Question / Help Need help fiquring out my problems
Torgue
so my problem is I have been dropping frames like crazy, it doesn't matter how low I put my bitrate either I have tested at 1000 bitrate up 3000 bitrate all with a resolution of 720p to 1080p, but I still drop frames I just got off an hour long phone call with my internet provider Charter and the tech I was with did various ping, trace routes and something called reverse route. But he said there was no pocket lose on their end at all not to mention my upload speed usually is around 4.2 on testmy.net right before i try and stream. I also just about a new router its a Linksys EA6500 but I lose frames with the router or without the router. so I'm at a lose on what is causing my problems.
And yes I have also changed servers on obs I have tried the San francisco and Los Angeles because they normally show a ping of 64.
here is my recent stream log
21:28:06: Server Ping plugin strings not found, dynamically loading 24 strings
21:28:06: Video Source Plugin strings not found, dynamically loading 38 strings
21:30:10: Open Broadcaster Software v0.592b - 64bit ( ^ω^)
21:30:10: -------------------------------
21:30:10: CPU Name: Intel(R) Core(TM) i7 CPU         930  @ 2.80GHz
21:30:10: CPU Speed: 2786MHz
21:30:10: Physical Memory:  6135MB Total, 3467MB Free
21:30:10: stepping id: 5, model 26, family 6, type 0, extmodel 0, extfamily 0, HTT 1, logical cores 8, total cores 4
21:30:10: monitor 1: pos={-1024, 0}, size={1024, 768}
21:30:10: monitor 2: pos={0, 0}, size={1920, 1080}
21:30:10: Windows Version: 6.1 Build 7601 S
21:30:10: Aero is Enabled
21:30:10: OBS Modules:
21:30:10: Base Address     Module
21:30:10: 000000003F430000 OBS.exe
21:30:10: 00000000F3E50000 OBSApi.dll
21:30:10: 00000000F51F0000 DShowPlugin.dll
21:30:10: 00000000F4B40000 GraphicsCapture.dll
21:30:10: 00000000FB220000 NoiseGate.dll
21:30:10: 00000000F8920000 PSVPlugin.dll
21:30:10: 00000000F4C60000 ServerPingPlugin.dll
21:30:10: 00000000F88C0000 VideoSourcePluginWrapper.dll
21:30:10: ------------------------------------------
21:30:10: Adapter 1
21:30:10:   Video Adapter: NVIDIA GeForce GTX 460
21:30:10:   Video Adapter Dedicated Video Memory: 1025048576
21:30:10:   Video Adapter Shared System Memory: 2948165632
21:30:10:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
21:30:10: Adapter 2
21:30:10:   Video Adapter Dedicated Video Memory: 1024917504
21:30:10:   Video Adapter Output 1: pos={-1024, 0}, size={1024, 768}, attached=true
21:30:10: =====Stream Start: 2014-01-18, 21:30:10===============================================
21:30:10:   Multithreaded optimizations: On
21:30:10:   Base resolution: 1920x1080
21:30:10:   Output resolution: 1280x720
21:30:10: Loading up D3D10 on NVIDIA GeForce GTX 460 (Adapter 1)...
21:30:10: Audio Format: 44100hz
21:30:10: Playback device Default
21:30:10: Using desktop audio input: Speakers (3- Razer Megalodon)
21:30:10: Using 7.1 surround speaker setup
21:30:10: Using auxilary audio input: Microphone (3- Samson Meteor Mic)
21:30:10: Audio Encoding: AAC
21:30:10:     bitrate: 112
21:30:10: Using bitmap image
21:30:10: Scene buffering time set to 700
21:30:10: Video Encoding: x264
21:30:10:     fps: 30
21:30:10:     width: 1280, height: 720
21:30:10:     preset: veryfast
21:30:10:     profile: main
21:30:10:     keyint: 60
21:30:10:     CBR: yes
21:30:10:     CFR: yes
21:30:10:     max bitrate: 1800
21:30:10:     buffer size: 1800
21:30:10: MMDeviceAudioSource: Frequency for device 'Speakers (3- Razer Megalodon)' is 1536000, samples per sec is 48000
21:30:10: MMDeviceAudioSource: Frequency for device 'Microphone (3- Samson Meteor Mic)' is 352800, samples per sec is 44100
21:30:13: Using RTMP service: Twitch / Justin.tv
21:30:13:   Server selection: rtmp://live.justin.tv/app
21:30:13:   Interface: Realtek PCIe GBE Family Controller #2 (ethernet, 1000 mbps)
21:30:13: Completed handshake with rtmp://live.justin.tv/app in 134 ms.
21:30:14: SO_SNDBUF was at 8192
21:30:14: SO_SNDBUF is now 65536
21:30:20: RTMPPublisher::SocketLoop: Stalled for 2595 ms to write 241836 bytes (buffer: 0 / 244736), unstable connection?
21:30:22: RTMPPublisher::SocketLoop: Stalled for 2183 ms to write 243620 bytes (buffer: 0 / 244736), unstable connection?
21:30:25: RTMPPublisher::SocketLoop: Stalled for 1949 ms to write 243944 bytes (buffer: 0 / 244736), unstable connection?
21:30:28: RTMPPublisher::SocketLoop: Stalled for 1611 ms to write 236442 bytes (buffer: 0 / 244736), unstable connection?
21:30:30: RTMPPublisher::SocketLoop: Stalled for 2177 ms to write 244340 bytes (buffer: 0 / 244736), unstable connection?
21:30:32: RTMPPublisher::SocketLoop: Stalled for 1759 ms to write 244394 bytes (buffer: 0 / 244736), unstable connection?
21:30:34: RTMPPublisher::SocketLoop: Stalled for 2112 ms to write 243009 bytes (buffer: 0 / 244736), unstable connection?
21:30:37: RTMPPublisher::SocketLoop: Stalled for 3087 ms to write 241609 bytes (buffer: 0 / 244736), unstable connection?
21:30:39: RTMPPublisher::SocketLoop: Stalled for 2664 ms to write 242163 bytes (buffer: 0 / 244736), unstable connection?
21:30:41: RTMPPublisher::SocketLoop: Stalled for 1916 ms to write 243779 bytes (buffer: 0 / 244736), unstable connection?
21:30:44: RTMPPublisher::SocketLoop: Stalled for 2586 ms to write 241300 bytes (buffer: 0 / 244736), unstable connection?
21:30:46: RTMPPublisher::SocketLoop: Stalled for 2164 ms to write 244362 bytes (buffer: 0 / 244736), unstable connection?
21:30:48: RTMPPublisher::SocketLoop: Stalled for 1667 ms to write 240958 bytes (buffer: 0 / 244736), unstable connection?
21:30:50: RTMPPublisher::SocketLoop: Stalled for 2015 ms to write 241466 bytes (buffer: 0 / 244736), unstable connection?
21:30:53: RTMPPublisher::SocketLoop: Stalled for 3033 ms to write 240713 bytes (buffer: 0 / 244736), unstable connection?
21:30:55: RTMPPublisher::SocketLoop: Stalled for 1741 ms to write 244695 bytes (buffer: 0 / 244736), unstable connection?
21:30:56: RTMPPublisher::SocketLoop: Stalled for 1540 ms to write 242410 bytes (buffer: 0 / 244736), unstable connection?
21:30:58: RTMPPublisher::SocketLoop: Stalled for 1802 ms to write 242271 bytes (buffer: 0 / 244736), unstable connection?
21:31:00: RTMPPublisher::SocketLoop: Stalled for 2188 ms to write 242907 bytes (buffer: 0 / 244736), unstable connection?
21:31:02: RTMPPublisher::SocketLoop: Stalled for 1941 ms to write 243146 bytes (buffer: 0 / 244736), unstable connection?
21:31:05: RTMPPublisher::SocketLoop: Stalled for 2900 ms to write 240734 bytes (buffer: 0 / 244736), unstable connection?
21:31:07: RTMPPublisher::SocketLoop: Stalled for 2508 ms to write 241160 bytes (buffer: 0 / 244736), unstable connection?
21:31:10: RTMPPublisher::SocketLoop: Stalled for 2617 ms to write 242728 bytes (buffer: 0 / 244736), unstable connection?
21:31:12: RTMPPublisher::SocketLoop: Stalled for 2440 ms to write 244203 bytes (buffer: 0 / 244736), unstable connection?
21:31:14: RTMPPublisher::SocketLoop: Stalled for 1832 ms to write 242546 bytes (buffer: 0 / 244736), unstable connection?
21:31:17: RTMPPublisher::SocketLoop: Stalled for 2408 ms to write 243589 bytes (buffer: 0 / 244736), unstable connection?
21:31:19: RTMPPublisher::SocketLoop: Stalled for 2702 ms to write 244391 bytes (buffer: 0 / 244736), unstable connection?
21:31:22: RTMPPublisher::SocketLoop: Stalled for 2639 ms to write 240672 bytes (buffer: 0 / 244736), unstable connection?
21:31:24: RTMPPublisher::SocketLoop: Stalled for 2254 ms to write 242999 bytes (buffer: 0 / 244736), unstable connection?
21:31:27: RTMPPublisher::SocketLoop: Stalled for 2591 ms to write 240982 bytes (buffer: 0 / 244736), unstable connection?
21:31:30: RTMPPublisher::SocketLoop: Stalled for 2638 ms to write 243019 bytes (buffer: 0 / 244736), unstable connection?
21:31:31: RTMPPublisher::SocketLoop: Stalled for 1909 ms to write 243405 bytes (buffer: 0 / 244736), unstable connection?
21:31:33: RTMPPublisher::SocketLoop: Stalled for 1882 ms to write 244081 bytes (buffer: 0 / 244736), unstable connection?
21:31:35: RTMPPublisher::SocketLoop: Stalled for 1874 ms to write 243729 bytes (buffer: 0 / 244736), unstable connection?
21:31:37: RTMPPublisher::SocketLoop: Stalled for 1951 ms to write 244046 bytes (buffer: 0 / 244736), unstable connection?
21:31:39: RTMPPublisher::SocketLoop: Stalled for 2227 ms to write 241788 bytes (buffer: 0 / 244736), unstable connection?
21:31:41: RTMPPublisher::SocketLoop: Stalled for 1967 ms to write 241883 bytes (buffer: 0 / 244736), unstable connection?
21:31:44: RTMPPublisher::SocketLoop: Stalled for 2672 ms to write 242289 bytes (buffer: 0 / 244736), unstable connection?
21:31:46: RTMPPublisher::SocketLoop: Stalled for 1786 ms to write 243680 bytes (buffer: 0 / 244736), unstable connection?
21:31:48: RTMPPublisher::SocketLoop: Stalled for 2452 ms to write 242604 bytes (buffer: 0 / 244736), unstable connection?
21:31:50: RTMPPublisher::SocketLoop: Stalled for 2201 ms to write 244160 bytes (buffer: 0 / 244736), unstable connection?
21:31:53: RTMPPublisher::SocketLoop: Stalled for 2085 ms to write 233571 bytes (buffer: 0 / 244736), unstable connection?
21:31:56: RTMPPublisher::SocketLoop: Stalled for 2973 ms to write 241848 bytes (buffer: 0 / 244736), unstable connection?
21:32:00: RTMPPublisher::SocketLoop: Stalled for 3354 ms to write 241872 bytes (buffer: 0 / 244736), unstable connection?
21:32:02: RTMPPublisher::SocketLoop: Stalled for 1819 ms to write 244138 bytes (buffer: 0 / 244736), unstable connection?
21:32:04: RTMPPublisher::SocketLoop: Stalled for 2133 ms to write 241340 bytes (buffer: 0 / 244736), unstable connection?
21:32:06: RTMPPublisher::SocketLoop: Stalled for 2242 ms to write 243243 bytes (buffer: 0 / 244736), unstable connection?
21:32:08: RTMPPublisher::SocketLoop: Stalled for 1562 ms to write 240753 bytes (buffer: 0 / 244736), unstable connection?
21:32:12: RTMPPublisher::SocketLoop: Stalled for 4035 ms to write 243333 bytes (buffer: 0 / 244736), unstable connection?
21:32:14: RTMPPublisher::SocketLoop: Stalled for 1518 ms to write 242429 bytes (buffer: 0 / 244736), unstable connection?
21:32:16: RTMPPublisher::SocketLoop: Stalled for 1984 ms to write 242105 bytes (buffer: 0 / 244736), unstable connection?
21:32:18: RTMPPublisher::SocketLoop: Stalled for 2833 ms to write 241847 bytes (buffer: 0 / 244736), unstable connection?
21:32:20: RTMPPublisher::SocketLoop: Stalled for 2044 ms to write 242195 bytes (buffer: 0 / 244736), unstable connection?
21:32:22: RTMPPublisher::SocketLoop: Stalled for 2010 ms to write 242722 bytes (buffer: 0 / 244736), unstable connection?
21:32:25: RTMPPublisher::SocketLoop: Stalled for 2250 ms to write 242268 bytes (buffer: 0 / 244736), unstable connection?
21:32:27: RTMPPublisher::SocketLoop: Stalled for 2311 ms to write 242978 bytes (buffer: 0 / 244736), unstable connection?
21:32:29: RTMPPublisher::SocketLoop: Stalled for 1748 ms to write 242274 bytes (buffer: 0 / 244736), unstable connection?
21:32:30: RTMPPublisher::SocketLoop: Stalled for 1593 ms to write 242908 bytes (buffer: 0 / 244736), unstable connection?
21:32:34: RTMPPublisher::SocketLoop: Stalled for 2204 ms to write 243864 bytes (buffer: 0 / 244736), unstable connection?
21:32:37: RTMPPublisher::SocketLoop: Stalled for 1677 ms to write 216246 bytes (buffer: 0 / 244736), unstable connection?
21:32:41: RTMPPublisher::SocketLoop: Stalled for 2921 ms to write 241502 bytes (buffer: 0 / 244736), unstable connection?
21:32:43: RTMPPublisher::SocketLoop: Stalled for 2297 ms to write 244198 bytes (buffer: 0 / 244736), unstable connection?
21:32:46: RTMPPublisher::SocketLoop: Stalled for 2121 ms to write 243186 bytes (buffer: 0 / 244736), unstable connection?
21:32:48: RTMPPublisher::SocketLoop: Stalled for 2392 ms to write 241393 bytes (buffer: 0 / 244736), unstable connection?
21:32:50: RTMPPublisher::SocketLoop: Stalled for 2433 ms to write 243120 bytes (buffer: 0 / 244736), unstable connection?
21:32:53: RTMPPublisher::SocketLoop: Stalled for 2724 ms to write 241716 bytes (buffer: 0 / 244736), unstable connection?
21:32:56: RTMPPublisher::SocketLoop: Stalled for 2782 ms to write 243357 bytes (buffer: 0 / 244736), unstable connection?
21:32:58: RTMPPublisher::SocketLoop: Stalled for 2054 ms to write 243111 bytes (buffer: 0 / 244736), unstable connection?
21:33:02: RTMPPublisher::SocketLoop: Stalled for 2522 ms to write 244271 bytes (buffer: 0 / 244736), unstable connection?
21:33:03: RTMPPublisher::SocketLoop: Stalled for 1664 ms to write 240911 bytes (buffer: 0 / 244736), unstable connection?
21:33:05: RTMPPublisher::SocketLoop: Stalled for 1870 ms to write 229827 bytes (buffer: 0 / 244736), unstable connection?
21:33:08: RTMPPublisher::SocketLoop: Stalled for 1510 ms to write 242515 bytes (buffer: 0 / 244736), unstable connection?
21:33:12: RTMPPublisher::SocketLoop: Stalled for 2769 ms to write 243277 bytes (buffer: 0 / 244736), unstable connection?
21:33:14: RTMPPublisher::SocketLoop: Stalled for 1595 ms to write 242529 bytes (buffer: 0 / 244736), unstable connection?
21:33:16: RTMPPublisher::SocketLoop: Stalled for 2464 ms to write 240950 bytes (buffer: 0 / 244736), unstable connection?
21:33:18: RTMPPublisher::SocketLoop: Stalled for 1878 ms to write 241692 bytes (buffer: 0 / 244736), unstable connection?
21:33:20: RTMPPublisher::SocketLoop: Stalled for 2301 ms to write 243284 bytes (buffer: 0 / 244736), unstable connection?
21:33:22: RTMPPublisher::SocketLoop: Stalled for 2020 ms to write 244577 bytes (buffer: 0 / 244736), unstable connection?
21:33:24: RTMPPublisher::SocketLoop: Stalled for 2076 ms to write 243315 bytes (buffer: 0 / 244736), unstable connection?
21:33:26: RTMPPublisher::SocketLoop: Stalled for 1838 ms to write 244260 bytes (buffer: 0 / 244736), unstable connection?
21:33:28: RTMPPublisher::SocketLoop: Stalled for 2099 ms to write 244108 bytes (buffer: 0 / 244736), unstable connection?
21:33:30: RTMPPublisher::SocketLoop: Stalled for 1759 ms to write 242860 bytes (buffer: 0 / 244736), unstable connection?
21:33:32: RTMPPublisher::SocketLoop: Stalled for 1892 ms to write 241240 bytes (buffer: 0 / 244736), unstable connection?
21:33:34: RTMPPublisher::SocketLoop: Stalled for 2217 ms to write 244531 bytes (buffer: 0 / 244736), unstable connection?
21:33:36: RTMPPublisher::SocketLoop: Stalled for 1716 ms to write 244358 bytes (buffer: 0 / 244736), unstable connection?
21:33:38: RTMPPublisher::SocketLoop: Stalled for 2167 ms to write 241996 bytes (buffer: 0 / 244736), unstable connection?
21:33:40: RTMPPublisher::SocketLoop: Stalled for 2063 ms to write 244146 bytes (buffer: 0 / 244736), unstable connection?
21:33:43: RTMPPublisher::SocketLoop: Stalled for 1837 ms to write 242916 bytes (buffer: 0 / 244736), unstable connection?
21:33:45: RTMPPublisher::SocketLoop: Stalled for 1517 ms to write 243594 bytes (buffer: 0 / 244736), unstable connection?
21:33:47: RTMPPublisher::SocketLoop: Stalled for 1703 ms to write 241174 bytes (buffer: 0 / 244736), unstable connection?
21:33:49: RTMPPublisher::SocketLoop: Stalled for 2309 ms to write 243099 bytes (buffer: 0 / 244736), unstable connection?
21:33:51: RTMPPublisher::SocketLoop: Stalled for 1728 ms to write 241450 bytes (buffer: 0 / 244736), unstable connection?
21:33:52: RTMPPublisher::SocketLoop: Stalled for 1847 ms to write 218692 bytes (buffer: 0 / 244736), unstable connection?
21:33:54: RTMPPublisher::SocketLoop: Stalled for 1751 ms to write 244617 bytes (buffer: 0 / 244736), unstable connection?
21:33:56: RTMPPublisher::SocketLoop: Stalled for 1569 ms to write 243493 bytes (buffer: 0 / 244736), unstable connection?
21:33:58: RTMPPublisher::SocketLoop: Stalled for 1918 ms to write 242718 bytes (buffer: 0 / 244736), unstable connection?
21:34:00: RTMPPublisher::SocketLoop: Stalled for 1982 ms to write 243684 bytes (buffer: 0 / 244736), unstable connection?
21:34:02: RTMPPublisher::SocketLoop: Stalled for 2189 ms to write 242830 bytes (buffer: 0 / 244736), unstable connection?
21:34:03: RTMPPublisher::SocketLoop: Stalled for 1624 ms to write 242039 bytes (buffer: 0 / 244736), unstable connection?
21:34:06: RTMPPublisher::SocketLoop: Stalled for 2353 ms to write 243830 bytes (buffer: 0 / 244736), unstable connection?
21:34:08: RTMPPublisher::SocketLoop: Stalled for 1990 ms to write 243698 bytes (buffer: 0 / 244736), unstable connection?
21:34:10: RTMPPublisher::SocketLoop: Stalled for 2417 ms to write 243248 bytes (buffer: 0 / 244736), unstable connection?
21:34:13: RTMPPublisher::SocketLoop: Stalled for 2563 ms to write 241324 bytes (buffer: 0 / 244736), unstable connection?
21:34:14: RTMPPublisher::SocketLoop: Stalled for 1663 ms to write 241846 bytes (buffer: 0 / 244736), unstable connection?
21:34:16: RTMPPublisher::SocketLoop: Stalled for 1796 ms to write 244725 bytes (buffer: 0 / 244736), unstable connection?
21:34:18: RTMPPublisher::SocketLoop: Stalled for 1503 ms to write 243108 bytes (buffer: 0 / 244736), unstable connection?
21:34:20: RTMPPublisher::SocketLoop: Stalled for 2671 ms to write 242419 bytes (buffer: 0 / 244736), unstable connection?
21:34:22: RTMPPublisher::SocketLoop: Stalled for 1959 ms to write 241100 bytes (buffer: 0 / 244736), unstable connection?
21:34:24: RTMPPublisher::SocketLoop: Stalled for 1634 ms to write 232502 bytes (buffer: 0 / 244736), unstable connection?
21:34:27: RTMPPublisher::SocketLoop: Stalled for 1801 ms to write 241494 bytes (buffer: 0 / 244736), unstable connection?
21:34:31: RTMPPublisher::SocketLoop: Stalled for 2768 ms to write 240817 bytes (buffer: 0 / 244736), unstable connection?
21:34:35: RTMPPublisher::SocketLoop: Stalled for 3075 ms to write 242613 bytes (buffer: 0 / 244736), unstable connection?
21:34:37: RTMPPublisher::SocketLoop: Stalled for 1687 ms to write 240880 bytes (buffer: 0 / 244736), unstable connection?
21:34:38: RTMPPublisher::SocketLoop: Stalled for 1503 ms to write 240763 bytes (buffer: 0 / 244736), unstable connection?
21:34:40: RTMPPublisher::SocketLoop: Stalled for 1838 ms to write 243721 bytes (buffer: 0 / 244736), unstable connection?
21:34:42: RTMPPublisher::SocketLoop: Stalled for 1735 ms to write 241712 bytes (buffer: 0 / 244736), unstable connection?
21:34:44: RTMPPublisher::SocketLoop: Stalled for 1828 ms to write 241300 bytes (buffer: 0 / 244736), unstable connection?
21:34:47: RTMPPublisher::SocketLoop: Stalled for 3107 ms to write 241900 bytes (buffer: 0 / 244736), unstable connection?
21:34:49: RTMPPublisher::SocketLoop: Stalled for 1906 ms to write 244592 bytes (buffer: 0 / 244736), unstable connection?
21:34:51: RTMPPublisher::SocketLoop: Stalled for 2131 ms to write 244505 bytes (buffer: 0 / 244736), unstable connection?
21:34:52: RTMPPublisher::SocketLoop: Stalled for 1631 ms to write 243204 bytes (buffer: 0 / 244736), unstable connection?
21:34:55: RTMPPublisher::SocketLoop: Stalled for 2266 ms to write 241470 bytes (buffer: 0 / 244736), unstable connection?
21:34:57: RTMPPublisher::SocketLoop: Stalled for 1955 ms to write 240707 bytes (buffer: 0 / 244736), unstable connection?
21:34:59: RTMPPublisher::SocketLoop: Stalled for 2578 ms to write 242707 bytes (buffer: 0 / 244736), unstable connection?
21:35:02: RTMPPublisher::SocketLoop: Stalled for 1771 ms to write 244079 bytes (buffer: 0 / 244736), unstable connection?
21:35:04: RTMPPublisher::SocketLoop: Stalled for 1987 ms to write 242178 bytes (buffer: 0 / 244736), unstable connection?
21:35:08: RTMPPublisher::SocketLoop: Stalled for 1985 ms to write 241565 bytes (buffer: 0 / 244736), unstable connection?
21:35:12: RTMPPublisher::SocketLoop: Stalled for 1880 ms to write 240906 bytes (buffer: 0 / 244736), unstable connection?
21:35:14: RTMPPublisher::SocketLoop: Stalled for 1586 ms to write 244564 bytes (buffer: 0 / 244736), unstable connection?
21:35:16: RTMPPublisher::SocketLoop: Stalled for 1674 ms to write 240828 bytes (buffer: 0 / 244736), unstable connection?
21:35:19: RTMPPublisher::SocketLoop: Stalled for 2169 ms to write 242595 bytes (buffer: 0 / 244736), unstable connection?
21:35:21: RTMPPublisher::SocketLoop: Stalled for 2283 ms to write 240882 bytes (buffer: 0 / 244736), unstable connection?
21:35:23: RTMPPublisher::SocketLoop: Stalled for 1688 ms to write 244339 bytes (buffer: 0 / 244736), unstable connection?
21:35:27: RTMPPublisher::SocketLoop: Stalled for 2587 ms to write 243881 bytes (buffer: 0 / 244736), unstable connection?
21:35:30: RTMPPublisher::SocketLoop: Stalled for 2751 ms to write 241799 bytes (buffer: 0 / 244736), unstable connection?
21:35:32: RTMPPublisher::SocketLoop: Stalled for 2617 ms to write 242531 bytes (buffer: 0 / 244736), unstable connection?
21:35:35: RTMPPublisher::SocketLoop: Stalled for 2323 ms to write 243752 bytes (buffer: 0 / 244736), unstable connection?
21:35:37: RTMPPublisher::SocketLoop: Stalled for 1786 ms to write 241965 bytes (buffer: 0 / 244736), unstable connection?
21:35:39: RTMPPublisher::SocketLoop: Stalled for 1973 ms to write 243163 bytes (buffer: 0 / 244736), unstable connection?
21:35:41: RTMPPublisher::SocketLoop: Stalled for 2584 ms to write 244627 bytes (buffer: 0 / 244736), unstable connection?
21:35:43: RTMPPublisher::SocketLoop: Stalled for 2243 ms to write 243526 bytes (buffer: 0 / 244736), unstable connection?
21:35:46: RTMPPublisher::SocketLoop: Stalled for 2721 ms to write 243864 bytes (buffer: 0 / 244736), unstable connection?
21:35:48: RTMPPublisher::SocketLoop: Stalled for 1889 ms to write 241699 bytes (buffer: 0 / 244736), unstable connection?
21:35:52: RTMPPublisher::SocketLoop: Stalled for 2623 ms to write 241560 bytes (buffer: 0 / 244736), unstable connection?
21:35:54: RTMPPublisher::SocketLoop: Stalled for 2110 ms to write 243960 bytes (buffer: 0 / 244736), unstable connection?
21:35:56: RTMPPublisher::SocketLoop: Stalled for 2130 ms to write 244318 bytes (buffer: 0 / 244736), unstable connection?
21:35:58: RTMPPublisher::SocketLoop: Stalled for 1678 ms to write 244611 bytes (buffer: 0 / 244736), unstable connection?
21:35:59: RTMPPublisher::SocketLoop: Stalled for 1574 ms to write 243909 bytes (buffer: 0 / 244736), unstable connection?
21:36:03: RTMPPublisher::SocketLoop: Stalled for 1810 ms to write 244247 bytes (buffer: 0 / 244736), unstable connection?
21:36:05: RTMPPublisher::SocketLoop: Stalled for 2251 ms to write 243927 bytes (buffer: 0 / 244736), unstable connection?
21:36:07: RTMPPublisher::SocketLoop: Stalled for 1902 ms to write 242515 bytes (buffer: 0 / 244736), unstable connection?
21:36:09: RTMPPublisher::SocketLoop: Stalled for 1955 ms to write 244619 bytes (buffer: 0 / 244736), unstable connection?
21:36:12: RTMPPublisher::SocketLoop: Stalled for 3047 ms to write 242687 bytes (buffer: 0 / 244736), unstable connection?
21:36:14: RTMPPublisher::SocketLoop: Stalled for 2249 ms to write 240918 bytes (buffer: 0 / 244736), unstable connection?
21:36:16: RTMPPublisher::SocketLoop: Stalled for 2467 ms to write 243802 bytes (buffer: 0 / 244736), unstable connection?
21:36:19: RTMPPublisher::SocketLoop: Stalled for 2179 ms to write 242842 bytes (buffer: 0 / 244736), unstable connection?
21:36:22: RTMPPublisher::SocketLoop: Stalled for 3691 ms to write 241294 bytes (buffer: 0 / 244736), unstable connection?
21:36:24: RTMPPublisher::SocketLoop: Stalled for 2211 ms to write 241387 bytes (buffer: 0 / 244736), unstable connection?
21:36:26: RTMPPublisher::SocketLoop: Stalled for 1851 ms to write 241241 bytes (buffer: 0 / 244736), unstable connection?
21:36:29: RTMPPublisher::SocketLoop: Stalled for 2569 ms to write 243604 bytes (buffer: 0 / 244736), unstable connection?
21:36:32: RTMPPublisher::SocketLoop: Stalled for 2839 ms to write 240986 bytes (buffer: 0 / 244736), unstable connection?
21:36:35: RTMPPublisher::SocketLoop: Stalled for 3286 ms to write 242305 bytes (buffer: 0 / 244736), unstable connection?
21:36:37: RTMPPublisher::SocketLoop: Stalled for 1762 ms to write 243723 bytes (buffer: 0 / 244736), unstable connection?
21:36:39: RTMPPublisher::SocketLoop: Stalled for 2690 ms to write 243313 bytes (buffer: 0 / 244736), unstable connection?
21:36:42: RTMPPublisher::SocketLoop: Stalled for 2347 ms to write 243588 bytes (buffer: 0 / 244736), unstable connection?
21:36:44: RTMPPublisher::SocketLoop: Stalled for 2002 ms to write 243739 bytes (buffer: 0 / 244736), unstable connection?
21:36:46: RTMPPublisher::SocketLoop: Stalled for 1700 ms to write 240709 bytes (buffer: 0 / 244736), unstable connection?
21:36:48: RTMPPublisher::SocketLoop: Stalled for 2135 ms to write 243366 bytes (buffer: 0 / 244736), unstable connection?
21:36:50: RTMPPublisher::SocketLoop: Stalled for 1978 ms to write 244409 bytes (buffer: 0 / 244736), unstable connection?
21:36:52: RTMPPublisher::SocketLoop: Stalled for 2552 ms to write 241640 bytes (buffer: 0 / 244736), unstable connection?
21:36:54: RTMPPublisher::SocketLoop: Stalled for 2141 ms to write 241087 bytes (buffer: 0 / 244736), unstable connection?
21:36:57: RTMPPublisher::SocketLoop: Stalled for 3022 ms to write 241229 bytes (buffer: 0 / 244736), unstable connection?
21:36:59: RTMPPublisher::SocketLoop: Stalled for 1755 ms to write 242135 bytes (buffer: 0 / 244736), unstable connection?
21:37:01: RTMPPublisher::SocketLoop: Stalled for 2040 ms to write 240019 bytes (buffer: 0 / 244736), unstable connection?
21:37:03: RTMPPublisher::SocketLoop: Stalled for 1785 ms to write 243435 bytes (buffer: 0 / 244736), unstable connection?
21:37:05: RTMPPublisher::SocketLoop: Stalled for 2383 ms to write 244187 bytes (buffer: 0 / 244736), unstable connection?
21:37:08: RTMPPublisher::SocketLoop: Stalled for 2731 ms to write 240945 bytes (buffer: 0 / 244736), unstable connection?
21:37:10: RTMPPublisher::SocketLoop: Stalled for 2222 ms to write 244208 bytes (buffer: 0 / 244736), unstable connection?
21:37:13: RTMPPublisher::SocketLoop: Stalled for 2488 ms to write 243546 bytes (buffer: 0 / 244736), unstable connection?
21:37:15: RTMPPublisher::SocketLoop: Stalled for 2396 ms to write 244075 bytes (buffer: 0 / 244736), unstable connection?
21:37:19: RTMPPublisher::SocketLoop: Stalled for 3871 ms to write 243467 bytes (buffer: 0 / 244736), unstable connection?
21:37:22: RTMPPublisher::SocketLoop: Stalled for 2614 ms to write 242361 bytes (buffer: 0 / 244736), unstable connection?
21:37:24: RTMPPublisher::SocketLoop: Stalled for 1964 ms to write 241410 bytes (buffer: 0 / 244736), unstable connection?
21:37:26: RTMPPublisher::SocketLoop: Stalled for 2184 ms to write 243934 bytes (buffer: 0 / 244736), unstable connection?
21:37:28: RTMPPublisher::SocketLoop: Stalled for 2414 ms to write 243357 bytes (buffer: 0 / 244736), unstable connection?
21:37:30: RTMPPublisher::SocketLoop: Stalled for 2123 ms to write 242477 bytes (buffer: 0 / 244736), unstable connection?
21:37:32: RTMPPublisher::SocketLoop: Stalled for 2125 ms to write 241184 bytes (buffer: 0 / 244736), unstable connection?
21:37:35: RTMPPublisher::SocketLoop: Stalled for 2119 ms to write 244184 bytes (buffer: 0 / 244736), unstable connection?
21:37:37: RTMPPublisher::SocketLoop: Stalled for 2128 ms to write 244462 bytes (buffer: 0 / 244736), unstable connection?
21:37:39: RTMPPublisher::SocketLoop: Stalled for 2434 ms to write 242524 bytes (buffer: 0 / 244736), unstable connection?
21:37:41: RTMPPublisher::SocketLoop: Stalled for 2109 ms to write 243159 bytes (buffer: 0 / 244736), unstable connection?
21:37:43: RTMPPublisher::SocketLoop: Stalled for 1662 ms to write 242599 bytes (buffer: 0 / 244736), unstable connection?
21:37:45: RTMPPublisher::SocketLoop: Stalled for 1838 ms to write 243447 bytes (buffer: 0 / 244736), unstable connection?
21:37:48: RTMPPublisher::SocketLoop: Stalled for 2793 ms to write 244339 bytes (buffer: 0 / 244736), unstable connection?
21:37:49: RTMPPublisher::SocketLoop: Stalled for 1902 ms to write 242587 bytes (buffer: 0 / 244736), unstable connection?
21:37:52: RTMPPublisher::SocketLoop: Stalled for 2497 ms to write 244562 bytes (buffer: 0 / 244736), unstable connection?
21:37:54: RTMPPublisher::SocketLoop: Stalled for 2522 ms to write 241894 bytes (buffer: 0 / 244736), unstable connection?
21:37:58: RTMPPublisher::SocketLoop: Stalled for 3169 ms to write 242146 bytes (buffer: 0 / 244736), unstable connection?
21:38:00: RTMPPublisher::SocketLoop: Stalled for 2663 ms to write 241441 bytes (buffer: 0 / 244736), unstable connection?
21:38:04: RTMPPublisher::SocketLoop: Stalled for 3462 ms to write 241371 bytes (buffer: 0 / 244736), unstable connection?
21:38:06: RTMPPublisher::SocketLoop: Stalled for 2217 ms to write 240850 bytes (buffer: 0 / 244736), unstable connection?
21:38:08: RTMPPublisher::SocketLoop: Stalled for 2306 ms to write 241883 bytes (buffer: 0 / 244736), unstable connection?
21:38:11: RTMPPublisher::SocketLoop: Stalled for 2822 ms to write 242060 bytes (buffer: 0 / 244736), unstable connection?
21:38:14: RTMPPublisher::SocketLoop: Stalled for 3169 ms to write 243908 bytes (buffer: 0 / 244736), unstable connection?
21:38:18: RTMPPublisher::SocketLoop: Stalled for 3233 ms to write 243546 bytes (buffer: 0 / 244736), unstable connection?
21:38:21: RTMPPublisher::SocketLoop: Stalled for 3272 ms to write 244719 bytes (buffer: 0 / 244736), unstable connection?
21:38:24: RTMPPublisher::SocketLoop: Stalled for 2105 ms to write 242930 bytes (buffer: 0 / 244736), unstable connection?
21:38:26: RTMPPublisher::SocketLoop: Stalled for 2492 ms to write 242631 bytes (buffer: 0 / 244736), unstable connection?
21:38:29: RTMPPublisher::SocketLoop: Stalled for 2237 ms to write 244118 bytes (buffer: 0 / 244736), unstable connection?
21:38:31: RTMPPublisher::SocketLoop: Stalled for 2351 ms to write 242326 bytes (buffer: 0 / 244736), unstable connection?
21:38:33: RTMPPublisher::SocketLoop: Stalled for 2167 ms to write 241954 bytes (buffer: 0 / 244736), unstable connection?
21:38:36: RTMPPublisher::SocketLoop: Stalled for 3100 ms to write 241821 bytes (buffer: 0 / 244736), unstable connection?
21:38:39: RTMPPublisher::SocketLoop: Stalled for 2515 ms to write 242167 bytes (buffer: 0 / 244736), unstable connection?
21:38:41: RTMPPublisher::SocketLoop: Stalled for 2740 ms to write 244631 bytes (buffer: 0 / 244736), unstable connection?
21:38:44: RTMPPublisher::SocketLoop: Stalled for 2232 ms to write 242637 bytes (buffer: 0 / 244736), unstable connection?
21:38:46: RTMPPublisher::SocketLoop: Stalled for 1832 ms to write 240895 bytes (buffer: 0 / 244736), unstable connection?
21:38:48: RTMPPublisher::SocketLoop: Stalled for 2060 ms to write 241283 bytes (buffer: 0 / 244736), unstable connection?
21:38:50: RTMPPublisher::SocketLoop: Stalled for 2310 ms to write 243144 bytes (buffer: 0 / 244736), unstable connection?
21:38:53: RTMPPublisher::SocketLoop: Stalled for 2719 ms to write 242927 bytes (buffer: 0 / 244736), unstable connection?
21:38:55: RTMPPublisher::SocketLoop: Stalled for 2475 ms to write 242285 bytes (buffer: 0 / 244736), unstable connection?
21:38:58: RTMPPublisher::SocketLoop: Stalled for 2862 ms to write 242151 bytes (buffer: 0 / 244736), unstable connection?
21:39:01: RTMPPublisher::SocketLoop: Stalled for 2645 ms to write 242465 bytes (buffer: 0 / 244736), unstable connection?
21:39:04: RTMPPublisher::SocketLoop: Stalled for 3249 ms to write 242506 bytes (buffer: 0 / 244736), unstable connection?
21:39:06: RTMPPublisher::SocketLoop: Stalled for 2618 ms to write 241783 bytes (buffer: 0 / 244736), unstable connection?
21:39:08: RTMPPublisher::SocketLoop: Stalled for 1726 ms to write 244560 bytes (buffer: 0 / 244736), unstable connection?
21:39:10: RTMPPublisher::SocketLoop: Stalled for 2193 ms to write 243075 bytes (buffer: 0 / 244736), unstable connection?
21:39:13: RTMPPublisher::SocketLoop: Stalled for 3134 ms to write 244034 bytes (buffer: 0 / 244736), unstable connection?
21:39:16: RTMPPublisher::SocketLoop: Stalled for 2308 ms to write 242290 bytes (buffer: 0 / 244736), unstable connection?
21:39:19: RTMPPublisher::SocketLoop: Stalled for 2096 ms to write 244523 bytes (buffer: 0 / 244736), unstable connection?
21:39:21: RTMPPublisher::SocketLoop: Stalled for 1723 ms to write 241533 bytes (buffer: 0 / 244736), unstable connection?
21:39:23: RTMPPublisher::SocketLoop: Stalled for 2224 ms to write 240928 bytes (buffer: 0 / 244736), unstable connection?
21:39:25: RTMPPublisher::SocketLoop: Stalled for 1639 ms to write 242777 bytes (buffer: 0 / 244736), unstable connection?
21:39:27: RTMPPublisher::SocketLoop: Stalled for 2074 ms to write 243943 bytes (buffer: 0 / 244736), unstable connection?
21:39:29: RTMPPublisher::SocketLoop: Stalled for 2204 ms to write 244069 bytes (buffer: 0 / 244736), unstable connection?
21:39:33: RTMPPublisher::SocketLoop: Stalled for 2288 ms to write 240810 bytes (buffer: 0 / 244736), unstable connection?
21:39:35: RTMPPublisher::SocketLoop: Stalled for 1986 ms to write 242562 bytes (buffer: 0 / 244736), unstable connection?
21:39:37: RTMPPublisher::SocketLoop: Stalled for 1805 ms to write 241164 bytes (buffer: 0 / 244736), unstable connection?
21:39:39: RTMPPublisher::SocketLoop: Stalled for 2541 ms to write 241125 bytes (buffer: 0 / 244736), unstable connection?
21:39:41: RTMPPublisher::SocketLoop: Stalled for 1547 ms to write 242705 bytes (buffer: 0 / 244736), unstable connection?
21:39:43: RTMPPublisher::SocketLoop: Stalled for 2419 ms to write 243804 bytes (buffer: 0 / 244736), unstable connection?
21:39:47: RTMPPublisher::SocketLoop: Stalled for 3838 ms to write 241152 bytes (buffer: 0 / 244736), unstable connection?
21:39:49: RTMPPublisher::SocketLoop: Stalled for 1653 ms to write 242993 bytes (buffer: 0 / 244736), unstable connection?
21:39:52: RTMPPublisher::SocketLoop: Stalled for 3682 ms to write 244502 bytes (buffer: 0 / 244736), unstable connection?
21:39:55: RTMPPublisher::SocketLoop: Stalled for 3246 ms to write 242204 bytes (buffer: 0 / 244736), unstable connection?
21:39:57: RTMPPublisher::SocketLoop: Stalled for 1733 ms to write 244275 bytes (buffer: 0 / 244736), unstable connection?
21:39:59: RTMPPublisher::SocketLoop: Stalled for 1987 ms to write 242357 bytes (buffer: 0 / 244736), unstable connection?
21:40:02: RTMPPublisher::SocketLoop: Stalled for 2907 ms to write 242218 bytes (buffer: 0 / 244736), unstable connection?
21:40:04: RTMPPublisher::SocketLoop: Stalled for 1668 ms to write 244024 bytes (buffer: 0 / 244736), unstable connection?
21:40:06: RTMPPublisher::SocketLoop: Stalled for 2150 ms to write 244219 bytes (buffer: 0 / 244736), unstable connection?
21:40:08: RTMPPublisher::SocketLoop: Stalled for 2381 ms to write 241664 bytes (buffer: 0 / 244736), unstable connection?
21:40:12: RTMPPublisher::SocketLoop: Stalled for 3776 ms to write 241061 bytes (buffer: 0 / 244736), unstable connection?
21:40:15: RTMPPublisher::SocketLoop: Stalled for 2853 ms to write 241787 bytes (buffer: 0 / 244736), unstable connection?
21:40:17: RTMPPublisher::SocketLoop: Stalled for 1747 ms to write 242416 bytes (buffer: 0 / 244736), unstable connection?
21:40:19: RTMPPublisher::SocketLoop: Stalled for 1928 ms to write 242278 bytes (buffer: 0 / 244736), unstable connection?
21:40:20: RTMPPublisher::SocketLoop: Stalled for 1800 ms to write 244626 bytes (buffer: 0 / 244736), unstable connection?
21:40:23: RTMPPublisher::SocketLoop: Stalled for 2567 ms to write 244006 bytes (buffer: 0 / 244736), unstable connection?
21:40:25: RTMPPublisher::SocketLoop: Stalled for 2394 ms to write 242651 bytes (buffer: 0 / 244736), unstable connection?
21:40:28: RTMPPublisher::SocketLoop: Stalled for 2285 ms to write 241588 bytes (buffer: 0 / 244736), unstable connection?
21:40:30: RTMPPublisher::SocketLoop: Stalled for 2303 ms to write 243500 bytes (buffer: 0 / 244736), unstable connection?
21:40:32: RTMPPublisher::SocketLoop: Stalled for 1674 ms to write 244400 bytes (buffer: 0 / 244736), unstable connection?
21:40:35: RTMPPublisher::SocketLoop: Stalled for 2989 ms to write 241320 bytes (buffer: 0 / 244736), unstable connection?
21:40:37: RTMPPublisher::SocketLoop: Stalled for 2086 ms to write 241039 bytes (buffer: 0 / 244736), unstable connection?
21:40:39: RTMPPublisher::SocketLoop: Stalled for 2263 ms to write 240888 bytes (buffer: 0 / 244736), unstable connection?
21:40:41: RTMPPublisher::SocketLoop: Stalled for 2258 ms to write 240843 bytes (buffer: 0 / 244736), unstable connection?
21:40:44: RTMPPublisher::SocketLoop: Stalled for 2642 ms to write 241139 bytes (buffer: 0 / 244736), unstable connection?
21:40:47: RTMPPublisher::SocketLoop: Stalled for 2672 ms to write 242014 bytes (buffer: 0 / 244736), unstable connection?
21:40:49: RTMPPublisher::SocketLoop: Stalled for 2723 ms to write 241357 bytes (buffer: 0 / 244736), unstable connection?
21:40:53: RTMPPublisher::SocketLoop: Stalled for 3559 ms to write 243260 bytes (buffer: 0 / 244736), unstable connection?
21:40:55: RTMPPublisher::SocketLoop: Stalled for 2673 ms to write 243302 bytes (buffer: 0 / 244736), unstable connection?
21:40:58: RTMPPublisher::SocketLoop: Stalled for 2313 ms to write 241217 bytes (buffer: 0 / 244736), unstable connection?
21:41:02: RTMPPublisher::SocketLoop: Stalled for 2536 ms to write 244676 bytes (buffer: 0 / 244736), unstable connection?
21:41:04: RTMPPublisher::SocketLoop: Stalled for 1929 ms to write 241278 bytes (buffer: 0 / 244736), unstable connection?
21:41:06: RTMPPublisher::SocketLoop: Stalled for 1990 ms to write 243990 bytes (buffer: 0 / 244736), unstable connection?
21:41:07: RTMPPublisher::SocketLoop: Stalled for 1916 ms to write 243691 bytes (buffer: 0 / 244736), unstable connection?
21:41:10: RTMPPublisher::SocketLoop: Stalled for 2239 ms to write 241463 bytes (buffer: 0 / 244736), unstable connection?
21:41:11: RTMPPublisher::SocketLoop: Stalled for 1535 ms to write 242397 bytes (buffer: 0 / 244736), unstable connection?
21:41:13: Total frames encoded: 19848, total frames duplicated: 1 (0.01%)
21:41:13: Total frames rendered: 19852, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
21:41:14: RTMPPublisher::SocketLoop: Aborting due to WSAEnumNetworkEvents failure, 10038
21:41:14: Average send payload: 236716 bytes, average send interval: 2120 ms
21:41:14: Number of times waited to send: 300, Waited for a total of 1170290 bytes
21:41:14: Number of b-frames dropped: 6708 (34%), Number of p-frames dropped: 6707 (34%), Total 13415 (68%)
21:41:14: Number of bytes sent: 73382251
21:41:14:
21:41:14: Profiler time results:
21:41:14:
21:41:14: ==============================================================
21:41:14: video thread frame - [100%] [avg time: 0.528 ms] [children: 15.3%] [unaccounted: 84.7%]
21:41:14: | scene->Preprocess - [0.189%] [avg time: 0.001 ms]
21:41:14: | GPU download and conversion - [15.2%] [avg time: 0.08 ms] [children: 11.6%] [unaccounted: 3.6%]
21:41:14: | | flush - [8.9%] [avg time: 0.047 ms]
21:41:14: | | CopyResource - [2.46%] [avg time: 0.013 ms]
21:41:14: | | conversion to 4:2:0 - [0.189%] [avg time: 0.001 ms]
21:41:14: Convert444Threads - [100%] [avg time: 0.398 ms] [children: 99.5%] [unaccounted: 0.503%]
21:41:14: | Convert444toNV12 - [99.5%] [avg time: 0.396 ms]
21:41:14: encoder thread frame - [100%] [avg time: 0.876 ms]
21:41:14:
21:41:14:
21:41:14: Profiler CPU results:
21:41:14:
21:41:14: video thread frame - [cpu time: avg 0.012 ms, total 249.601 ms] [avg calls per frame: 1]
21:41:14: | scene->Preprocess - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
21:41:14: | GPU download and conversion - [cpu time: avg 0.005 ms, total 109.201 ms] [avg calls per frame: 1]
21:41:14: | | flush - [cpu time: avg 0.005 ms, total 109.201 ms] [avg calls per frame: 1]
21:41:14: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
21:41:14: | | conversion to 4:2:0 - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
21:41:14: Convert444Threads - [cpu time: avg 0.276 ms, total 10966.9 ms] [avg calls per frame: 2]
21:41:14: | Convert444toNV12 - [cpu time: avg 0.269 ms, total 10701.7 ms] [avg calls per frame: 2]
21:41:14: encoder thread frame - [cpu time: avg 0.01 ms, total 202.801 ms] [avg calls per frame: 1]
21:41:14:
21:41:14: =====Stream End: 2014-01-18, 21:41:14=================================================
21:41:37: Server Ping plugin instance deleted; removing dynamically loaded localization strings
21:41:37: Video Source Plugin instance deleted; removing dynamically loaded localization strings
