccounted: 0.653%]
19:24:07: | | flush - [9.64%] [avg time: 0.133 ms]
19:24:07: | | CopyResource - [0.29%] [avg time: 0.004 ms]
19:24:07: | | conversion to 4:2:0 - [0.0725%] [avg time: 0.001 ms]
19:24:07: Convert444Threads - [100%] [avg time: 0.348 ms] [children: 99.1%] [unaccounted: 0.862%]
19:24:07: | Convert444toNV12 - [99.1%] [avg time: 0.345 ms]
19:24:07: encoder thread frame - [100%] [avg time: 0.685 ms] [children: 0.292%] [unaccounted: 99.7%]
19:24:07: | sending stuff out - [0.292%] [avg time: 0.002 ms]
19:24:07:
19:24:07:
19:24:07: Profiler CPU results:
19:24:07:
19:24:07: video thread frame - [cpu time: avg 0.399 ms, total 4633.23 ms] [avg calls per frame: 1]
19:24:07: | scene->Preprocess - [cpu time: avg 0.02 ms, total 234.003 ms] [avg calls per frame: 1]
19:24:07: | GPU download and conversion - [cpu time: avg 0.006 ms, total 78.001 ms] [avg calls per frame: 1]
19:24:07: | | flush - [cpu time: avg 0.004 ms, total 46.801 ms] [avg calls per frame: 1]
19:24:07: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:24:07: | | conversion to 4:2:0 - [cpu time: avg 0.001 ms, total 15.6 ms] [avg calls per frame: 1]
19:24:07: Convert444Threads - [cpu time: avg 0.042 ms, total 982.805 ms] [avg calls per frame: 2]
19:24:07: | Convert444toNV12 - [cpu time: avg 0.042 ms, total 982.805 ms] [avg calls per frame: 2]
19:24:07: encoder thread frame - [cpu time: avg 0.012 ms, total 140.4 ms] [avg calls per frame: 1]
19:24:07: | sending stuff out - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
19:24:07:
19:24:07: =====Stream End: 2015-07-24, 19:24:07=================================================
You can unfortunately pretty much only do the usual:
  • Lower resolution or even the fps slightly (although 30 should be good)
  • Lower the compression (not really recommandable for streaming)
  • Lower game settings
  • Buy more powerful hardware
In general your settings are fine for your PC but heavy games can always be a problem. You could also use nvenc but it would probably have a negative effect on the quality of your stream.
I mean I think my rigg is pretty powerful for streaming..
I am going to be doing a CPU upgrade soon to a i7 extreme 6-core. But i dont need to upgrade my video cards or RAM I dont think...
